Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Red Light (on) on my motherboard
Its right next to the video card. is this bad? also my monitor says "No Signal" could these problems be linked? my monitor is fine so im guessing something is wrong with the video card.
PLEASE HELP!!!! I've been stuck on this iMAC.. I NEED MY PC BACK!
  • 34 Answers
The red signal is for the motherboard which indicates it has powered on. It has nothing to do with the video card.
In the no signal problem, please make sure that the video card is firmly pressed on the its slot.
Detach and reattach your memory [RAM] or put it in a different slot right beside it.
Posted on Oct 27, 2008
Monitor screen is black but computer seems to work
That is not enough info, please provide more info so people can understand the issue better. For example, describe what you do and see step by step. When you turn on the machine, after a few seconds it powers on, it should run Power-On-Self-Test (POST) which will end with a beep telling you everything was OK. If you do not hear any beep, the problem is likely to be inside the case, bad video card, motherboard, CPU, etc. Typically bad RAM or Video card will cause a series of quick or long beeps (different for each motherboard) to indicate where the problem is. Bad CPU generally do not generate a beep code and most motherboards also do not give out a beep for motherboard issues, naturally.
If you hear that beep but see absolutely nothing on the screen from the moment you turn it on, then check to see if the status indicator light (assuming it has one) changes color or not:
A) If the light on the monitor changes from red/amber to blue/green but you see nothing on the screen then either the video resolution and/or refresh rate is unsupported, video drivers are faulty or monitor itself is bad.
B) If the light goes back to red/amber or stays that way from get-go, then there is no connection, monitor cable is loose at either end or bad/supported.
C) One other possibility would be the input selection on the monitor which is set to "Auto" by default but if it was manually changed to DVI for example and you are now using a HDMI cable, monitor would not automatically change this setting thus not receiving the signal from the video card. You can check this using the menu buttons on the monitor itself.
This is a generic troubleshooting ideas I just shared, more details you can provide, the better people will be able to assist you.
Nov 21, 2013 | Dell Dimension XPS 400 PC Desktop
What should I do because it says no signal input
Sounds like your video card or monitor is bad. Most likely it's the video card because if it was the monitor the No Signal Input could not appear on the screen. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed Monitor displays ok without a problem then your original monitor is bad. If the Borrowed monitor has the same issue of No Input Signal as your original monitor, then your video card inside the computer is bad.
May 30, 2012 | Biostar MCP6PB M2+ Motherboard
This is going to sound vague, but currently a friend and I are working to get this desktop PC working that has a KN9 SLI motherboard installed on it. Currently, the issue is: The computer turns on, a red...
Try checking the jumpers on the motherboard. A lot of the SLI compatible boards have jumpers that need to be configured properly. You can find out the positions by checking the motherboard manual. Are you using an SLI capable video card or is the video onboard? I just ask because I had the same problem once while trying to install an SLI video card. I had no picture on the monitor and I couldn't figure it out for the longest. Finally I found the answer in the motherboard manual and it turned out to be a jumper that was set wrong. Hope this helps.
Mar 23, 2011 | Abit KN9 SLi Motherboard
Hello I have a problem, my motherboard g31-m7 no video, i picked up the battery, but the problem still there, how to solve this problem?
I don't know who recommended a CMOS battery to fix your graphics, but this = no.
1) You have checked the monitor cable, correct? If the monitor cable is removable, replace it with a known to be good one, for a test.
If the monitor cable is not removable, use a known to be good monitor, and cable for a test.
2) If you are using the Integrated Graphics of the motherboard, (OnBoard graphics), then the next test is to install a graphics card. If you have graphics now, your OnBoard (Integrated) graphics chipset is bad.
3) I find most of the time, (Like around 80% or more) that the Power Supply is bad.
Enough power to light LED lights, spin fans, (Or spin a few times, and stop), but NOT enough power to turn the Processor on.
A bad Power Supply is one of the leading causes of computer failure, right next to computer is dirty inside.
A) ALL of the LED lights being on at once, will use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power. Depends on what Processor it is.
Here you can see a CPU Support list for the Biostar G31-M7-TE motherboard, and the wattage of the different CPU's,
http://www.biostar.com.tw/app/en/mb/cpu_support.php?S_ID=363
Again, you may have a bad Power Supply.
