Question about LG Flatron Computers & Internet
LG IPS235V-BN Remove Bezel
HI everyone, I have bought 3 LG IPS235V-BN monitors and the displays are great. My issue is that the bezel on the left and right side is slightly curved causing for small gaps between the screens in an eyefinity setup. I have looked up some information on removing the plastic cover from the screen which would give me a flat metal surface. Unfortunately I couldn't find anyone that removed the bezel of this monitor before. Can anyone help me out? Maybe the procedure is the same for all LG models...
The Machine
  • 788 Answers
SOURCE: Replacing the whole monitor screen and bezel
Usually there is a plastic cover that snaps off right about the keyboard that covers the hinges. It is sometimes screwed from the bottom of the notebook thought. Once that is removed you should have a clearer view of what needs to be done. Sometimes there is a few screws from the bottom or back of the system that hold the hinges and sometimes the screws are on top of the hinges. You should also see all the cables that go from the screen to the system, unplug those. Hopefully that is all you need to do, but sometimes you have to remove the keyboard and palmrest to get the screen off. Good Luck!
Posted on Jan 10, 2008
SOURCE: lg 8700 cellular phone lcd replacement
removice a plast
Posted on Oct 09, 2008
  • 13 Answers
SOURCE: Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
Russell
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Posted on Jan 03, 2009
SOURCE: need to remove dell e193fpc flat panel covers to repair
First remove the stand. Then at the bottom of the monitor there are two small openings an inch or two from each edge. Starting there with WIDE flat blade screw driver (or a couple of them) it IS possible to pop the catches that hold the back of the case to the front. You have to go around the case very carefully popping each catch and preventing the areas you have opened from becoming re-latched. I found some wood popsicle sticks good for that.
If you search for "LCD Monitor Repair" you can find sites that have video's of several Dell models (but not this exact one) any that use the "pop open" case are pretty much similar.
One note after you get inside. The power supply board had the WORST solder job I have seen in a long time. The failure in the unit I repaired was due to open solder joints on the hi-voltage transformers taking out the power transistor's that drove them. It took me two months, but I found some replacement transistors on ebay and after resoldering many of the joints on the board it the monitor works fine.
I attribute part of the failure to the use of Lead free solder which is becoming common in all consumer electronics. It makes for brittle connections that fail easily and there is also the issue of tin whisker growth that will hit in a few years down the road.
Posted on Mar 16, 2009
SOURCE: Removing front bezel of Dell 1907FP monitor to repair stuck power button
ThndrChld's suggestions are great but way too complicated. all you need is a flat head screwdriver. the front bezel/frame/whateveryoucallit can be removed without taking the backside off at all.
the reason the power button gets "stuck" is because it is set off centered from the sensor on the chip underneath it and it relies on a little protruding arm to press down on the sensor...this arm has broken off. button is not really "stuck." its a stupid design flaw by dell or whoever they contracted to make the monitor.
take the screwdriver and just stick it into the seams along the side of the front frame (black frame) and wrench side to side, twist your wrist, etc, to open. you will hear creaking and cracking but thats ok and doesnt damage the monitor at all (though you may create scratches and dents in your casing), its just the clips and snap ins coming loose.
here is a shot of it opened. the chip is held in by 3 very small screws. there is nothing you can do about the power button being broken.
(see this pic shows only front frame is pried open, nothing else) 1086a3b.jpg
the way i circumvented this broken power button is to drill a hole directly through the bezel/frame to the chip itself. i turn on my monitor now with a toothpick (i dont suggest using a paper clip as i first did in this shot, it will scratch up the metal on the chip). you can see where the paper clip is inserted and shows that the sensor on the chip is offset from the power button.
do this or take it into a shop and pay money =). who cares about a nasty looking front bezel, at least my monitor still works.
Posted on Apr 07, 2009
I have an Acer Extensa 5635. All the lights on the laptop work and i can hear the Windows sounds but the monitor doesn't show.. what do i do?
follow this steps and fix it. God bless you
    Power off your computer. Examine the bezel of your laptop, which is the perimeter surrounding the LCD display. There will be screws around the edges of the bezel, likely with screw covers on them, depending on your exact model. Pop off these screw covers using a knife tip, for example, and then remove all the bezel screws using a Phillips screwdriver. Put these screws in a safe place, such as a small plastic bag, because you will need them later.
