Question about Toshiba 1370 Black and White Copier
Error code c412 for toshiba e-studio 720 copier
  • 990 Answers
SOURCE: what is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
didi2005
  • 524 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 990 Answers
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Posted on Jun 02, 2009
  • 92 Answers
SOURCE: Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Posted on Jun 28, 2009
didi2005
  • 524 Answers
SOURCE: toshiba e-studio 720 toner low message but bottle
If everything is OK, but the message is still appear, then u can clear it by following below steps:
User Function--> User--> General--> Toner Near Empty Detection -->Yes
Posted on Sep 17, 2009
Toshiba 720 error code 447
poor connection fuser drawer
go to this site to get error code listing
http://fyi.toshiba.com:81/KB/file_uploads/8535/TSB-1002.pdf
Jul 10, 2013 | Toshiba e-Studio 720 Copier
My toshiba copier720 error cf70 pls help me to solve this problem
That is a new toner motor abnormality. If memory serves there was a field mod released back when those were state of the art that dealt with that error code. Either way, sounds like you either have blown or about to blow your tonor motor. Time to holler at your nearest Toshiba Certified retailer.
Jan 16, 2013 | Toshiba E-STUDIO 720 Copier
''toshiba e-studio 720 displayed error code c473. How to solve this problem''
you can try switching the machine off hold in 0-8 till the machine beeps then push 400 start set the value to zero and enter reboot the machine and if doesnt6 work change the thermisters and check the thermastats
Aug 17, 2011 | Toshiba E-STUDIO 720 Copier
My photocopier (toshiba e-studio 720) can't start. When turn on power, on the screen i only see icon start. It can't not start. Tell me why and way to repair it, please Ngo Hieu.
how are you this is jack my id jack_pak@hotmail.com
Yor copier e-studio 720 can t' start,
Dear you press 0 and 8 key and on your copier other hand.
Then copier on then you press 690 and stars key.... copier screen show 2.... 2 then you press enter (on toch screen).
after some time copier screen show REBOTE THE MACHINE.
THEN torn off ... and simple on the copier ..
PLEASE VOTE ME
Best Regards,
Thanks,
Sep 05, 2010 | Toshiba E-STUDIO 720 Copier
E-STUDIO 720 Copier Gives me a error F105. What should i do? thanks
Hi:
You are having a Hard Drive issue. You should call in a qualified Toshiba tech at this point.
Andrew
Jun 14, 2010 | Toshiba E-STUDIO 720 Copier
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
E studio 720 error code c467, can you tell me how to clear this problem?
Hello sir; Hold down "0" &"8" while you turn on the power, enter 400 press "enter" or "interupt' key then turn power off and back on again.
Oct 14, 2009 | Toshiba E-Studio 161 Copier
Toshiba 1370 Black and White Copier Logo
260 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
pkwc
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
