Question about Refrigerators
My bush fridge freezer keeps triping switch only 18 month old
My bush fridge freezer keeps triping swich only 18 months old
HVACRH20
  • 237 Answers
SOURCE: Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Posted on Dec 20, 2006
SOURCE: Bosch Classixx fridge / freezer
Not a solution but mine has a weird noise. when the door is shut the fan engages yeah? well its sounds to me that when the fan starts spinning it seems to be hitting something amd making a wacking noise as it spins iv tryed removing the air flow ducts inside the fridge but can seem to get to where the fan is located has anyone taken one of these apart before? help would be great as its out of warrenty and im a bit skint for a new one and its driving me mental at night lol
Posted on Mar 19, 2008
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
freetek
  • 5568 Answers
SOURCE: Freezer too cold, fridge not working - Amana freezer on bottom
Something tells me you are right.
I'm sure you know that cold air seeks the lowest point, in your case, the freezer drawer.
About every combination unit I have ever seen uses a fan to 'stir' the air in a controlled manner and one or more adjustable vents to allow you to balance the distribution of the cooled air.
I'd place my bet on the failure of a (possibly Chinese) fan motor that isn't turning anymore.
Posted on Jul 27, 2009
mgprice
  • 744 Answers
SOURCE: Freezer is too cold, fridge isn't cold enough.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Sep 11, 2009
Bought Bush fridge freezer 13 months ago. fridge broke down twice with same problem. defrost timer. Can i complain to bush
you can ask again for it to be looked at repaired
even if it is out of warranty
fixed twice during warranty period (for free i hope )
if point of sale will not refund or repair or replace fridge freezer
you will need lots of paper work receipts of repairs and calls and conversations made etc etc
then you have to take the company /manufacturer of the bush fridge freezer to small claims court and try to get money back
parts list
http://www.espares.co.uk/browse/at1084ma732/fridges-and-freezers/bush
Jun 30, 2016 | Bush Refrigerators
Fridge freezer triping switch
The only thing that really can cause this is a shorted motor in the refrigeration pump capsule.
Feb 08, 2012 | Refrigerators
I have a Samsung side by side model # SRS 632NSS. it is about 18 months old. The freezer side does not function but the fridge side is normal .We have tried turning it off and resetting it however it is...
Defrost cycle is very often. Check freezer timer/thermostat might be cuts off frequently. Check thermostat setting..Check fridge is working continuously until frosting over freezer by keeping thermostat at 9' clock position. If not replace thermostat.
Jan 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have an active smart fridge freezer. The freezer seems ok but the fridge has stopped working but it doesent get cold. how can it be fixed. It is only 18 months old.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
