Question about SMC Barricade g SMC2804WBR Wireless Router
Cant set up network password on my Mac using SMC 2804WBRP-G router..
Hello, im4mum2..I was looking into an issue i have with my SMC router and came across some useful help you provided another person with similar problems. I decided to try the 'guru' directly and see if you can help me with this little dilemma. As you probably know, SMC charges for the customer support and I really can't afford that..but neither can I allow everyone to keep sucking up my bandwidth because it's slowing my work down and posing a serious security threat.
Basically, I never password protected my network and it's been available to everyone for at least a couple years. The router is connected to my modem (TimeWarner) and MacBook which runs the most current operating system (OSX10.5.5). I've gone to the System Preferences; Network; Selected Airport, (clicked Advanced..); Selected SMC; double clicked and selected WPA Personal; put in new password then Saved....but it never seems to actually work and store the settings.
I'm not sure if I'm setting the password in the right place or what, but could really use some help.
Thanks in advance for your time.
Best
RAM
  • Anonymous Dec 10, 2008
    I hava same router SMC2804WBR and Macbook. Actually the problem is in OSX. When I updated my MacBook to OSX 10.5.2 I lost my wlan connection which used WPA Personal(with password).
    If I try to connecto using PC it wlan works fine but MacBook doesn't work. now I also use MacBook with OSx 10.5.5. and still cannoct connect to wlan if WPA is used.
    Unfortunately solution is to remowe WPA Protection from your wlan. After that my macbook can connect to wlan.
  • 611 Answers
Ya you can setup the password to router
at first you do go to router configure page in that adminster or mantenions will get in that password is there wirte your password old and new.
second if you want in wierless password then go to wirless in the enable siecurety some thing cilk it then wappsk/wap2psk that opption cilk then give the password then you get the proper secuty.
Posted on Dec 13, 2008
How do i set the password for my wireless and i using the SMC router now. Pls help, people are keep using my wireless and my internet keep disconnect .
Setting up a login password only protects your wireless router from someone changing your wireless settings.
To secure your wireless network from unauthotized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 21, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
How do I set up password protection for my SMC Barricade Turbo 2404WBR Router?
Please follow the steps mentioned below and check if the issue is resolved.
  • Please open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
  • The password would be either blank or smcadmin.
  • To enable Encryption or Secure the Wireless Network, follow these steps:In the router's configuration page: Click on Advanced Setup -> Wireless -> Encryption.
  • Select the Encryption type (WEP, WPA, WPA2 etc), type the Security Key and save the settings.(128-bit encryption uses 26 characters. Example: 01 2C 45 67 89 A0 CD EF 01 23 45 6D F9
    64-bit encryption uses 10 characters. Example:
    01 A3 45 F7 8)
  • The Wireless/Internet is Secured Now.
  • You can also set the password for the Router log in: Please click on Administrator settings and input the new password.
Good Luck!
Thank you for contacting.
Jul 07, 2010 | SMC Barricade Turbo Router
Cant load a web page on my mac even though the router works.
go to network preferance and creat a new location and try.Also reset the smc and pram followed by Apple webpage.This will solve your issue. Also try checking different browser.
Mar 18, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Smc setup cannot be accessed but have network
login to your router and go to wifi and check for the mac address of your laptop, if its require to change anything do it according to it.
To know the mac address of your laptop go to command prompt and type --> getmac
Mar 11, 2010 | SMC Barricade g SMCWBR14-G (662698582192)...
The default password isnt correct, cant log in. I reseted the device many times, and unpluged for hours/days but the default password still doesnt set back...so i cant use the device because with default...
According to SMC the default password which is case sensitive is: smcadmin you enter that into the SMC web interface found by typing 192.168.2.1 into Internet Explorer's address bar.
The full manual is here,a nd their support site is here
If this helped you then please help me and vote, thank you
Oct 12, 2009 | SMC Barricade SMC7004VBR (SMC7004VBR-CA)...
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Sep 18, 2009 | SMC (SMCWBR14-G2) Router
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Jun 22, 2009 | Computers & Internet
SMC Barricade g SMCWBR14-N Wireless Router... router Configure with Westell 327W
it seems that the router capability of both devices are conflicting with each other so below are the steps that you can try to setup the two devices to work with each other.
i assume that you are using pppoe connection from at&t and you are using a connection manager. if so, with the current setup that you have right, you need to disable the connection manager on your computer (network connection, disable at&t connection) and set the connection of your web browser to "never dial a connection". check now if you will be able to connect to the internet instead of being prompted for a password. if your problem is still the same, try the steps below.
configure the westell 327w the way it was before (when it works properly when hard wired to the computers but the wireless sucks) but disable the wireless capability. change now the ip address of the smc router from it's default (192.168.2.1) to an ip address which is on the same segment as the ip address of the westell 327w (ex. 192.168.1.2 if your westell 327w is using the ip address 192.168.1.1). disable the dhcp of the smc router (note:make sure that you have configured all the settings that you want to configure with the smc (i.e. wireless settings, port forwarding, etc). then connect the westell to one of the LAN ports of the smc (note: with this setup, the wan port of the smc should not be used) and power cycle everything and check if this setup will work.
hope this'll help you and just ask me if you have other concern.
ciao!
Oct 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
How do I configure my SMC Turbo router for a Cable Internet connection?
In the routers web-interface, click on login (password would be either 'blank' or 'smcadmin') -> Home network settings -> click on WAN settings -> Dynamic IP address -> more configuration -> click on clone MAC address and save the settings.
Feb 19, 2006 | SMC Barricade 7004 Router
Open Questions:
SMC Barricade g SMC2804WBR Wireless Router Logo
380 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
