Question about OTC Ball Joint Installer / Remover
How to remover ball joint - OTC Ball Joint Installer / Remover
How to replacement ball joint
Posted on Oct 20, 2012
How to change a Xantia bottom ball joint
Depressurize the hydraulic system. Jack the front and put on jack stands (both left and right side). Remove wheels. Slacken and unscrew the ball joint nut partially. Release ball joint from knuckle using a proper separation tool. Once dislodged, remove ball joint nut and pull out strut/knuckle away from lower arm. You may need to push down the arm with a lever. Remove dust cover from the ball joint. The ball joint can be removed by unscrewing it using a tool that locks into the notches on the sides of the ball joint. Install new one by screwing in the ball joint back into the knuckle.Tighten well.
Sep 01, 2012 | 1998 Citroen Xantia
How to change upper ball joint on 93 suburban 2500 4x4
Inspect/Test/Service/Replace Removing Ball Joint Tapers from the Steering Knuckle
The ball joint is connected to the steering knuckle with a tapered connection, called a steering taper, which is also used in other steering connections.
f57-19.gif A ball joint taper. Courtesy of Moog Automotive, Inc. To remove a ball joint requires the use of a ball joint remover.
Another way of "breaking" the taper is to use a large hammer.
  • First, remove the cotter pin from the ball joint nut and loosen the nut several turns.
  • Position the vehicle so that the coil spring is pushing on the ball joint. This could require lifting the vehicle or allowing its weight to rest on the wheels.
  • Use a hammer to pound sharply on the steering knuckle on the outside of the taper. this will deform the taper and spring pressure will separate the ball joint from the steering knuckle.
Removing the Ball Joint from the Control Arm
A ball joint can be retained by one of several methods.
f57-20.gif Three common ball joint retaining methods. Courtesy of Moog Automotive, Inc. Some ball joints are held in with rivets from the factory. The rivets are drilled and punched to remove them. Bolts and nuts are used to hold the replacement joint in place.
f57-21.gif Original equipment rivets are replaced with nuts and bolts. Courtesy of Moog Automotive, Inc. The most common method is press fit. Some manufacturers require you to replace the entire control arm assembly if a ball joint is to be replaced. In these cases, the ball joint and control arm are made as a single assembly and individual parts are not available.
If the control arm has been removed from the vehicle, a pressed-fit ball joint can be removed using a standard hydraulic press. when the control arm is still on the car, a special press set allows the removal and replacement of these ball joints. some pressed-fit ball joints have a spot weld that holds them in place. this must be carefully removed. when a replacement ball joint is installed, a snap ring often takes the place of the weld.
NOTE Be sure the grease release hole in the new ball joint's rubber boot is aimed away from the brakes.
May 09, 2012 | 1993 Chevrolet C/K 2500
I need to know how to replace lower ball joint in my custyomer's gmc vandura 1996 model 6.5 d 3500 series.
Hi, the ball joint is connected to the steering knuckle with a tapered connection, called a steering taper, which is also used in other steering connections.
Use a hammer to pound sharply on the steering knuckle on the outside of the taper. This will deform the taper and spring pressure will separate the ball joint from the steering knuckle.
If the control arm has been removed from the vehicle, a pressed-fit ball joint can be removed using a standard hydraulic press. When the control arm is still on the car, a special press set allows the removal and replacement of these ball joints. Some pressed-fit ball joints have a spot weld that holds them in place. This must be carefully removed. When a replacement ball joint is installed, a snap ring often takes the place of the weld.
NOTE
Jul 24, 2011 | GMC Vandura Cars & Trucks
Need pictures and procedure 91 Ford pickup F250 twin I beam ball joint replacement.
Wheel Spindle, F-150, F-250, F-350
Removal
  1. Raise the front of the vehicle and install safety stands.
  1. Remove the wheel and tire assembly. Refer to Section 04-04 .
  1. Remove the disc brake caliper (2B120) from the rotor and wire it out of the way. Refer to Section 06-03 .
  1. Remove the dust cap, cotter pin, nut retainer, nut, washer and front wheel bearing (1216).
  1. Remove the rotor from the front wheel spindle (3105).
    Item Part Number Description 1 606085 Clamp Bolt 2 3B404 Camber Adjuster 3 800895 Nut 4 800937 Nut 5 3049 Front Suspension Upper Ball Joint 6 3050 Front Suspension Lower Arm Ball Joint 7 3105 Front Wheel Spindle 8 642569 Cotter Pin 9 3304 Steering Sector Shaft Arm Drag Link 10 383489 Nut 11 3001 Front Axle Assembly 12 388727 Bolt A - Tighten to 77-103 Nm
    (57-75 Lb-Ft) B - Tighten to 68-92 Nm
    (50-67 Lb-Ft) C - Tighten to 113-153 Nm (83-112 Lb-Ft) D - Tighten to 340-460 Nm (250-339 Lb-Ft)
  1. Remove bearing cone and roller (1201) and wheel hub grease seal (1190). Discard the seal.
  1. Remove front disc brake rotor shield (2K004). Refer to Section 06-03 .
  1. Disconnect the steering linkage from the integral front wheel spindle and spindle arm by removing the cotter pin and nut and then removing the front wheel spindle tie rod from the spindle arm with Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Remove the cotter pin and castellated nut from the lower ball joint stud.