      • 2
    Remove the bezel from the display. Pop it off by isolating a corner and peeling it off from there. Be careful not to bend or warp the bezel in the process.
      3 Disconnect the inverter cable. The inverter cable plugs into the inverter, which is located directly beside it. The inverter can be found beneath the bezel after it is removed, and directly below the center of the LCD display.
        • 4
      Remove the remaining screws. These screws are located in the metal brackets on either side of the laptop screen. These metal brackets are only visible once the bezel is removed. There should be two screws on each bracket, but this varies by model. Use your Phillips screwdriver to remove these screws, and put them in safe place, such as your plastic bag.
        • 5
      Pull the LCD display from the back plastic of the computer carefully, then remove the old display altogether. Slide the new display in and reconnect the inverter cable.
        • 6
      Replace the screws into each metal bracket, making sure to hold the new LCD display in place. Then, put the bezel into place over the LCD display. Replace all the screws and make sure they are tightly screwed into the bezel. Power the Toshiba laptop back on and enjoy your newly fixed hardware. Save any documentation that shipped with your replacement LCD display for later perusal or warranty purposes.
      Jul 31, 2013 | Computers & Internet
      My hp dv5000 screen is blank
      Problem can be;
      A) Graphics chipset
      B) Video Cable
      C) screen Inverter
      D) LCD screen
      Let's diagnose, and find out.
      A) Graphics chipset:
      To start off with, the Pavilion dv5000 series of Notebook PC's; is NOT known to have a problem with the graphics chipset.
      The Pavilion dv2000 series, Pavilion dv6000 series, and Pavilion dv9000 series; does.
      1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port; on the laptop.
      The VGA port is on the Left side of the laptop, and located towards the rear.
      This is a general example of a VGA connector (port), and VGA Cable,
      http://en.wikipedia.org/wiki/VGA_Connector
      Scroll down a little for VGA Cable example.
      You can use a CRT type of monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
      Turn the monitor on. If a CRT type allow it to warm up.
      Turn the laptop on.
      By factory default settings, the display should show on the external VGA monitor.
      IF not:
      There are at least 3 display options available;
      1) Internal monitor of laptop ONLY
      2) Internal monitor of laptop AND external VGA monitor
      3) External VGA monitor ONLY
      Press, and hold down on the Fn key, and at the SAME time tap once on the F4 key.
      The F4 key is the Display Toggle-Over key.
      Still no? Hold the Fn key down again, and tap once more on the F4 key.
      No display on external VGA monitor, suggests a problem with the graphics chipset.
      (Most of the time it is a problem with the Mounting, of graphics chipset TO motherboard. If this proves to be your problem, state in a Comment )
      Display on external VGA monitor means the problem is the Video Cable, or inside the Display Assembly.
      (screen Inverter or LCD screen)
      B) Video Cable:
      The Video Cable plugs into the motherboard, in an area under the Switch Cover.
      (Left side.
      Switch Cover is the plastic cover above the Keyboard, and below the LCD screen. Has the Power On Button, LED indicator lights, etc in it)
      It then loops by the left Hinge, and goes up into the Display Assembly.
      There is a small separate wire that comes from the main Video Cable, and connects to one side of the screen Inverter.
      The main part of the Video Cable goes on, to connect to the back of the LCD screen.
      Example of Video Cable,
      http://www.batterycentury.com/hp-430531-001-cable-p-215726.html
      Click on image to enlarge.
      The wide connector you see at the top/left, connects to the back of the LCD screen.
      The wide connector at the bottom/right, connects to the motherboard.
      The single cable (Wire) coming off at the bottom, connects to one side of the screen Inverter.
      Just due to normal repeated opening, and closing of the laptop; the Video Cable may become pinched.
      This leads to it being pulled on, and may also lead to damage of the Video Cable.
      (Stretched/Broken wires)
      Procedure is to Physically check the connections of the Video Cable. Visual inspection alone will NOT do. You need to physically see if you can plug the connection in tighter.
      1) ALL power removed. Remove the AC adapter (Charger), and Battery.
      2) Remove the Switch Cover.
      [Switch Cover is just that. A Cover. I will give a link to a free Service Manual from HP Support, towards the bottom of this solution ]
      Try to plug the Video Cable connection at motherboard, in tighter.
      Once done reinstall the Battery, and attach AC adapter. Plug AC adapter into power.
      Turn the laptop on.
