Question about Sony KP-57WS500 57" Rear Projection Television
I only see red blue and green on my Tv
When ever i turn on my Tv i get a color echo a sort of green red blue color only and everything is shown as if their over laped.
    Problem Solver:
  • 10 Answers
Repkace your convergence units that should do the trick cost is about 50- 75 dollars
Posted on Oct 23, 2008
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Color in tv is very green you cant tell what suppose to be what i was watching cartoons with kids and the animal that suppose to be red was black i tried adjusting color temp and every thing even resetting...
If your using a tuner for your TV channels and you are using component video cables make sure that the red cable is not plugged into the audio socket. red blue and green cables should all be plugged into the "component" input on the tv not audio.
Dec 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Trying to hook up the dvd player to the tv and I figured out how to get the color back on but the sound is terrible it sounds like its echoing. Can't figure out the blue green red combination for white red...
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Aug 24, 2009 | Philips Televison & Video
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
Color Problem
prob bad crt. blue gun weak. new tv is answer.
Nov 17, 2008 | Zenith B25A74R 25" TV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
Missing colors on screen
if you have H/D one of your cables might be loose red/green/blue  i suspact red
Oct 21, 2007 | Toshiba 32WLT58 32 in. LCD Television
Everything in picture on television are green
The basic colors in the TV is RGB & each color has a diff amplitude & frequenc. It seems that the IC controlling the RED & BLUE has lost some of it's capabilities due to lower voltage supplied/regulated by the chip, which generally happens after quite long period of usage. However this seems an inherent fault with visio & most of the early sets do not have this problem sorted out at the manufacturing level & is a problem for most of TV's which are unpredictable & could occur in a month or year. If still under warranty, pressurize your dealer/distributor/service center to sort it pronto or ........... face the consequence..........sodeep
Sep 23, 2007 | Televison & Video
Sony KP-57WS500 57" Rear Projection Television Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
