Question about Coffee Makers & Espresso Machines
I have a PROCOMBI 85 HE Boiler, the Hot Water runs warm for a short while then runs cold then warm again and keeps repeating this the boiler temp gauge ramps up to 80 then the boiler shuts down till it drops to 50 ish then fires back up and keeps repeating this, the boiler seems to do the same thing in heating mode but generally I have good heat in the house, ANY IDEAS ANYONE THANKS
  • 2039 Answers
SOURCE: Cleaning boiler
no descaler vinegar not strong enought go to hardware store ask for descaler 1part descaler 1part water put it in the water container activatemachine open valve for a few second wait repeat untill empty rinse very good cheer
Posted on Jan 28, 2008
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
  • 13 Answers
SOURCE: hi,i have a vaillant turbomax
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Posted on Mar 03, 2009
SOURCE: Gaggia Synchrony - we need a new boiler.
http://www.cafeparts.com/dynamicIndex.asp This site has parts.
Posted on Mar 27, 2009
gary1121
  • 332 Answers
SOURCE: Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Posted on Jun 10, 2009
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Tip
The extra benefit of a Modulating Boiler
You're looking to install a new hot water boiler or replace your existing boiler. You come across something called a "modulating" boiler. You wonder what on earth that means. I will attempt to explain some of the features of a modulating boiler.
How nice would it be if you could have your boiler make just enough heat to keep your house warm and nothing more? Your thermostat tells your boiler that you need heat in the house. The boiler starts up and heats the water that runs through the pipes to heat your house. The water does not heat up to temperatures that are more than just warm. But you notice that the temperature in your house is staying right where you want it to be.
This boiler is no ordinary boiler. It knows what the temperature is outside and varies your water temperature to make just the heat needed to keep you comfortable. The modulating boiler also runs much more then a normal boiler would but you can see by your gas bill that you are getting great efficiency from this thing.
The feature that makes this wonder so great is that it has the ability to vary the fire that heats the water up and down so that the water temperature stays precisely where the computer brain in the boiler wants it to be. This temperature is figured by measuring the outdoor temperature and changing the water temperature based on that. The colder the weather is outside, the hotter the water is going through your system.
With a system like this you will notice that your heat will run longer and still not cost anymore money. This makes you more comfortable. The modulating boiler will give you just enough heat to keep you warm without wasting much of the heat that a normal boiler would. This type of furnace will give you the most efficient heating possible on any given day.
Before buying a new heating system or replacing your old hot water boiler make sure that you check into a system that will modulate the fire and also vary your heating water temperatures according to the outdoor temperatures. This will save you money and give you a very comfortable heating system.
on Dec 08, 2009 | Heating & Cooling
Tip
Boiler Aquastat - How to set it
It is the coldest day of the year and your boiler is chugging along. However you notice that your house is slowly cooling off even though the boiler is running. Then you notice that the boiler is shutting down even though your house is not up to the thermostat temperature setting.
You look into the situation farther and notice that you boiler temperature is below say 180F. What is shutting the boiler off? The device that controls the temperature of your boiler is called an aquastat. This device senses the temperature of the water in your boiler, and then fires the burners to keep the water at the temperature call for by the aquastat.
The other role that this device may play is to keep the boiler from getting too hot and making steam. However for this time we will concentrate on the lower side and the heat of the water. If you have a house that has barely enough baseboard or radiators for that really cold day then you need your water to be very hot or around 200F. This will give the water enough BTU's to carry around the piping to give off to keep your house warm. The downside is that it also makes your boiler less efficient when it needs to heat the water this hot.
So, now you know that if you need more heat you can turn the aquastat up higher to get more heat and turn it lower on the milder days to save energy. Another way to do this is to buy and install a smart control that will do that automatically for you. These are called an outdoor reset control and will vary your boiler temperature according to the outdoor temperature, saving you money and keeping you warm all at the same time.
Now, the one thing you need to know yet. The aquastat is usually a gray box with a screw driver slot in a little wheel that has numbers on it. It is often hidden pretty well and may take some looking to find it. Some of the newer boilers may have a digital one that is in a bigger gray box. Read the instructions to learn to change the temperatures.
Setting your aquastat correctly can save a lot of money and it can be the difference between keeping you warm or not.
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
I HAVE A WATER ONLY BOILER MODEL WR11E IT IS ONLY 6 MONTHS OLD AND THE PROBLEM IS THE WATER IS ONLY LUKE WARM AND NOT HOT AS IT WAS BEFORE
Turn the boiler off. Connect a garden hose to the drain bib. Shut the water supply valve off.
Open the drain bib and drain boiler. Close drain bib and open supply valve.
When boiler is full, go to the farthest faucet and open the hot water and let run.
Go back to supply valve and turn off and on a couple of times rapidly this will "bounce" sediment loose.
Repeat above twice.
Nov 08, 2010 | Heating & Cooling
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Apr 24, 2009 | Combi Centre DX - Mango
Coffee Makers & Espresso Machines Logo
307 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
