Question about Smeg Kitchen Ranges
Smeg induction cooktop error F9
Flashing F9 on all three hotplates
4 Suggested Answers
SOURCE: Electrolux Induction Cooktop: My husband
Power down, then back up. You will be lucky if that fixes it though. I had the same problem here. It is in-warranty so I called Electrolux. Parts came in only after requesting them multiple times. Repairman put them in and they were bad. After a month it is still broken. I was promised a new unit, but little real action. Electrolux is a horror. No way to DIY this thing, too complicated. Cut your losses and buy another brand.
Posted on Aug 11, 2008
CMV9
  • 594 Answers
SOURCE: what does error code 35
it has a fatal or error condition. try turning the power off and than back so it the cook top can reset it's self. if that does not work you will need to contact sears for service.
Posted on Aug 23, 2008
jyackle5
  • 8197 Answers
SOURCE: Error code GE induction cooktop
Display flashing “E” alone (no other letter)
A hardware error has occurred.Call for service.
Posted on Dec 17, 2008
SH OR 5H error code on my smeg induction and no heat
I have the same problem and can't fix IT!
did You Solve the problem?
Dec 01, 2016 | Smeg Cooktops
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
Smeg induction hob error
Hi There
Using the 'Google' search engine, type in www.smeguk.comand you will find the answer to your problem , there are sections of 'trouble shooting' and various other problem solving solutions. Also you can contact them direct through their website if you still cannot find a solution to your problem and they will be only too pleased to give you free advice.
  • Add a Product
  • Apr 13, 2014 | Cooktops
    Induction hob not heating up. What does 5h or SH error code indicate?
    if they are not steel bottomed pans they will not work with induction hob test them with a magnet
    Apr 07, 2013 | Smeg Cooktops
    Error message on my electrolux INDUCTION STOVE TOP
    Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
    Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
    Instruction Manual for Smeg SIHP274S Induction cooktop
    go to www. fitness.manualsonline.com or www. retrevo.com
    God bless you
    May 14, 2012 | Smeg Cooktops
    I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
    The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
    if you also get a F9-4 that would mean its just the lower oven
    a F9-5 would be just the upper oven
    but for the F9-3 it could be either oven
    Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
    A maytag Gemini everything is working but it is flashing an F9-5 code and sometimes it throws a F9-6 any ideas on what to do????
    Hi twiztedminds,
    The F9:-5 / F9:-6 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
    Hope it helps.
    Thank you for using FixYa.
    (Positive feedback will be greatly appreciated.)
    Aug 09, 2011 | Maytag MER6772 Gemini Electric Kitchen...
    I have a GECE7006 induction cooktop and next to the timer button it is flashing "Lo" and i cannot clear it to use any of the hotplates?
    Remove the main power for about few hours and then plug the unit while you press the Start/Stop button. If the panel still blinks around, check for any traces of moisture on the panel. if so dry and check. If not the processor is having some errors which needs to be checked from within and requires Tech help.
    May 19, 2011 | Baumatic Microwave Ovens
    Kitchen Ranges Logo
    79 people viewed this question
    Top Smeg Kitchen Ranges Experts
    ashburton
    Joseph Mueller
    Joseph Mueller
    Your Consultant
    Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
