Question about Lenovo Computers & Internet
HOW DO I SWITCH MY NIGHT LIGHT ON THAT IS STATED ON KEY F3 AS I DO A LOT OF NIUGHT WORK ON MY COMPUTER
I WOULD LIKE TO USE MY NIGHT LIGHT BUT DO NT KNOW WHERE TO GET IT ON.ON KEY F3 THERE IS A HALFMOON SIMP;E BUT WHEN I TRY TO SWITCH IT ON IT DOES NOT ACTIVATE THE NIGHT LIGHT FOR MY KEYBOARD
  • 807 Answers
Try the holding the Fn and press PgUp (Page up)
Posted on Feb 08, 2012
2 Suggested Answers
SOURCE: How do I turn on the back light to the keyboard of
Hi.. Norman
i hv bought the same laptop ..earlier i was facing this problem at day time , it consumes battery.but at night it does excellent work.
Now talk abt ur problem...
1. to on/off it use "Fn" key given near window key(near left control)
2.use Fn+F4 key to dim or off light
as u can use Fn+F5 key
3. to perminant off
go to RUN+MSCONFIG+STARTUP
and disable ATK HOTKEY driver..
NOw i have problem with my laptop(asus UX50V)..
it came with VISTA but i installed WIN7 ultimate.
now i can't open my webcam.. I dont have DRIVER for it..
if u kno help me where should i download driver for it...
rply soon...
Posted on Aug 14, 2010
I need a computer Aires k3 user manual to download
Function Keys
Fn + Esc:4 levels backlit brightness adjustable,suitable for use days & nights
High light - Medium light - Respiration light - Extinguish (High brightness by default when starting up).
7 Multimedia Shortcut Keys: Stop, Fast forward, Rewind, Play/Pause, Volume-, Volume+, Mute
3 levels keyboard speed adjustable:
Fn+F1 : 21 byte per sec(80/S)
Fn+F2 : 30 byte per sec(60/S)
Fn+F3 : 63 byte per sec(40/S)
Fn Multimedia Combination Keys:
Fn + F4 Mute
Fn + F11 Lock/Unlock all keys
Fn + F12 Lock/Unlock Windows Key
FN + W : Switch WASD keys and Arrow keys.
Fn + Tab:3 colors adjustable backlit
Jan 28, 2017 | Audio Players & Recorders
I need a keyboard manual for an Aires K3 seven colour keyboard
Function Keys(for Aires 3 colour keyboard , so i'm guessing will be the same)
Fn + F4 Mute
I have an acer aspire 5552-5898 and i am unable to enable the wifi even after hitting FN+F3 to turn it on
From what I can find on your notebook it looks as though there may be a physical switch for your wireless as well. Be sure that this switch/button is turned on prior to using the Function F3 keys to turn on your wireless.
Dec 01, 2014 | Acer Aspire 5552 Laptop
What it does is when i turn the key it does'nt make a sound at all
would need to see it ,sorry but ford focus is showing for model and these earlier ones have a starter solonoid in the fuse board and its possible this has failed but dont ask me which one look in the manual and find it then test for current to the relay in case the switch on the back of the ignition lock has failed ,doesnt happen very often with the fords unlike a VW .But ? i have known the relay to fail on this model quite a few times .also check for the small wire that goes to starter motor ,its easy to do on a focus as the starter motor is at the front
Sep 22, 2017 | 2000 Ford Focus
Toshiba error F3-F100-0003
Maybe caused by damaged recovery media or faulty hard drive.To reinstall your laptop to the factory settings / "out of the box" settings, please follow these steps. It worked for me, and should work for you.
ALL DATA WILL BE ERASED ON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THE POWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURING THIS PROCESS.
1) Hold down the power button for 10 (ten) seconds to switch off your machine.
Please note: Holding down the power button on the machine forces it to switch off. Any unsaved data will be lost.
2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook.
3) When the machine Starts beeping; release the 0 key.
4) When prompted by the warning screen; select Yes to continue with the system recovery.
5) Select Recovery of Factory Default Software; click Next.
6) Select Recover to out-of-box state. Click Next again.
7) Click Next to Start recovery.
Apr 11, 2012 | Toshiba Satellite A205-S5880...
Lost power to 4x4 switch can,t get out of four wheel low.
I've seen this on one ford before. The guy was in 4x4 and the switch would not release it. We tested all the components and like you stated all was good. There just happen to be a code in the computer that really did nt suggest a cure for this. So we cleared the code and click, right away the switch worked. So try disconnecting the battery for about 15 minutes to get the computers to completely discharge and hopefully erase the code.. If this does nt work you may need a scanner to see if there is a code. The code in my case was in memory and no lights were on because of it.
Jul 18, 2009 | 1998 Ford F150 Regular Cab
Pci ide controller for third hard disk
You need to enter into scsi bios first, then do an autodetect for hard drive, this will set the IDE/SCSI hard drive on raid controller.
To enter SCSI control you need to press the same key stated on screen on startup (F6 I assume) I think F3 is just boot settings.
If the card do not enter regularly in CMOS settings for the raid then this card is defective.
Mar 28, 2009 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
Dim light on my sony vaio.
heres the solution! if ur fn + F5 key doesn't work...
1. go to start
2. go to control panel
3. click "power options" has a pic of a battery
4. click "change plan settings" under "balanced"
5. change "adjust display brightness"
May 23, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
