Asko WM33 Theh front door won't open
  • 566 Answers
Hi if the timer is on off/finished cycle and door wo'nt open? it may well be the micro switch that is stuck this is the time delay that prevents you from opening door till light goes off ?? it is not uncommon and part is obtainable if you wish diy? by removal of rear panel then the top panel to gain access to door latch/lock attached to inside of front panel you could try tripping plunger back to release door lock first then replace this switch just for info i have removed and found the switch plunger stuck with grit/grease and cleaned it with electical cleaning spray then refitted and prob rectified but your choice ?? hope this helps
Posted on Oct 22, 2008
How to fix a cold water tap that will no turn ff during cycle on Asko front loading WM33
Inlet solenoid is faulty & will need to be replaced by licensed service center.
Aug 30, 2014 | Asko Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
Dec 10, 2011 | Asko W6021 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko front load washing machine
Try some WD40 on the door mech,(on door, ie.) And with switch off, close & open door 4 or 5 times.
May 09, 2008 | Asko W6021 Front Load Washer
Asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Mar 06, 2008 | Asko W6021 Front Load Washer
Asko W6021 front load washer door stuck! If any one can help me please do thanks, Dwayne.
there is a little red loop that you can pull on to release the door manually. it is located behind the little door on the lower left of the machine. Pop that door open and take the phillips head screw out of the lever hen pull on it and the door will open.
Oct 24, 2006 | Asko W6021 Front Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
