Question about Samsung SyncMaster 2253BW LCD Monitor
Samsung monitor won't turn on
2 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: my samsung pt24ts won't power up
hi if no any light indicator at the front panel, it was a sign of bad power supply board. check first for a blown fuse replace with the same rating. then look for any bulging capacitors. also replaced with the same rating and voltage capacity.hope this can help good luck and let me know if you need further assistance.
Posted on Nov 16, 2012
Samsung monitor brightness indicator stuck in middle of screen and won't disappear
its an option pyshically on your monitor there has to be some butttons near the power button of the monitor. play around with those and you might figure it out or
http://www.eanswer.com/tv-repair/?r=ppc'ga'9'HI%20-%20Electronics'TV%20Samsung&JCLT=Samsung&JPKW=samsung%20screen&JPDC=S&JPST=&JPAD=5822362509&JPAF=txt&JPCD=20100518&JPRC=1&gclid=CPqM5LPxlLUCFYVFMgodOiUA5w
if this helps please take time to rate
Feb 01, 2013 | Computers & Internet
My samsung pt24ts won't power up
Nov 15, 2012 | Samsung Computers & Internet
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
Samsung T220hd won't turn back on from standby
Power up issues on the T220HD monitor are caused by a failure of the capacitors on the IP-49135b power supply board that this unit uses. The repair is easy, you just need to replace the 7 failed capacitors and the unit should be as good as new. Here is a link to some information showing what needs to be replaced to repair the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_33_68&products_id=217
I hope this helps.
Nov 21, 2011 | Samsung T220HD LCD Monitor
Our Samsung SEW-3030 won't stop vibrating. How do we get it to stop?
Adjust your sensitivity dial which is located side of your monitor. It might hard to find suitable sensitivity, but once you find, it will not vibrating.
OR
You can just put sensitivity dial all the way down to turn alarm function.
Hope this helps!
Jul 30, 2011 | Samsung Wireless Security Monitoring...
Lately, my T-Mobile Samsung t239 phone's buttons on the slider part with the monitor attached to it won't work, like for example, the right side button that, when the home screen is on,...
i gues you have dropped it or it got wet. Bring it to your local telephone shop and ask to clean it. That only cost like 10 dollars and when they put it back together the align the keyboard
thats the best way to go
good luck
rene
May 28, 2011 | Samsung T239 Cell Phone
MY SAMSUNG CRT MONITOR 56V DISPLAY IS NOT COMING,THOUGH POWER ON INDICATOR IS GLOWING WITH GREEN LIGHT. PLS HELP ME . THANK YOU. MY E-MAIL ID IS parthobijoy@yahoo.com
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....DISPLAY WON'T COME BUT LED BLINKS........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily....
Apr 06, 2011 | SAMTRON 55V 15" CRT Monitor
Open Questions:
See all Samsung SyncMaster 2253BW LCD Monitor Questions
Samsung SyncMaster 2253BW LCD Monitor Logo
346 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