  1. Remove the nut from the axle clamp bolt and remove the bolt from the axle.
  1. Remove the camber adjuster from the upper ball joint stud and axle beam. If required, use Ball Joint Removing Tool D81T-3010-B or equivalent to remove adjuster.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use a pickle fork to separate the ball joint from the axle as this will damage the seal and the ball joint socket.
    Strike the inside area of the axle as shown to pop lower ball joints loose from the axle beam.
  1. Remove the front wheel spindle and ball joint from the axle.
Ball Joint, F-150, F-250, F-350 SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number U-Joint Tool T74P-4635-C Ball Joint Remover T94T-3010-AH
Removal
  1. Remove the front wheel spindle (3105) and ball joint assembly from the axle. Refer to Wheel Spindle, F-150, F-250, F-350 in the Removal and Installation portion of this section.
  1. NOTE: Lower ball joint must be removed first.
    Install the front wheel spindle in a vise and remove the snap ring from the lower ball joint.
  1. Remove the lower ball joint from the front wheel spindle using U-Joint Tool T74P-4635-C and Receiver Cup D81T-3010-A5 or equivalent for F-150. Use Ball Joint Remover T94T-3010-AH for F-250 and F-350.
  1. Turn the forcing screw clockwise until the ball joint is removed from the front wheel spindle.
  2. CAUTION: Do not heat the ball joint or the front wheel spindle to aid in removal.
    Assemble U-joint tool and cup on the upper ball joint, and turn forcing screw clockwise until ball joint is removed from the front wheel spindle.
    Installation
    1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not heat the ball joint or axle to aid in installation.
      NOTE: Upper ball joint must be installed into the front wheel spindle first.
      NOTE: Individual ball joint tools are included in Ball Joint Adapter Set D81T-3010-A or equivalent.
      To install the upper ball joint, assemble C-frame assembly, Ball Joint Receiver Cup D81T-3010-A5 and Installation Cup D81T-3010-A1 and D81T-3010-A3 or equivalents inside cup D81T-3010-A4 or equivalent in position on the front wheel spindle.
    1. Turn forcing screw clockwise until ball joint is seated.
Mar 25, 2011 | Ford F-250 Cars & Trucks
How to remove upper and lower ball joins on a 4x4 bronco full size 1986
For Lower & Upper Ball Joint Step by Step :
For That you use a C-clamp style ball joint press to remove the ball joint from the suspension arm-note the location of the receiver cup ! For installation of the ball-joint, use the same tool when pressing the ball joint into the suspension arm-again, note the location of the receiver cup.
Step by Step :
  1. Raise and support the vehicle safely, with jackstands.
  2. Remove the spindle and the ball joint assembly from the vehicle.
  3. Remove the snapring from the ball joint. Using a ball joint removal tool, remove the ball joint from the spindle. Do not heat the ball joint or the axle to aid in removal.
  4. Installation is the reverse of the removal procedure. Torque the ball joint stud nut to 85-110 ft. lbs. for 1983-89 Ranger and Bronco II.
    Please Rate, Thank you !
Aug 13, 2010 | 1994 Ford Bronco
How to replace a lower ball joint on a 1988 pontiac grand prix hit a pothole and it popped out
Hope this helps and please don't forget to rate! Thank you!
Front ball joint with heat shield
Remove and Replace-
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle with jackstands.
  3. Remove the front wheel and tire assembly.
  4. Unfasten the retaining bolts, then remove the ball joint heat shield.
  5. Remove and discard the lower ball joint cotter pin.
  6. Remove the ball joint nut.
  7. Loosen, but do NOT remove, the stabilizer shaft bushing assembly bolts.
  8. Separate the ball joint from the strut/knuckle assembly using ball joint/tie rod puller J-35917 or equivalent.
Do NOT damage the halfshaft boots when drilling out the ball joint rivets.
  1. Drill out the rivets retaining the ball joint to the knuckle strut assembly and remove the ball joint from the knuckle. Use a 1/8 in. drill bit. Refer to the instructions in the ball joint replacement kit.