      Still no? Turn laptop off. (Hold down on Power On button)
      Remove ALL power again.
      This time check the Video Cable connections at screen Inverter, and back of LCD screen.
      The plastic frame in front of the LCD screen is the Display Bezel.
      Example,
      http://www.ebay.com/itm/447997-001-HP-Pavilion-LCD-Display-Bezel-DV9000-Series-w-Webcam-GENUINE-/170992584210?pt=US_Laptop_Screens_LCD_Panels&hash=item27cff3c612
      Service Manual indicates to remove Display Assembly from laptop, in order to remove Display Bezel.
      IMHO this = NO.
      I think you can remove the Display Bezel, without having to remove the entire Display Assembly.
      This video details removing the Display Assembly.
      Shows replacing the LCD screen.
      http://www.youtube.com/watch?v=NNyvf4KqeIY
      What my concern is with removing the Display Bezel, is the integral Hinge Covers that are a part of it.
      I believe the Display Assembly can be tilted far enough back, that the Display Bezel can be removed, and carefully ease the Hinge Covers out/off at the same time.
      Why not just remove the Display Assembly?
      A whole lot less stuff to reconnect, after you have checked the LCD screen connection of the Video Cable, and screen Inverter connection.
      After disconnecting the LCD screen from the Hinge Brackets, you just tilt the LCD screen forward, and check the Video Cable connection.
      Then slightly tilt the Display Cover back, so the LCD screen can rest against it, and reinstall power.
      Connections are plugged in tighter, and this proves to Not be the problem, go on.
      (Don't forget to remove ALL power again)
      The Screw Covers are made of synthetic rubber, or plastic.
      They are held in place by a type of rubber cement.
      I like to use a computer pick, (Much safer than a blade!), and lift up at the base of the Screw Cover.
      I also like to GENTLY stick them to the Display Bezel for safekeeping. (They like to stick to the tool, your fingers, and it seems passing cars. "Oops, dropped one. Where'd it go? Hmmmm)
      If you are careful with them you can reuse them. (Doesn't stick anymore? Apply a TINY dab of rubber cement to them, with a toothpick)
      Screws removed, I suggest cut a piece of thick construction paper, that just fits the inside edges of the Display Bezel.
      Helps prevent scratching the LCD screen, from your fingernails, when you go to flex the Display Bezel, and remove it
      The LCD screen is an Assembly of layers. They are held in the factory aligned position, by the metal Screen Frame which surrounds them.
      There are screws that hold the Hinge Brackets TO the Screen Frame, and there are screws which when removed, will take the Screen Frame apart.
      ONLY remove the necessary screws which hold the Hinge Brackets, TO the Screen Frame!
      More in a Comment.
      Regards,
      joecoolvette
      Feb 24, 2013 | HP Pavilion dv5000t Notebook
      White screen on laptop
      Long read ahead Naveen.
      Check to see if the problem is the;
      A) Graphics chipset,
      Or;
      B) Video Cable,
      http://www.ebay.com/itm/Compaq-Presario-1700-Laptop-LCD-Ribbon-Cable-251352-001-/310601465049?pt=LH_DefaultDomain_0&hash=item48514a3cd9
      Or;
      C) Screen Inverter,
      http://www.ebay.com/itm/Compaq-Presario-1700-LCD-Inverter-KUBNKM011A-/280971500392?pt=US_Laptop_Screens_LCD_Panels&hash=item416b34db68
      Or;
      LCD screen,
      http://www.ebay.com/itm/Compaq-Presario-1700-Laptop-14-1-Inch-Screen-251352-001-/310601464998?pt=US_Laptop_Screens_LCD_Panels&hash=item48514a3ca6
      (Not advertising, but on another note; you can buy the whole laptop for $50 USD,
      http://www.ebay.com/itm/Compaq-Presario-1700-14-1-Laptop-Pentium-lll-1GHz-256MB-CD-RW-DVD-Rom-20GB-HDD-/390534574226?pt=Laptops_Nov05&hash=item5aedacb092 )
      Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the back of the laptop.
      This is an example of a VGA connector (port), and VGA cable,
      Scroll down a little for VGA cable example.
      You can use a CRT type monitor (Looks like a small TV), or a flat LCD screen monitor of it has a VGA cable.
      Turn the laptop on.
      IF not:
      There are at least 3 display options;
      Press, and hold the Fn key down, and at the same time tap once on the F3 key. The F3 key is the Display Toggle-Over key.
