Question about Air Tools & Compressors
My dodge durango 2003 is giving me a cylinder misfire on a computer readout
I ran a diagnostic check and the reading it gave was misfiring in one of the cylinders my o2 sensors need to be replaced
    Problem Solver:
  • 6 Answers
O2 sensors can be very easy to get to, and some can be awful to get to, my advise is begin at the exhaust manifold and follow the exhaust pipe all the way until you get to the first (maybe only) O2 sensor, if it seems easy to get to then go for it, they make a special ratchet attachment just for 02 sensors but typically you can get them with a wrench, this will probably fix you misfire, o2 sensors can cause some funky things to happen.
Posted on Feb 08, 2012
Multiple cylinder misfires cause engine to die out unless gas pedal is pressed. Will not idle
the fuel smell is from unburnt fuel in the cylinders not firing , i'd have to start with reading the OBD codes to help narrow down the component/s at fault but at a guess i'd think the ign coils are at fault but the OBD will pinpoint the issue
Oct 08, 2014 | 2002 Dodge Durango
2000 dodge durango
Same cylinder all the time? What brand of spark plug did you put in? Have you cleaned injector connection? If spark plug and wires are known good, injector and connection would be next. Did you erase code after other work done?
Jun 10, 2013 | Dodge Durango Cars & Trucks
Dodge Durango engine knocking and check engine light
P0300 is a Random Misfire
P0302 #2 Cylinder Misfire
U1120 The code U1120 means, lost wheel distance message. The powertrain control module(PCM) is not
receiving a signal from the anti-lock brake module. The problem could be a short in the bus circuit,
the PCM or the anti-lock brake module. This type of problem is best diagnosed by the dealer or a
local shop with the proper diagnostic scanning equipment. Hope this helps.
Apr 14, 2013 | 2004 Dodge Durango
I have a 2003 dodge durango 4.7 and it is overheating which i already r&r the thermostat. fixed the problem a lil but not 100%. also check engine light turned on for second time both same code P0308...
yes... overheating can cause issues in your piston/cylinder head. if your cylinder head is made from aluminum and not metal, overheating can cause cracks and bends in your cylinder head. if this cracks occur inside the combustion chamber, then proper compression cannot be attained. you need to rebore then resleeve your combustion chamber and change the pistons to fix this issue. this will also require resurfacing of cylinder head to ensure that it does not create leaks against crankcase.
Aug 05, 2011 | 2003 Dodge Durango
Engine yellow light is flashing and engine is not running smoothly
Hi It sounds like the engine management system has detected a fault. I`m assuming its a petrol engine and the most common problem is one of the coils has gone.
To find the exact fault the car needs to have a diagnostic check which will tell you which coil or other component has malfunctioned.
Good luck i`m sure it won`t be a big problem
John ( South Wales UK )
May 01, 2011 | 2004 Volkswagen Passat
Oo dodge durango is flashing codes p0201,p0207,p0300,p0301,p0307 what is this telling me that needs to be fixed
P0201?? Injector #1 Ctrl Circ /
P0207 Injector #7 Ctrl Circ /
P0300?? Multiple Cylinder Misfire
P0301?? Cylinder #1 Misfire
P0307?? Cylinder #7 Misfire
are the codes start with the basics inspect plugs wires cap rotor and if all checks out do a compression test
Dec 31, 2010 | 2000 Dodge Durango
Have 2005 lincoln aviator - has miss at 30-55 MPH - no codes replaced all coils ( ford) & spark plugs (twice) - repair vacuum leak at PCV Still misses -- no codes -- help
The COPS (coils) may have shorted the drivers in the PCM (computer). You should get a misfire code for each cylinder misfiring though.
Slim possibility, but very expensive unless you have a service contract.
LINCOLN: 1999-2004 Navigator
2002-2003 Blackwood
2003-2005 Aviator MERCURY: 2003-2004 Marauder
ISSUE: Some 1999-2004 Navigator, 2002-2003 Blackwood, 2003-2005 Aviator, 2003-2004 Marauder and 2003-2004 Mustang vehicles built before 12/19/2004 equipped with 4.6L 4V/5.4 4V engine may exhibit a runs rough, lacks power, and engine misfire, prompted by a MIL light and DTC codes P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, and P0316.
ACTION: Diagnose engine for engine misfire concern. If diagnostics determine an engine misfire which is characterized by leakage through exhaust valve(s), only replace the affected cylinder head(s).
SERVICE PROCEDURE FOR VEHICLES WITH RUNS ROUGH/MISFIRE CONDITION:
  1. Perform relative compression check on all cylinders. If abnormal, check cylinder leakage and actual compression for "low" cylinders refer to Workshop Manual (WSM), Section 303-00.
  2. If leakage/compression check indicates a valve train concern, per valve train diagnostics in WSM, Section 303-00, replace cylinder head and cam assembly, pipe plugs and timing chain tensioner, per procedure outlined in WSM, Section 303-01.
  3. If cylinder leakage and compression tests are inconclusive, perform misfire diagnostic, per TSB 05-22-8. NOTE: DO NOT TRANSFER SPARK PLUGS. INSTALL NEW SPARK PLUGS IN REPLACEMENT CYLINDER HEAD AND CAM ASSEMBLY. NOTE: THE ENGINE MISFIRE CONCERN IS TYPICALLY EXHIBITED ON THE LEFT HAND CYLINDER HEAD AND RARELY ON THE RIGHT HAND CYLINDER HEAD. UNLESS CONFIRMED, THE RIGHT HAND CYLINDER HEAD SHOULD NOT BE REPLACED AS AN "EXTRA MEASURE" SERVICE PRECAUTION. NOTE: THE REPLACEMENT CYLINDER HEAD WILL NOT IMPROVE OR REDUCE ENGINE HORSEPOWER OR TORQUE ABOVE ADVERTISED LEVELS.
Sep 24, 2010 | 2003 Lincoln Aviator
2005 Dodge Durango
The p0300 What does that mean? Basically this means that the the car's computer has detected that not all of the engien's cylinders are firing properly.
A P0300 OBD DTC code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-
The p0430 What does that mean? Basically this means that the O2
downstream of the catalytic converter on bank 2 is detecting that the converter is not working as efficiently as it should be (according to specs). It is part of the vehicle emissions
system.
Apr 26, 2009 | 2005 Dodge Durango
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
