Question about Kodak EasyShare Z700 Digital Camera
Shutter flops down and wont stay up
Shutter was forced open while closed (turned off), so the top half of the shutter drops down to cover half the lens and the bottom one stays down in the camera.
The shutters are floppy if you push it up to take a photo it drops down as if there is nothing to hold it there (no spring feeling).
The battery goes flat as if the camera has been left on - but the camera is turned off.
  • Tony Parsons
    Tony Parsons Jul 28, 2017
    That is not actually the shutter, merely the lens cover - the shutter on most cameras resides near the focal plane. I fear that repair would cost more than replacement.
  • 67 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
Tapp the lense GENTLY in the opposite direction of the misalignment
Posted on Dec 10, 2007
  • 8 Answers
SOURCE: lens stuck out; camera won't stay on
I have the same problem. Its actually because the On/Off button got pushed in somehow and its stuck. At this time right now, im not sure how to make it unstuck, but sometimes it will stay on. But when you push on, since its being held down, its stuck that way and immediately turns off because its still being held down constantly. Maybe try using a thing needle to try and push it out?
Posted on Nov 16, 2008
  • 1901 Answers
SOURCE: How do I set a shutter delay on a cx4230 camera?
It is easiest to link you to your camera manual.
Click on:
Kodak CX4230 Manual
Go to page 20 in the manual for instructions.
While you have it open, save a copy to your computer for future reference.
Here it is if you don't want to do that:
In Capture mode, press the Menu button.
Highlight Self Timer , then press the Select button.
Highlight On, then press the Select button.
Press the Menu button to turn off the menu screen.
Place the camera on a flat surface or use a tripod.
Press the shutter button completely down to take the picture.
The red Self Timer light turns on for 8 seconds, then blinks for 2 seconds. The picture is taken.
Posted on Dec 24, 2008
  • 50 Answers
SOURCE: lens shutter one side is loose and flops
the only place i've ever seen that fixes small digital cameras like that is portatronics, but it's a mail-in business.
Posted on Apr 22, 2009
  • 3 Answers
SOURCE: Lens 'shutter' problem.
have you changed your batteries do you have a warranty if you do take it back
Posted on May 07, 2009
How do you open the left cover to remove a jam
open the front cover, pull the handle on the left door,see if paper has jammed between the rollers,remove the paper by turning green knob in the left front side. close the covers.if jam is not recovered follow the steps given below;
1, check if the sensor arm spring is detached (sensor is under side of fixing unit behind the left cover )
2, set the sensor spring correct take care not to overtighten the spring.
3, apply some rubber based adhesive to both spring ends so that it wont come out again.
close the doors and check.
Feb 06, 2011 | Canon ImageRUNNER 330s Copier
Its shutter is not opening
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 18, 2009 | Canon Cameras
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Help with "B" setting
You press the shutter once and that opens the shutter (you do your light painting) then you press the shutter a second time to close the shutter.
When you press the shutter the first time and look in the view finder it will be dark . this is because the mirror has locked its self up while doing the exposure (this is normal) Once you click the shutter a second time the mirror will flop down and you will be able to see threw the viewfinder again.
Jan 24, 2009 | Canon EOS-AE-1 35mm SLR Camera
Shutter issue
I experienced the same problem and took the camera in for repair - I was told the problem was with the motor on the zoom drive which had to be replaced. The shutter cover has worked fine ever since. Repair cost was about $150
Oct 05, 2008 | Pentax Optio 50 Digital Camera
Shutter problems
I am having a similar problem with my eos 100QD.
shutter opens, then stays open until I depress the shutter switch again.
Sometimes about half my photos are lost on a roll, but the other photos are fine (as would be expected from how the film is wound). This problem looks like it's caused by the shutter mechanism failing, a common problem with older camera and one that is often more expensive to repair than it is to replace the body.
May 25, 2008 | Canon EOS Rebel GII with 35-80 lens 35mm...
Outside shutter cover will not open
The only thing I can recommend is to manually push the cover open. But, it will probably stay that way, and not close.
Mar 12, 2008 | Olympus Stylus Verve / ?-mini Digital...
Shutter closed
Any small distortion to the case will jam the dust shutter mechanism, as will dislodged dust and dirt. Remove the battery and carefuly remove the case screws. DO NOT LOSE. Lift off the front cover, take care with the top control knob and on/off switch as there are dust shields that may tear. This reveals the dust cover mechanism on the front of the camera. Dust off with an air-duster or soft spotlessly clean (new) paintbrush. Check a narrow ribbon cable is plugged-in at the front as this powers the cover motor. Gently guide the case around the top rotary control & on-off switch and line-up the circuit board beneath the rotary switch. Do not force anything together. Lightly re-assemble without screws and insert the battery - you cannot make this test without the cover-on as the case supports the switches needed to control the camera. Check that the cover operates correctly or is jamming on the case cover at the front where the shutter moves. If all OK replace the screws, else gently straighten the case with your fingers. This has happened several times to mine and cleaning it/lightly straightening the case cover always make it work again.
Jan 30, 2008 | Fuji MX-1700 Zoom Digital Camera
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Kodak EasyShare Z700 Digital Camera Logo
32 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
