Question about Patton U21403UC Floor / Box Fan
Turning itself off
My floor fan has been constantly turning itself off after every 10mins....It runs fine while it's on. It's all almost like it's on a timed schedule. What can I do. When it turns off I hear something that sounds like slight grinding. It's been doing this for 2-3years now. What can I do?
Well its 1 of 2 things either the winding is bad in which case you'd smell a sicky burning chemical smell, or the bearings have seized. I'm guessing the bearings are bad, there probably getting the winding too hot causing itself to short out. If its a cheap Walmart bought fan then just replace it, if not you can take it apart yourself pretty easily. You may have trouble getting the bearings of the shaft, i use a die grinder with a cutoff wheel on it, just try not to cut into the shaft, you can crack it with a hammer after your almost through then they usually just slide off. Then swing up to a bearing store they'll probably just be a couple of bucks a piece(tell them you don't care what class they are just gimme the cheapest except dolly bearings, and bring the old ones with you). Then get a piece of pipe that matches the "inner race", and carefully hammer them onto the same part of the shaft(mark it prior if there is no bearing shoulder), if there are copper wires running through the laminations (if there are any) on the shaft, tape a rag around them to prevent damage. If any of the wires are damaged on the inside of the motor go buy a new one, it'll cost several hundred to rewind it.
Posted on May 12, 2007
It's now turning itself off and back on constantly. Got a fix?
See answer here Old Motorola RAZR ce0168 keeps turning itself of then on Got fix
Motorola Support
Dec 27, 2014 | Motorola Mobility RAZR V3
Do you bypass the run capacitator on a lakewood model hv-18 fan with a 2.4 motor
More than likely it's not the start capacitor why your fan will not run this more than likely it's not the start capacitor why your fan will not run this lubrication try turning the fan motor by hand if it does not turn freely it's lubrication I have answered this another post.
more than likely it is lubrication spray WD-40 into the oil holes after you have unplugged the fan of course Keep turning the fan and you'll notice will start turning more freely apply more oil to the rear of the motor as this is an oil bushing you're putting more oil into
hope this solves your problem
May 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Firdge turns on but never gets cold. Runs constantly. Refridgerant maybe?
Is the condenser fan turning? Is the evaporater fan turning? Check the evaporater at the freezer compartment it should have fine frost all the way if no frost or partly frosted may be low on freon.Be sure there is no air leaks around door or something. Hope this helps.
Dec 23, 2010 | LG (LRBC22522ST) Stainless Steel
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Blades stop working
Does your mower have an electric clutch ? If so your problem is most likely a connection
May 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Fan runs constantly
i'm not sure what you mean... what fan... if you mean the cpu fan ... it's supposed to run all the time... is it noisy ?
Jan 11, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
Dell Latitude D600
Check that the cpu fan is working. In easynote usually you uncrew a panel at the back of the laptop. If it is not that may be a common system problem, in that case reinstall your system.
Mar 13, 2008 | Dell Latitude D600 Notebook
Computer turns off by itself
there is a problem in your power supply, you need to replace this with a new one
Jan 06, 2008 | Computers & Internet
Patton U21403UC Floor / Box Fan Logo
196 people viewed this question
Top Patton Dryers Experts
Mohamed Ismail
Mohamed Ismail
Are you a Patton Dryer Expert? Answer questions, earn points and help others
