Question about Boston Acoustics Horizon Solo Clock Radio
I have a Boston Solo 2 Clock Radio which has gone dead. Working fine, I unplugged it & thereafter not working. Could it be a fuse or something simple, how do I check?
Did you find a solution with that problem, other than throwing it in the garbage that is?
Posted on Sep 09, 2013
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
Dear Support, I have a Boston Horizon Trio Radio. The screeen remain blocked with the word "BOSTON" the buttons dont work. I have tried to plug the service cable to my PC, but nothing. Please, can you help...
Hi Roberto, I have the same problem after not using the Trio for about 2 month while it was unplugged. BA told me to unplug for 48 hours - of course this didn't help. Have you found a solution?
Oct 06, 2013 | Boston Acoustics Horizon Trio Clock Radio
How can I find the product manual for the Horizon Solo Clock Radio?
Here you go buddy:
http://www.abt.com/images/products/PDF_Files/hsolomdnt_use.pdf
Nov 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
My boston microsystem cd has stopped working. There's power, but nothing else. No clock, no sound nothing. Any troubleshooting suggestions?
I contacted Boston acoustics. I was told this is an intermittent problem with some units (mine is date april 2007). They say the radio will recover if kept unplug for 5 days. This is the time it takes for a huge capacitor on the main PC to discharge completely. They say a firmware upgrade can solve the problem.
So the idea is to leave it unplu for 5 days, plug it back and it should turn on again. I'm at day 3 and hpoing for the best.
Aug 28, 2009 | Boston Acoustics MicroSystem CD High...
Replaced fuses in my 06 Matrix. Radio and clock are still dead.
The 15 amp dome fuse is in the fuse box under the hood and the 15 amp CIG fuse is in the lower finish panel up under the dash on the drivers side. These are needed for the radio. The above fuses and also the 15 amp Gauge fuse in the box with the dome fuse under the hood are needed for the clock.
So...since both are dead it is likely to be 1 of the first 2 fuses mentioned.
Jul 23, 2009 | 2005 Toyota Matrix
Safe light boston gt 20 amp
First,check the output functions of your radio.
Then test the power lead for 12+ volts and ground at the amp, also be sure the "turn-on/remote power" lead from the radio is supplying 12+ volts when the radio is turned on.
Good luck...
Feb 22, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Volume won't go past 30
Turn on. Set volume to 00. Press & hold the volume knob for about 10 sec., until you hear a beep. Then turn volume up to the maximum that you would ever want, and then press the volume button again. It is now set.
Feb 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
Moisture in amp while on, caused a small pop, then no sound outpu
check the fuse between the battery and the amp. (not the fuse in the back of the amp).
if that doesn't work then something on the inside of the amp is fried.
Jan 30, 2009 | Phoenix Gold Xenon-200.4 Car Audio...
Boston Acoustics Horizon Solo Clock Radio Logo
654 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
