How to config my EDUP ADSL Modem Router (EP-DL520G)
My service provider says I need to config my modem to get a connection to the ISP how do I do this.
5 Suggested Answers
Al42
  • 72 Answers
SOURCE: Dual Routers?
Disable DHCP on the router and connect the modem to one of the router's LAN ports - that will give you 3 DHCP ports + wireless. If you need more than 3 ethernet ports, use a hub on one of them.
Posted on Apr 29, 2008
SOURCE: Configuring DLink Wifi router for Reliance broadband
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
Posted on Oct 20, 2008
SOURCE: Nokia siemens ADSL Modem c2110 USB Driver
Download it
http://rapidshare.com/files/78129093/DATAONE_SIEMENS_C2110_USB_DRIVER.rar.html
Posted on Oct 27, 2008
  • 3 Answers
SOURCE: ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Posted on Dec 06, 2008
I have D-link 2750U (modem *** router). I am switching from BSNL to Hathway (ISP). Hathway does not supports ADSL. Suggest a work around!
ADSL modem/routers can only route from adsl line, no way you can use it as normal router, maybe ISP can provide you with its own modem router...
Apr 23, 2014 | D-Link Dir-835 Wireless N750 Db Router...
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Will comcast support Actiontec - ADSL Modem with 802.11g Wireless Router and 4-Port Ethernet Switch
Comcast will not support that kind of modem. Comcast is a Cable ISP thus the ADSL modem won't work with them because ADSL modem is for DSL providers. Cable Company uses different protocol than DSL. But Comcast will provide you the cable modem if you subscribe to them.
Oct 22, 2009 | Actiontec GT704WG Wireless Router...
If I have a wireless router do I still need a modem?
It is depend on which type of connection cable your internet service provider.
You don't need modem if in your router ADSL port and your ISP gives you ADSL but if on wi fi router there not dsl port and your ISP gives you dsl cable then you need modem.
Let me know if you need more assistanse.
Thanks.
Sep 11, 2009 | NetGear WGR614 Wireless Router
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
I want fast help..how to get connection between linksys router and aztech modem
first check..
Step 1:
Step 2:
Step 3:
Step 4:
Computers & Internet Logo
870 people viewed this question
David Payne
David Payne