      Still no?
      Hold the Fn key down again, tap once more on the F3 key.
      A good display on the external VGA monitor means the graphics chipset is OK.
      A white screen on the external VGA monitor, means a problem with the graphics chipset. More than likely the Mounting to motherboard, of the graphics chipset. (BGA surface mount)
      If this is the problem post back in a Comment.
      A good display on the external VGA monitor, means the problem is the Video Cable; or inside the Display Assembly.
      (Screen Inverter or LCD screen)
      B) Video Cable:
      The Video Cable plugs into the motherboard, in an area under the LED Button Bezel, and right next to the Left HINGE.
      [LED Button Bezel is the strip of plastic below the LCD screen, and above the Keyboard. Has LED indicator lights in it, etc ]
      It then leads up into the Display Assembly, where a small separate cable connects to one side of the screen Inverter, and the rest of the cable connects to the Back of the LCD screen.
      This allows it to be pulled on, and/or damaged.
      (Stretched/broken wires)
      ALL power removed, AC adapter (Charger), and Battery; the connections for the Video Cable should be checked.
      Motherboard side, screen Inverter connection, and LCD screen side.
      Motherboard side connection:
      1) Remove the LED Button Bezel.
      Two screws (Philips) are removed from the bottom of the laptop, and the LED Button Bezel is CAREFULLY pried up, and off.
      Details are in Page 91 in the Service Manual, which I will include at the last of this solution.
      I will refer to the page number from now on, for the specific component removal.
      2) Remove the Keyboard. Page 93.
      I state remove, but do NOT unplug the Keyboard Cable from motherboard connector. Just unfasten the Keyboard, roll LCD screen side towards you, and lay upside down on the Palm Rest Cover.
      You MUST physically check the connection for tightness. Try to plug it in tighter.
      LCD screen side connection:
      Disassembly of the Display Assembly, is not shown in the Service Manual. (At least I couldn't find it)
      REMOVAL of Display Assembly is.
      So I will guide you step by step. I do not believe the Display Assembly has to be removed, in order to remove the Display Bezel.
      Looks like this removed,
      http://www.ebay.com/itm/COMPAQ-PRESARIO-1700-14-1-LCD-FRONT-COVER-BEZEL-/320720203233?pt=US_Laptop_Screens_LCD_Panels&hash=item4aac69ede1
      From what I can see, there are four Philips head screws to remove, from the Display Bezel.
      There is a Screw Cover at the Top Left, and Top Right to remove.
      The is a Screw Cover at the Bottom Left, and Bottom Right to remove also.
      I use a computer pick, and lift up at the base of the Screw Cover, where it meets the Display Bezel.
      The Screw Covers are held in place by a type of rubber cement.
      If you are careful you may be able to reuse them. If they don't stick again, apply a TINY dab of rubber cement with a toothpick.
      I LIGHTLY stick them to the Display Bezel for safekeeping.
      Remove the 4 Philips head screws. (No.1 Philips screwdriver, or No.1 Jewelers Philips screwdriver)
      The Display Bezel has TABS going around the exterior perimeter, of the inside edges.
      The Display Cover has matching LATCHES that the Tabs snap into.
      I suggest cut a piece of thick construction paper, to JUST FIT the inside edges of the Display Bezel, and lay on LCD screen.
      (Display Assembly laid as far back as possible)
      This will protect the LCD screen from your fingernails.
      The bezel is flexible. Come to the inside edge (LCD screen side), of the right side of the Display Bezel.
      Lift the edge up with a fingernail, until you can slide a fingertip underneath.
      Can't get in? Move over. You are at a Tab/Latch.
      Bezel lifted up with one fingertip slid under, move over with the other hand, and slide a fingertip under. Flex the bezel up a little, and move towards the Top.
      By now you should hear a Tab/Latch snap loose.
      Sounds like you are breaking something.
      (Do use CARE! The bezel can be broken, but not if you are gentle, and go slow)
      Keep popping the Tabs/Latches loose, going around the Top, then Left side. By the time you come around the Left side, the entire Display Bezel should pop loose.
      (At the TOP. You may have to slide the Latch over to the open side, to get the slot in the Display Bezel to clear, if a Latch is used)
      Not your laptop, and uses more screws. Just a basic 'hands-on' guide I thought may help,
      http://www.insidemylaptop.com/how-to-replace-screen-on-asus-u56e-laptop/
      More to follow in added Comment.