To install:
  1. Position the lower ball joint in the strut/knuckle assembly.
  2. Install the four ball joint bolts and nuts, as shown in the ball joint kit and tighten to specifications.
  3. Install the ball joint-to-lower control arm. Install a new ball joint-to-lower control arm nut.
  4. Tighten the stabilizer shaft bolts to 35 ft. lbs. (48 Nm).
  5. For 1988-91 vehicles, tighten the ball joint-to-lower control arm nut 15 ft. lbs. (20 Nm) plus at least an additional 90° (11/2flats), plus enough to align the cotter pin hole. Do NOT overtighten.
  6. For 1992-96 vehicles, tighten the lower ball joint nut to 63 ft. lbs. (85 Nm). Tighten to align the next slot in the nut with the cotter pin hole in the stud. Do NOT tighten more than 60° (1 flat) to align with the hole.
  7. Install a new cotter pin.
  8. Position the ball joint heat shield and secure with the retaining bolts. Tighten to 62 inch lbs. (7 Nm).
  9. Install the front wheel and tire assembly, then carefully lower the vehicle.
  10. Connect the negative battery cable and check for proper suspension operation
Apr 26, 2010 | 1988 Pontiac Grand Prix
Removal and replacement of a lower ball joint for a 1997 taurus. using a new ball joint
You will need certain tools to remove the ball joint. You will need a ball joint removal and installation kit you can find at a local automotive store.Remove brakes and control arms to easily get to ball joint and start the removal. The ball joint kit has instructions on how to remove and install your new ball joint.
Jul 27, 2009 | Ford Taurus Cars & Trucks
How do I replace the upper ball joints in my 2002 Ford Explorer?
The upper ball joints are replaceable without replacing the control arms. Use Moog K80008 ball joints and a ball joint press.
Jun 25, 2009 | 2002 Ford Explorer
Front brake rotors.
1. Loosen the wheel nuts slightly. 2. Raise the front of the car and support it with safety stands in the proper locations. 3. Remove the wheel nuts and front wheel. 4. Remove the brake hose mounting bolts. 5. Remove the caliper bracket mounting bolts, and hang the caliper to one side. CAUTION: To prevent accidental damage to the caliper or brake hose, use a short piece of wire to hang the caliper from the undercarriage. 6. On ABS equipped vehicles, remove the wheel sensor wire bracket, then remove the wheel sensor from the knuckle but do not disconnect the wheel sensor connector. NOTE: Use ball joint removers to separate the ball joints from the suspension or tie-rod end. 7. Clean any dirt or grease off the ball joint. Remove the cotter pin from the tie-rod end ball joint castle nut and remove the nut. 8. Apply grease to the special tool on the areas shown. This will ease installation of the tool and prevent damage to the pressure bolt threads. 9. Install a 10mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end to prevent damage to the threaded end of the ball joint. 10. Adjust the jaw spacing by turning the pressure bolt. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 11. Once the tool is in place, turn the adjusting bolt as necessary to make the jaws parallel. Then hand tighten the pressure bolt, and recheck the jaws to make sure they are still parallel as pictured above. 12. With a wrench, tighten the pressure bolt until the ball joint shaft pops loose from the steering arm. WARNING: WEAR EYE PROTECTION. THE BALL JOINT CAN BREAK LOOSE SUDDENLY AND SCATTER DIRT OR OTHER DEBRIS IN YOUR EYES. 13. Remove the tool, then remove the nut from the end of the ball joint and pull the ball joint out of the steering/suspension arm. Inspect the ball joint boot and replace if damaged. 14. Remove the cotter pin from the lower arm ball joint castle nut, and remove the nut. 15. Install a 12mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end, or the threaded section of the ball joint pin might be damaged by the ball joint remover. 16. Use the ball joint remover, 32mm, as shown to separate the lower ball joint and lower arm. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 17. Remove the knuckle protector. 18. Remove the cotter pin from the upper ball joint castle nut, and remove the nut. 19. Install a 10mm hex nut on the ball joint. Be sure that the hex nut is flush with the ball joint pin end, or the threaded section of the ball joint pin might be damaged by the ball joint remover. 20. Use the ball joint remover as shown to separate the upper ball joint and knuckle. NOTE: If necessary, apply penetrating type lubricant to loosen the ball joint. 21. Pull the knuckle outward and remove the driveshaft outboard joint from the knuckle by tapping the driveshaft end using a plastic hammer, then remove the knuckle. 22. Remove the knuckle from the hub unit. 23. Remove the four flange bolts, then separate the hub unit from the brake disc.
Jun 08, 2009 | 1994 Honda Accord
Lower ball joint removal from a-arm
The entire control arm is supposed to be replaced on those when ball joint fails. Did you manage to buy another ball joint only?
Apr 26, 2009 | 2001 Nissan Altima
OTC Ball Joint Installer / Remover Logo
56 people viewed this question
Top OTC Tools & Hardware - Others Experts
Are you an OTC Tool and Hardware - Other Expert? Answer questions, earn points and help others