Enough power to light LED lights, and spin fans, but not enough power to turn the Processor on.
No Processor operating, No computer.
No computer operating, No video signal.
(No Signal)
Do you have a KNOWN to be good, compatible power supply to use for a test unit?
Post back in a Comment.
Nov 06, 2010 | Biostar G31-M7 TE Motherboard
Acer monitor does not get signal every time
If anything try updating the video card drivers. That's what it sounds like, or the monitor is going. The next time the monitor fails to start, just unplug from the input and put back in. If it starts you are looking at a bad power booster on the board. You can also try pluging in another monitor or try that monitor on a different machine. This way you can eliminate which is bad. I had flat panels and crt's go on me and they usually start by this symptom. It shouldn't be the BIOS, if it's been working right along, same with the processor, it either works or doesn't, it's a monitor scenario.
Mar 08, 2009 | Asrock K8Upgrade-VM800 Motherboard
When I turn on my pc I an see the hard drive light working and flashing, indicating that it is loading up, but my monitor does not receive any video signal,so I hooked my pc to my freinds monitor and I got...
Sounds like your video card is bad. You will need to purchase a new one. On some machines there is 2 video connectors -like 1 on the motherboard and 1 other mounted in a slot just verify that you have tried both connectors if you have them before buying a new card.
NOTE: Usually the slot mounted video card will over-ride the motherboard video by default.
Good Luck!
Rich
Jan 30, 2009 | E-Machines eMachines Desktop PC
COMPUTER WON'T BOOT UP
The possible reason why there's no signal on the mobo are, first of all it can be a problem with the video card and since you already tried replacing the video card and still no sigal so it means not the video card problem, you can also try to connect a different monitor if possible to check if its not a problem with the monitor and also a bad motherboard will cause this since the video card is connected to it and so if you already try a different monitor and still the same problem motherboard is the one that is bad....
Nov 02, 2008 | Abit IS7-V Motherboard
Red Light
Hi Ivematthew,
Usually, that red light is simply an indicator that the mainboard is receiving a 5volt supply from the power supply and you must NEVER install or remove any mainboard components whilst this light is on. In fact, dont touch the instde if the case or the mainboard if this light is on.
If you are getting a no signal on your monitor, try turning off at the mains and pulling the plug out, then touch the metal chassis of the case BEFORE you touch anything inside the case.
Then carefully remove your video card and re-install it into the same slot, you can even do this a couple of times. Then try booting the system up.
Also, check that both ends of the video cable are securely connected and that the cable appears undamaged.
I have to ask, Is the system booting up?
Are you getting a single beep at the start of the boot or is your system beeping more then once?
If it is beeping more then once, count the length and number of beeps and go to the ASUS website where you can use the beep code to locate the particular fault the mainboard is signalling about.
Let me know how things go and email me if you are still having issues OK?
Swoop611
Oct 22, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Ram problem..
carthi, I do not think the problem your having currently has anything to do with your memory. If your video card was integrated into the board I might agree there could be a problem with your memory but that is not true. Your video card is an AGP8x device. Black & red colored lines can be produced from either a bad monitor or a bad video card. Your K8S-MX motherboard can not run DDR1 ( unless you mean that slot 1 DIMM you replaced). Your board only supports, 2x184-pin DDR DIMM sockets for up to 2GB non-ECC PC3200 / PC2700 /PC1600 DDR DIMM's. No video display suggests your video card may be going bad or monitor is going bad. To prove this concept, please temporally switch your monitor with a monitor you know functions correctly. If you can not temporally switch your monitor with someone else than replace your AGP8x video card. You can find up to six pages of AGP8x video cards listed at the link below.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
The XFX cards carry Lifetime Warranty.
If you find you have more questions feel free to ask.
Good Luck & Kind Regards.
Mike
Mar 24, 2008 | ASUS K8S-MX Motherboard
No Video Output - HP 6635 Desktop minitower - CPU Intel CELEROM 533Mhz
if you have changed the monitor and the same no signal have you noticed a beep sound? or can you see the green and red light in front of cpu? if both of this doesn't light it's power supply and if there are led lights (green&red) lighting but there is a continous beep sound the problem is the on board video card. if a sound short beep, beep the problem is your memory card.
Nov 27, 2007 | HP (5064-6630) Motherboard
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
