Question about Smeg Dishwashers
Smeg dishwasher 12059 is constantly draining, unable to re-set to wash- rinse light and large sucepan ligh on-rinse programme lightflashing
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
  • 1462 Answers
SOURCE: SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Posted on Jul 18, 2008
  • 298 Answers
SOURCE: dishwasher has a overfill problem rinse light flashing
An Idea: the Overflow sensor or float is bad, stuck, disconnected and its messages to STOP filling aren't getting thru to the CPU
This is usually located in the right frony of the machine or in the side wall. Float types get gummed up with 1/2 dissolved soap powder (god what we do tho the water systems) see if it moves. Sensor types have a hole that feels or senses water. If clogged, they lie. Clean out with toothpick and blast with a bit of hot water and air. Retry
If fixed, let me know... if not, see the yellow pages for parts dealers ;-)
Cheers
Posted on Mar 27, 2009
  • 109 Answers
SOURCE: SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Posted on Jun 16, 2009
reddyanantha
  • 205 Answers
SOURCE: SMEG DWI710E1 Dishwasher not heating water
please check the heating element and also the thermostat
Posted on Nov 07, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
Why does dishwasher rinse light keeps flashing and sounds like its draining. ?cant put another programme on
the flashing rinse light is a error code but i need a model number to know exactly what it means, constant draining with an error normally indicates an issue with water either its filling up to much and leaking into the base or it has a leak from somewhere in the dishwasher i.e. a hole in hose or a leaking seal, constant draining is a default response to a leak for all dishwashers often continuing draining even when the door is opened
Oct 08, 2014 | Dishwashers
Smeg dishwasher Beeps when trying to drain...seems to wash ok but
Check your air gap at the sink for internal obstructions (take it aoart and clean it) Also check the dishwasher drain outlet into the garbage disposal (if you have one) They tend to clog up inside the garbage disposal. You may have to pull the hose off that connects to the garbage disposal to clean the hole out.
Kelly
Feb 28, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Water pre-heating
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Smeg DF612S
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Nov 07, 2007 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishwashers Logo
99 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Garth Jackson
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
