Question about Mitsubishi WD62628 62" Projection HDTV
Wd-62628 blinking green light - Mitsubishi WD62628 62" Projection HDTV
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
  • 103 Answers
SOURCE: Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Posted on Apr 26, 2008
Slinteriors
  • 8617 Answers
SOURCE: WD 62725 Timer geen light keeps blinking
Thats caused by the capacitors on the dm which wont allow the DM to boot back up because the power cord was unplugged to change the lamp. You can get the V26 DLP DM repair kit at the following link which will usually repair that issue and it contains the replacement caps and step by step instructions with detailed pics on how to do the repair on CD plus the service manual is also on the CD.
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
Posted on May 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
  • 8 Answers
SOURCE: Blinking green light Wd-C657
sell it
Posted on Apr 16, 2010
My mitsubishi wd 62628 wont reset. the green light keeps flashing for about a minute and then the orange keeps flashing tv not coming on..try resetting several times...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 12, 2017 | Mitsubishi Televison & Video
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Thanks.
Jun 24, 2011 | Televison & Video
My Mitsu WD-62628 will not turn on
It is probably by coinsidence that the set has failed. I doubt it was from the house cleaner. The set most likely failed on its own. The power supply is a common fault in most LCD screens when they fail. Sometimes a failure can occure on any of the other boards, and thus cause a fault in the power supply.
Jerry G.
Apr 16, 2008 | Televison & Video
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD62628 62" Projection HDTV Logo
191 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