      Free Service Manual,
      http://h10025.www1.hp.com/ewfrf-JAVA/Doc/pdf/c00000630.pdf
      http://www.overclockers.com/more-laptop-musings/
      Regards,
      joecoolvette
      Feb 21, 2013 | Compaq Presario 1700 Notebook
      Will not turn on
      If your laptop won't turn on, you could have any number of problems.
      The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter.
      Conversely, it may only appear to be a power failure, and the problem may lie with another component.
      Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected.
      Look at the battery indicator light on your computer.
      Is it on?
      If so, check your brightness settings.
      If your laptop appears that it is not on, it may in actuality have lowered brightness settings.
      If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not.
      Try cranking up the brightness settings.
      Check your AC power adapter.
      Is it snugly plugged into the wall or surge protector?
      Make sure the connection is made and it is not loose.
      Also, try connecting the power adapter into a different wall outlet.
      Check the status of your laptop battery by considering how long you have had the same battery.
      Most modern batteries are only good for about 1,000 full charges.
      After that point, the battery can and eventually will greatly deteriorate.
      Replace your battery if necessary.
      Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop.
      Remove any screws with a Phillips screwdriver and pop off the battery cover.
      Slide out the old battery.
      Put in the new battery by sliding it in until it clicks, and then replace the cover.
      Consider replacing your laptop monitor.
      Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine.
      Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable.
      If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
      Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver.
      Pop off the bezel carefully and remove it.
      Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
      Disconnect the inverter cable, which is plugged into the inverter.
      The inverter is located just beneath the display, at the bottom-center of the laptop.
      Then, pull back and slide out the old display, and replace it with the new.
      Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place.
      Replace the bezel screws.
      hope this helps
      Oct 22, 2012 | Dell Latitude D610 Notebook
      Compaq presario 1200 laptop monitor problem
      This is due to a bad Backlight, or screen Inverter.
      90 PERCENT OF THE TIME the fault is a bad screen Inverter,
      http://www.ebay.com/itm/HP-COMPAQ-PRESARIO-1277-1275-13-1-1688-1200-1694-13-3-LCD-SCREEN-INVERTER-/330698057906?pt=LH_DefaultDomain_0&hash=item4cff23e8b2
      A small primer before we continue;
      An LCD screen cannot produce light. It needs an additional light source.
      A Backlight is the additional light source,
      http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
      Click on the monitor icon.
      A Backlight can be a CCFL, (Or two of them), or a series of LED's.
      (Light Emitting Diode)
      The Compaq Presario 1200 series of Notebook PC's, uses a Single CCFL.
      (The exact model number is on the Bottom of the laptop. It is in a white Service Tag, and P/N = Product Number. Compaq and HP's model number)
      A CCFL is a Cold Cathode Fluorescent Lamp.
      Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
      Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about this thick -> O
      Average length is almost as long, as the LCD screen is in height.
      [ http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
      Look at the last 8 photos ]
      A screen Inverter is used to convert the power of the laptop, for the LCD screen, and Backlight.
      (LED backlighting doesn't usually use a screen Inverter.
      CCFL backlighting Does)
      Primer over.
      The front plastic thin frame in front of the LCD screen, is the
      Display Bezel.
      The screen Inverter is located behind the Display bezel, and is located towards the bottom of the LCD screen.
      1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
      2) Open the laptop to the usual 90 degree position.
      AS FAR AS I CAN TELL, you do not need to remove the Display Assembly from the laptop, in order to remove the Display Bezel.
      IF the Display Bezel will Not come off, with the Display Assembly attached to the laptop, I will give a link at the bottom of this section to a free Service Manual from HP Support.
      There are 4 Philips head screws that go around the front, of the Display Bezel.
      One at the Top Right corner, one at the Top Left corner, one at the Bottom Left corner by the left Hinge, and one at the Bottom Right corner by the right Hinge.
      These are covered by Screw Covers. The screw covers can be pried off with your fingernails. If you use care you may be able to reuse them again. I stick them to the Display Bezel frame for safekeeping.
      (They also like to stick to your fingers too! lol!)
      If the glue is not reusable on the screw cover/s, just put a tiny little dab of Rubber Cement on them, using a toothpick.
      (Try to remove any old glue first)
      Use a Philips screwdriver of the right size, and remove the 4 Philips screws.
