Trying to get router to work
I'm trying to hook up my new wireless router to my new laptop, but my cable modem uses a USB port, and I need an ethernet connection for my router. The modem has an ethernet port, but it's not currently used. I've tried to attach an ethernet cable, but I don't get an internet connection without the USB cable. Do I need to get a new modem from my ISP? j dont have ethernet so it is imposibble to conect wirelles router dl-524 because it says 'check if your router is on
    Master:
  • 538 Answers
That would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Posted on Oct 22, 2008
I am trying to connect my new router to my laptop,but the instructions say i should connect my pc to the internet by connecting my ethernet cable to the router.my problem is i have only one connection and...
Modem <-- Ethernet cable --> WAN port on router
LAN port #1 on router <--- Ethernet cable --> network-port on desktop computer
LAN port #2 on router <-- Ethernet cable --> network-port on laptop computer
If the router has built-in "wireless" capability, then use the desktop computer's connection to the router to "configure" the wireless adapter, i.e., pick an SSID, and establish a password, and then your laptop computer can use the SSID/password to connect "wirelessly" to the router.
Mar 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
Feb 10, 2010 | Linksys Wireless-G Broadband Router
Trying to hook up a dlink router using cricket broadband wireless modem. need help?!?!?
Cable-modem (or DSL-modem) --> WAN port on CRICKET
and you _have_ a wireless network, without using the D-Link.
If you really want to get yourself confused:
LAN port on Cricket <--- Ethernet "cross-over" cable ---> WAN port on D-Link router.
Jan 28, 2010 | D-Link DIR-615 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
