Question about Philips Lands Phones
Trying to register a Phillips CD685 phone with a RTX4002 Dect repeater, and not having much luck
There is an automatic registration and a manual registration, I,m not even sure if I have a compatibility issue.
  • 146 Answers
SOURCE: DECT registration
Sorry but could you re-confirm the model number, as the post heading shows KX-TG5632 and the text of your query shows it as KX-TG7223E ? ( Panasonic site does not recognise the latter ) Thanks.
Posted on Jan 26, 2008
SOURCE: Dect 6.0
Hi :I have the same problem and the dealer couldn't help me .I replaced the battery but that wasn't the solution.Glad to see i'm not the only one with this problem
Posted on Jul 31, 2008
SOURCE: phillips voip321 duo phone drivers
I had the same problem with a HP Pavilion PC running vista. The way I fixed this problem with to plug the USB into a USB port on the PC not using a ext USB Hub. I did have to go into the sound in the control panel and change the default so the other programs would use the correct sound.
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
SOURCE: GE DECT 6.0 Model 28111EE2 is not working, registration failed message
I had the same problem, and restoring to default settings did not seem to work either. I just opened the back, unplugged the battery, plugged it back in, and now it works again.
Posted on May 20, 2009
My phone is sayin not registered
Since you declined to specify the model of your VTech DECT 6.0 phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download the manual and registration instructions.
Jul 19, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Screen has 'NOT REGISTERED' and will not let me connect .
Since you declined to specify the model of your VTech DECt 6.0 phone, enter it into the search box at
Jun 11, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do you register a DECT 6.0 UNIDEN PHONE, LOST MANUAL?
You didn't give your phone's model number, so I can't give detailed steps. ("DECT 6.0" is a generic term for the cordless technology used, and appears on almost every cordless phone that uses it. The actual model number is on a label on the rear or bottom of the base unit.) Usually, registering a handset is just a matter of placing the handset on the base, but sometimes you need to enter a registration mode first. You can download manuals from Uniden here. Pick your model from the list, and the manual will guide you through the process.
May 15, 2011 | Uniden DECT 6.0 Cordless Phone
My vtech 6.0 cordless keeps saying not registered
to download a copy of the manual and registration instructions.
Mar 23, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
My cordless phone says "to register see owners manual for help" How do I get the phone working, it is a uniden DECT 6.0 Model DECT 1588-2
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
Dec 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
One of the handsets of my Dect telephone can not be registrated anymore.
On my phillips phones you first have to "enable registration" on the base before you can register the phone - the RC code should be a label on the bottom of the phone. Else unfortunately the handset could be faulty.
Apr 30, 2009 | Lands Phones
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Nov 08, 2008 | Uniden Cordless Phone
Phillips dect2152
If you bought the base and handset together they should already be registered. If not then the instruction manual is downloadable here: MANUAL
The relevant section is on page 16 - here is a copy:
4 handsets can be registered to the base station. A handset
can only be associated with 1 base station.
�� To register another handset
First enter registration mode by unplugging and
plugging back in the power adapter to the
electricity supply.
Handsets registering / unregistering ( )
�� To unregister the handset you use
enter the RC code*
�� To unregister all the handsets (except the handset you are using)
enter the RC code*
Once the menu is selected, enter the RC* code written under the base and press
to confirm.
Warning : If you wish to associate a non-Philips handset to the DECT 211 or DECT 215 base
stations, make sure that these handsets are GAP compliant otherwise they will not operate properly.
*RC code
(Registration
Code) is
written under
the base.
Warning : Once unregistered, the handset is no longer operational.
Please rate my assistance this should be a fixya!
Mar 29, 2008 | Philips DECT 2151 Cordless Phone
Lands Phones Logo
91 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
