I have a HD-338-comp and i don't know the pin of power which iw the positive the ins
I have external enclosure kit HD-338-comp and i want to know in the power socket host which is the positive the pin or the other
4 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Enclosures for Seagate ST910021AS
Just buy an external
Posted on Nov 02, 2007
SOURCE: Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Posted on Jun 03, 2012
  • 224 Answers
SOURCE: HD-338-COMP external hard drive not mounting
It's likely your dealing with hard drive failure on your san max and you will need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Posted on Sep 05, 2012
Sep 04, 2012 | Computers & Internet
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Can't start HD, I can hear only biping sound
a biping sound is usually indicative of either a dead drive, or not enough power on the USB bus (for unpowered external drives).
If the drive will take an external power supply, but is not connected to one, try connecting a power supply to it.
If the drive is out of warranty, try removing it from the external enclosure and hook it up internally to the PC. Sometimes the enclosure interface fails. If the drive makes the same noise inside the PC, it's likely dead.
May 17, 2012 | Seagate Expansion 1.5 TB USB 2.0 Portable...
I need to locate a mother board for a firelite model #USBFLB40-C any suggestion? Or where can I get a new USB power data plug soldered on the old board? Thank you.
Yes I would take the Harddrive out of the SmartDisk FireLite external harddrive, and install it into an economical external enclosure.
Looking up reviews just now I know that it's a laptop sized harddrive that's inside.
(The Harddrive inside is 2.5 inches across in width. 2-1/2 inches)
I don't know however if it is an IDE or SATA unit.
But you will know once you get the case open, and view the Harddrive inside.
One example of a 2.5 IDE external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1086960&CatId=2782
One example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
One example of an external enclosure that will support IDE or SATA harddrives that are 2.5,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Regards,
joecoolvette
Jul 04, 2011 | SmartDisk FireLite 40 GB Hard Drive
I have a serial ATA mobile disk drive, model # HD-338-SSC. My computer no longer recognizes the device and the power button on the device now displays a red light, next to the standard green light. I tried...
The disk-drive inside the enclosure has "failed".
Open the enclosure, remove the disk-drive, and take it to any computer-store, to buy a compatible replacement. Install the replacement disk-drive.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 18, 2010 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My external hd was in use when the power went out and came on . it was about 30 seconds. now my computer and ps3 will not recognize it . It is 2TB Masscool 3.5 SATA enclosure with a wd 2TB hd green. just...
The could be only two reasons for that problem with enclosure or hd. You need first figure out which one is the problem.
Plug the HD directly to the computer and see if computer can recognize it. If computer can recognize HD and you can access it then the problem with enclosure and something got burned when power got back. If you the enclosure still under warranty try to get replacement of if you electronic tinker you might try to fix it. If computer not able to recongnize HD and you can't access it from WIN then HD got fried. I would not recommend to store any important data on HD there is always a chance it will fail at some point.
Cheers, DS
Oct 25, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
I applied the wrong ac adaptor to my external hardrive
My laptop adapter delivers 4A (ampères). Examine the HD adapter, and read all markings, looking for output intensity ( a number followed by a capital A). Do the same with you computer's adapter.
If output intensity delivered by the computer adapter is higher than the output intensity of the HD adapter, chances are you have blown out a fuse inside the HD enclosure (if you have a fuse)
In addition to voltage, intensity, there is the question of polarity of the adapter (positive inside ---C+ or positive outside ---+C. You can verify compatibilties of the adapters by comparing the C with a dot on both adapters.
Hope it helps sort things out a bit.
Sep 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Iomega Minimax HD, no power but lead light is on. Working fine, then I turned it on today & nothing, no fan, no light but the power lead green light comes on. How do I know if its the HD or the power lead...
In your situation I would :
open the minimax enclosure, and take the hd out, (just open the enclosure, not the hd itself), and then open your desktop and connect this hd as slave (I am guessing you have a desktop with IDE hd and that the minimax has an IDE hard drive in it.... or both your desktop and the minimax has SATA hard drives) and then when you turn on your computer you should be able to see your second hd as a partition and be able to see the info in there, yet if windows does not recognize it, that means your hd is useless., yet remember you have to change the pin on your external hd to be slave or auto detect, if you let it as master your computer won't boot, bout do not worry, after you unpluges the hd from your desktop everything will be normal
p.d.
shutdown and unpluged the power cord from your desktop when adding/removing the hd.
Apr 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
USB Connection Issues
Cat this is your earlier problem reworded - I can see now that this is a dual device. If you can use it that way in Firewire mode leave it at that. However - is it possible that this is a 'switchable mode device and you have not discovered the secret of how to. If there is anything like a manual with this check it thoroughly or get into the makers tech support team
May 23, 2007 | SanMax 2.5'' EXTERNAL ENCLOSURE KIT...
USB Connection Problems
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
