I am using Image mixer 3 and am struggling with saving a project and then opening it to continue working on it or to write it. Does it need to save it as an M peg? Where does it save it to and how can i get it back to then burn it? Sounds simple but we have spent hours trying to suss this out and read all the help pages to no avail. It seems to be saving the file but when i go to open it again nothing is there??
  • 883 Answers
SOURCE: Unable to use file save or file save as without getting dialogue box with error 15 or 43
someone has placed a read-only password on file
Posted on May 21, 2007
  • 265 Answers
SOURCE: Issue With File Titled "Normal.dotm" in Word 2007
sgoss53080,
Please note that you should NEVER give someone your software's Product Key! Balaji123's inquiry has been reported to the Webmaster.
The issue that you've encountered has no easy solution. Please read this Microsoft Knowledge Base article:
http://support.microsoft.com/kb/924460/en-us
Posted on Feb 08, 2008
SOURCE: PD-DVR100 DVD Tray will not open
I am having the same problem. Sometimes, unplugging the unit works, but only after multiple attempts. However, recently, it didn't work at all after several days of unplugging and replugging the unit in. After doing some research with other brands experiencing the same problem, some of the solutions suggested pressing the open button and record button @ the same time. I tried it, and It didn't work; however, when I pressed the center of the "source/record" button, it opened! Thank goodness, because I had a DVD in the drawer and thought I was going to have to tear the thing apart to avoid buying it from Blockbuster. Hopefully, my discovery will work the next time I experience the same problem. If not, it's going in the garbage!!!
Posted on Jun 05, 2008
20YrsCompExp
  • 227 Answers
SOURCE: Cannot open file - "Unexpected File Format"
Does the program allow for "auto back Up?" if so I would look in the folder of the original file and look for one closely named but probably with a different extension, if it exists rename it a different name than the original and with the proper extension. then try it. If not you have probably lost your work due to improper closing of the file when your computer crashed. You could try the manufactures web site and look for a corrupt file recovery tool of some sort. Sorry I could not help more.
Posted on Apr 03, 2009
  • 3 Answers
SOURCE: Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Posted on Jul 08, 2009
Microsoft Project cannot open the file
1.Open the .mpp file in Microsoft Project 4.x.
2.On the File menu, click Save As.
3.In the File name box, type the file name that you want to save.
4.In the Save as type list, click MPX(4.0).
5.Click Save.
Files in MPX 4.0 format can be opened directly in either Microsoft Project 98 or in Microsoft Project 2000.
If you are still experiencing the issue you can try Project Fix Toolbox https://www.fixtoolbox.com/projectfix.html
Oct 29, 2015 | Microsoft PROJECT Computers & Internet
Tip
How To Save Photos From Facebook On iPhone
iPhone has a great facebook application which is so nicely designed to cater all the needs to browse facebook on iphone, but still one of the feature which lacks in iphone facebook application is that it does not allow you to save facebook album photos or any other photo you view on facebook.
In such a case you might want to download, save a facebook photo on your iphone but you can't through the facebook application, another way to do it is to open facebook in safari browser and locate that photo and touch your finger for 2-3 seconds on the photo opened you will see the option to save the image.
Follow the step by step visual procedure to do it.
1. Open facebook un safari browser by typing the address facebook.com or touch.facebook.com
2. Now open the image which you want to save and touch your finger over the image for 2-3 seconds you will get the option to save the image on your iphone as shown in the image below.
Similarly you can download the all the photos in a facebook, but there is no way to save the entire facebook photo album on iphone in one go, you will need to follow the procedure one by one for each image.
on Oct 27, 2010 | Cell Phones
Tip
<span style="text-decoration: underline;">iPhone</span> has a great <span style="text-decoration: underline;">Facebook</span> application which is so nicely designed to cater all the needs to browse facebook on iphone, but still one of the feature which lacks in iphone facebook application is that it does not allow you to save facebook album photos or any other photo you view on facebook. <br /> In such a case you might want to download, save a facebook photo on your iphone but you can't through the facebook application, another way to do it is to open facebook in safari browser and locate that photo and touch your finger for 2-3 seconds on the photo opened you will see the option to save the image. <br /><br /> <span style="font-weight: bold;">Follow the step by step visual procedure to do it. </span><br /><br /> <span></span> <br />1. Open facebook un safari browser by typing the address facebook.com or touch.facebook.com<br /><br />2. Now open the image which you want to save and touch your finger over the image for 2-3 seconds you will get the option to save the image on your iphone as shown in the image below.<br /><br />Similarly you can download the all the photos in a facebook, but there is no way to save the entire facebook photo album on iphone in one go, you will need to follow the procedure one by one for each image. <br />
on Oct 27, 2010 | Apple iPhone 3G Black Smartphone
I am using Magix Video Easy HD. I was busy
sometimes the file just doesn't get saved as it may be to be big.
But to resolve this:
save it;
go to the location you've saved it in;
check if it's there;
open it( if you want).
You may try looking it up using Search.
Nov 01, 2013 | Magix Video easy HD
Business card template with ten images have turned one image into design of my choice and now want to duplicate other 9 images with same thing thought copy and paste would work but it won't let me copy...
At home, we mostly use Printmaster for making greeting cards, but I'm guessing the procedure is similar. When you complete one design, select Finish Project, or similar. Then there's a menu option to Save the project. Give it a name, then Save.
Next, begin a new project, this time choosing the next image. This will prove to be a tedious effort, but you need to Finish and Save each one as a separate project. Of course, once it's done you can simply choose any one of them from your Open Saved Project list and quickly make any needed changes, then print.
Nov 27, 2017 | Broderbund PrintMaster Platinum for PC
I cannot open my saved pinnacle studio 14 project because i have upgraded my os (windows xp to windows 7) please help.
New project stated in Pinnacle14 Ultimate. I have windows vista:
My project contained 900images. I burned to a dvd, all went well.
Next day, I opened the project and 3/4 of it was missing ! I alway's
save the projects after editing. This project has taken several months.. It is to be viewed next week at a grad party. Please, I need your help.
Thank you
gl
May 16, 2010 | Computers & Internet
Dragon software
Forget about soundwave, I don't know if it saves 16 bit Wav or mp3.use Wavelab it is easier just open the files and do save as and chose format 16 bit. You can do the same with soundforge.
Whatever software you use , you use just (File button on top left)command open and save as or export, and when saving you set 16 bit wav. It is not to difficult.
Some of this software has many feature use solo basic file open save as or export
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
Failed creating file
I had to re-do the project, this time using Standard Quality rather than High Quality, and it completed creating the file(s) and writing the DVD.
Bernie
Mar 26, 2008 | Panasonic Palmcorder SDR-H18 Camcorder
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
FL Studio 6 Troubleshooting
It means that a sound or plugin that you saved with the file was corrupt, so you will have to scrap the project and start over.
Sep 07, 2006 | Image Line FL Studio 5 Producer Edition
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