      The Display Bezel is now pried off.
      Use CARE as your fingernails can scratch the LCD screen.
      You can lay the LCD screen back as far as it will go, then cut something to fit the LCD screen area, and be inside the inside edges of the Display Bezel.
      Poster board, cardboard, cloth, etc.
      Or use a pair of computer gloves.
      The procedure is to lift the inside edge of the top, of the Display Bezel up a little. Then move over a few inches with your other hand, and try lifting up on another inside edge of the Display Bezel.
      This will slightly flex the frame of the Display Bezel.
      There are Latches on the inside of the Display Bezel, and Tabs on the Display Cover. (Cover that is the top when you close the laptop)
      The Latches snap into the Tabs.
      When you lift up on the inside edge of the Display Bezel, the Display Bezel will flex. Lift up, slide your fingers over under the Display Bezel, and the bezel will start popping off. Snap, snap, snap.
      Keep working along, and popping those Latches loose from the Tabs.
      Same principle, less screws,
      http://www.insidemylaptop.com/replace-lcd-screen-hp-g62-compaq-presario-cq62-laptop/
      Again, a different laptop than yours. Main info I want you to see is at
      3:04 to 3:22,
      http://www.youtube.com/watch?v=goVTe9rzAFo
      The screen Inverter will be located at the bottom/middle, of the LCD Screen Frame.
      Remove the screw/s that hold it on. Carefully unplug the wires to it.
      Plug the wires to the new one, and remount the screen Inverter.
      Snap the Display Bezel back into place, reinstall the screws, and screw covers.
      http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=95013&
      Click on -
      Presario Select 1200 Series Maintenance and Service Guide
      [ Ignore if you are aware;
      This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
      After you click on the above file name, it may take up to 30 seconds before the first page comes up.
      The PDF file is downloading in the background ]
      Replacing a CCFL backlight if the screen Inverter wasn't the problem;
      It's TRICKY, and dangerous.
      The bulb is so thin it can break in a New York minute.
      It also contains MERCURY just like Fluorescent lamps used in homes, and businesses.
      You may wish to seek professional help with replacing a Backlight
      For additional questions please post in a Comment.
      Regards,
      joecoolvette
      Oct 20, 2012 | Computers & Internet
      My computer willnot power up anymore.
      Instructions
      1.Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
      2.Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
      3.Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
      4.Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
      5.Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
      6.Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
      7.Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws.
      I hope you find it very helpful. Thanks.
      Oct 04, 2011 | HP DeskJet F4280 All In One Printer InkJet
      Computer wont start in any mode, black screen
      Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have 1.lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
      Sep 28, 2011 | Computers & Internet
      Hi, I have a laptop compaq presario cq 60 .When I switch on the computer the fan start working but the screen is black doesn't start .What could be the problem? Thank you
      If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
      Here are some steps that you can try. One of these may work on your case.
      1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left on the system. (You may need to repeat this step to get it work.)
      2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor.
      3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
      4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the laptop not to POST.
      5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
      Hope this helps.
      Jul 17, 2011 | Compaq Presario CQ60-212US Notebook
      Dashboard Gauge
      1. Disconnect and isolate the battery negative cable.
      2. Remove Over Steering Column Bezel Replacement.
      3. Remove over steering column bezel.
      4. Remove left end cover.
      5. Remove screw at left end of cluster bezel and headlamp switch.
      6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
      7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
        1. Separate cluster bezel from instrument panel.
        2. Disconnect wire connectors from back of the bezel.
        INSTALLATION
        1. Connect wire connectors into back of the bezel.
        2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
        3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
        4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
        5. Install screw at left end of cluster bezel and headlamp switch.
        6. Install left end cover.
        7. Install over steering column bezel.
        8. Install lower steering column cover.
        I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
      Jan 15, 2009 | 1999 Dodge Caravan
      LCD screen looks like bad TV reception
      if the display returns to normal when you press the bezel at on end means there is a bad connection to the inverter behind the bezel itself or the inverter is ready to give up the ghost.
      you can attempt to dismantlethe laptop and remone the lid or in some cases just unscrew the bezel and remove the plastic cover, the inverter is at the bottom of the display you can't miss it
      hope this helps
      regards
      Nov 18, 2008 | Acer Aspire 5601WLMi Notebook
      Computers & Internet Logo
      360 people viewed this question
      Top LG Computers & Internet Experts
      Michael Vincent Cruz
      Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
