Question about Dell Dimension 5100 (D51L1) PC Desktop
Cd rom drive is missing or hidden
Cd rom drive is not visible at start up bios settings may have changed
  • 669 Answers
Check the cables to make sure they are connected and tight. If the drive is not appearing in the bios, then it could have went bad and will need replacing. If it is, but not appearing in windows, then here are the steps from Microsoft on how to fix the issue. All operating systems are included in the fix.
http://support.microsoft.com/kb/314060
Posted on Feb 08, 2012
3 Suggested Answers
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
dante777
  • 623 Answers
SOURCE: I am trying to change
In order to change the boot sequence on a Dell computer you have to press the F12 key right after the computer starts and BEFORE the Windows logo appears.
You can also choose F2, if you have to get into the BIOS.
On some machines you just have to hold down the respective key, on others you have to tap it repeatedly. Just try it out.
When you see the Windows logo, let the computer complete the start-up, reboot and try again.
Once it is booting from CD/DVD, follow the instructions on the screen ("Press any key to boot from CD...")
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Dec 07, 2010
Is there a trick to getting a Toshiba laptop L775 to boot from CD ROM when BIOS password is missing? Have tried holding down c, esc. F2, F12, you name it.
reset the cmos settings to remove the password on the bios
https://www.youtube.com/watch?v=K4NqgDoyjNc
https://www.youtube.com/watch?v=siSoOXkNSgw
a software solution
https://www.youtube.com/watch?v=9UgLL3EHVzU
Worth a try
To change the boot order remove the hard drive and when it fails in the boot order I would think the laptop will try to boot the next device in the boot order hopefully set as CD rom
it could be f8 in so,me laptops
Mar 24, 2017 | Toshiba Computers & Internet
Tip
NTLDR is missing?
A missing NTLDR is a common start up error that can appear on the screen while booting a computer running a Windows operating system. This error may occur due to number of reasons.
NTLDR is short for Windows 'NT LoaDeR'. It's entirely involved in the loading of the operating system.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk/hard drive that contains no operating system or CD-ROM drive. Firstly what you've got to to is press the Delete key multiple times as your computer boots up until it displays the BIOS screen. Then you will need to find the boot disk priority setting. Make sure this is set to your drive that has Windows on it (as priority 1) and not the CD-ROM drive/stiffy drive or empty hard drive. You can set the CD-ROM/DVD-Rom drive to priority 2 if you like.
Once you have checked that and have set it to your master/primary hard drive (the one that you've installed Windows onto), save and exit the BIOS and on reboot your system should boot into Windows normally.
If you only have one hard drive and the boot disk priority 1 is set to it and you still get this message, then it means that your NTLDR is either corrupted or missing. In the BIOS you will need to change boot disk priority 1 to your CD/DVD drive. Once this is done save and exit the BIOS.
As the PC reboots insert your Windows install disk and let it load.
Hit [R] when prompted if you need to repair system files and then [C] at the 'Welcome to Setup' screen to start the Recovery Console. This will let you copy NTLDR from the CD to C:\
If this fails then you will need to install a fresh copy of Windows on your system. All is not lost though as you can still save your data that is trapped on the NTLDR missing hard drive. If you are not quite seasoned with computers and electronics then this is the job for a PC technition. Simply take your PC down to your local Computer store and explain your situation (Don't forget to take your original Microsoft Windows with you). They will back up your data, re-install Windows and the put all your data back on for you.
on Nov 15, 2010 | Computers & Internet
Boot mgr missing message
I could have told you you were loading Windows 7 by the symptoms. Try running a Malware program with a register edit-register function in it. If you are switching from XP Pro. you will need to clear your register and all command and drive to . Set BIOS to boot from DVD/CD first then set the hard drive to boot second. Windows. Also if you have access to another computer ask microsoft for tech support.
Apr 01, 2012 | Compaq Presario 5000 PC Desktop
Hello. I flashed the computers bios to upgrade the computer and now the restore disk I got with my system is out dated and older then the computers bios that was flashed. It loads and restores the...
You did not post the make and model number of the computer. There may be a proprietary driver missing. the BIOS should have nothing to do with the issue. On another note, XP is no longer supported so it may not be able to register with Microsoft.
Mar 03, 2017 | Viscom V2 Premier 17'' LCD Computer...
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
System reboot
Depending on what bios it has it may not show the cd drive. All you can do is set it to auto or if it has the option to cd or atapi. Then set the boot order so that the cd is looked at before the hard drive and you should then boot off of the cd.
Oct 24, 2009 | Acer Aspire 3610 Notebook
I can;t boot my laptop compaq Evo N610c from cd-rom drive
Disable the SATA option in BIOS settings then it automaticaly takes the CD ROM
Mar 04, 2009 | Compaq Evo N610C Notebook
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Cd rom and dvd drives were not visible.
Hi purushoth,
So neither of the ROM drives are available, or just the one? Your jumper settings may or may not be correct; in some systems, even having the IDE cable placement and jumper settings correct may still leave errors such as this.
Basically if you dink around with the settings (for example just try changing the Slave and Master) it will work (provided there's nothing wrong with the drives or IDE cable). I'd also suggest setting both to Cable Select as some systems (such as Sony VAIOs) oftentimes will only allow optical drives to function with that setting.
Ben
Feb 25, 2008 | HP (344542-005) DVD Drive
Dell Dimension 5100 (D51L1) PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
