Question about Craftsman Air Tools & Compressors
Can my 240 volt compressor run on 208 volts?
  • Craftsman Master
  • 885 Answers
Being an Authorized Service Center for a couple air compressor companies I can tell you I have replaced several 240 volt motors because they were run on 208 volts. Not knowing what model you have or what motor is on it, yes your compressor will run on 208 volts but it is very ******* the motor. At startup, all voltages have a dropoff then come back up to their rated voltage. The dropoff is determined by the original voltage and length and guage of lines getting the power from your transformer to the compressor With 208 volts it typically drops to around 190 volts at startup then comes back up to 205 to 208 volts while running. The motor needs the full 240 volts when it restarts and there is already pressure in the tank If the motor's not marked, call the manufacturer and see if it's rated for up to 240 volts or only for 240 volts.
Posted on Feb 09, 2012
  • 150 Answers
SOURCE: need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Posted on Mar 29, 2009
SOURCE: what size line should i run to a 60 gallon air
You need to up size your wire. According to one site I pulled up on the Intranet and input your information, which was 208VAC, 15 AMP and 375 feet it said you need #6 AWG wire.
Posted on Nov 02, 2009
dmftrucker
  • 1922 Answers
SOURCE: why did my craftsman 5 hp 240 volt 125 psi air
your motor overheated from too low a voltage if theres a manual reset try this,also replace the two motor start and run capacitors on the motor body
Posted on Dec 24, 2009
mxc2
  • 146 Answers
SOURCE: I AM SETTING MY AIR COMPRESSOR FROM 240 VOLT TO
You have to change the wires in the motor according to the wiring diagram on the motor before you can convert the motor to 120 Volt.
The standard colors you should use would be black and white for line and load and green for ground. If you just have a copper wire and it is not coated with a green coating then you will use the standard copper wire for ground.
Posted on Sep 28, 2010
  • 1383 Answers
SOURCE: We've purchased a Kobalt 60 Gallon, Volt 208-240,
Your compressor is designed to be used in a shop situation (not portable) and is usually wired to a switch box similar to how your central air condenser is wired. It can however be wired with a short cord to a 220v plug. Your compressor motor is most likely wired to the pressure switch so all that you need do is to connect your pigtail from the pressure switch to the wall. You can buy all the parts that you will need at Lowes. You will notice that your motor has two wires going thru the contacts of the pressure switch. The inside cover of the switch will clue you in to wiring but if it does not have an illustration just match the black to black and white to white (110 v lines) and green to the ground screw at the pressure switch. Here is a good web site for another view: http://www.ehow.com/how_5041165_wire-air-compressor.html
Posted on Nov 05, 2010
Imperial icve-1 standard depth 208/240 volt connextion help
Are you in the EU or US and can you be more specific, it is fairly straight forward. If in doubt get a professional to connect it for you.
Apr 10, 2014 | Imperial ICV-1 Turbo-Flow Single Oven
Whats the voltage on a frigidaire Crown Dryer Model #FDEB23RGS1?
that depending where your at
in England/Canada its going to 208 volts
in the USA it will 240 volts
in other parts of the world it could be somewhere between 208 to 240 depending on what the standard is in that country
Sep 30, 2011 | Frigidaire Electric Dryer
LP126HD3A rated for 265 volts AC single phase I have 240V ac single phase, how can I use this unit on 240V ac
You'd need to supply a "Buck-Boost" transformer to do this properly. Technically, the 265 VAC is one hot leg and neutral of a 480 VAC 3 Phase Y system that measures 277 VAC. The 265 number comes from this:
265 is the standard nameplate voltage for a 277 volt motor or AC unit.
230 is standard name plate for 240.
200 is standard name plate for 208
460 is standard name plate for 480.
110 is standard name plate for 120.
Most electricians call the hot leg / neutral circuit "277V AC".
Some popular "Buck-Boost" transformers will convert 208 to 240 and 240 to 208 volt systems, and 240 to 277 and 277 to 240 volt systems - among many other variations. These are auto-transformers as the primary secondary windings share a connection. KVA ratings differ significantly from name plate because of this fact. You should contact a qualified electrician to not only size, but wire the transformer for you. Failure to install a Buck-Boost transformer - and running this unit on 240V AC mains will cause premature failure of motors - fans and compressor due to overheating. This can also result in a fire hazard.
I hope this helps and good luck!
Sep 06, 2011 | LG LP126HD3A Air Conditioner
I need to know the power requirements for this piece of equipment. Single or 3 phase, voltage, amps etc.
It is single phase. Either 208 volts 3240 watts or 240 volts 4316 watts. Unfortunately, its difficult to know which one you have. It can be ordered either way. Here's the deal, For no apparent reason, some buildings have 208 volts, some have 240 volts. If you know when you buy new equipment, you specify which voltage you have. So if your building has 208 volts and the machine is 240, it will still work, maybe a little slower to heat up. If it is the other way around, your building has 240 volts and the machine has 208 elements, it will heat up much faster, but the life of the elements is drastacally reduced becuse they burn out much quicker. You can call Lang at 314 781 2777 ask for technical assistance and they may have a way to find the voltage if the tag is missing.
Oct 19, 2010 | Lang Manufacturing PB-24-S
How to install a 208v outlet for a stove
if its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Nov 14, 2009 | General Electric Profile PP945 30 in....
Craftsman air compressor is hums but the compressor will not fire up
IF THE COMPRESSOR IS 208/ 230/ 240 VOLTS CHECK THE VOLTAGE FROM HOT TO GROUND AND MAKE SURE YOU HAVE BOTH LEGS COMMING IN ARE HOT. IF SINGLE PHASE 120 YOU MIGHT WANT TO CHECK THE CAPACITOR IF IT IS CAPCITOR START
Sep 27, 2009 | Craftsman Air Tools & Compressors
New motor for Coleman Powermate 60 gallon compressor
Hi there and first and foremost, just want to say Thank you for your service.
Generally for larger air compressors, the factory motor is designed to do the correct amount of work to power everything. Your wanted to step down from 240 volt motor to a 120 volt motor will probably not work. Let me explain why.
The factory 240 volt motor is going to produce more torque. It would be Tough to find a 120volt motor to match that amount of torque. The compressor or piston pump that the motor powers, requires a certain amount of torque, and speed. If you can dig in and find the compressor pump it should state right on the housing the required power to operate efficiently.
Another possible issue with going with a smaller motor is Shaft size. The 240 volt motor will tend to have a large shaft diameter then a 120.
I hope this helps, although a smaller motor would save you money on your electric bills, it just simply wont get the job done.
Aug 07, 2009 | Coleman Powermate 60 Gallon Air Compressor
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Air Tools & Compressors Logo
274 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
