Question about Dell Multifunction Colour Laser (1235cn) Printer
The printer says outer temp open cycle power - Dell Multifunction Colour Laser (1235cn) Printer
    Guru:
  • 887 Answers
Curtis,
Hi, thank you for contacting me. I will do my best to help you solve this problem. Could you please give me more information surrounding the issue and about your operating system. Too much information is better than too little. Here are a few details that would help:
Try turning off the printer and disconnecting it from the power source for about 5 minutes (physically unplug it). If the problem persists when power is restored to the unit. Please let me know.
When requesting technical assistance, remember to give as much information as you can about the problem. Explain the situation leading up to the problem and the current status. The information given appears to be incomplete.
I hope thie helps
Randy
Posted on Feb 09, 2012
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
Benq sp 840 the temp led is on. What to do?
Hello, when temp led is on it is a way to protect the unit from overheating, Inside the PJ there are several fans (usually3-4) to cool down the temp of the power board, lamp , dlp chip etc. First do visual inspection of outer visible fans , maybe some are stuck. Then you can try using vacuum cleaner to clear the dust inside. If this don't help deeper cleaning is needed with opening the unit. If yuo are not familiar with electronics and due to risk of electric shock, please do not open the unit by yourself, and visit proper service center.
Of course upper suggestion is only the one of common cause for described problem.
Hope this helps.
Oct 20, 2014 | BenQ SP840 4000 ANSI Lumen 1080p Full HD...
How to reset fuser unit in printer hp laserjet 4250
turn the printer off for at least 20 minutes, then cycle power. If the 50.2 fuser error occurs again, you may need to replace the entire fuser assembly OR you will need to replace the power supply.
Dec 24, 2012 | HP LaserJet 4250n Printer
Samsung ML3051N open heat error cycle power
check the fuser assy thermostate , if pressor roller melt then change the fuser assy
Feb 19, 2011 | Samsung ML-3051N Laser Printer
I got error outer temp open cycle power what can I do to fix it
Have you had the front door off the machine. It's a bit fiddly, but this error can happen if the cable connector next to the left hand hinge isn't plugged in properly.
Dec 28, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Half way (circa 1hr) through the baking cycle "error 01" appears on the progress window. Any suggestions as to what's causing the malfunction ?
This is what i have been told i called and also looked up online to find that the error 1 code means
Magnetron (1) Failure:
Test magnetron (1) and Blower fan motor
Magnetron (1), (2) Failure: Test magnetron (1), (2).
Check blower fan motor and ventilation opening.
This is what the man told me to do to check the problems
(He also wanted to make certain i was a repair specialist which i am not) but this is what i got out of him
1. Disconnect the power supply cord, and then remove outer case.
2. Open the door and block it open.
3. Discharge two high voltage capacitors.
4. A continuity check across the temperature fuse terminals should indicate a closed circuit unless the
temperature of the temperature fuse reaches specfied temperature as shown below.
5. Reconnect all leads removed from components during testing.
6. Reinstall the outer case (cabinet).
7. Reconnect the power supply cord after the outer case is installed.
8. Run the oven and check all functions.
Hope this help you out.
Apr 26, 2010 | Microwave Ovens
Led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
Soap dispenser does not open during cycle
Had similar problem. Water was not hot enough. Check your manual for proper water temp.
May 29, 2009 | GE Dishwashers
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
Dell Multifunction Colour Laser (1235cn) Printer Logo
106 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
