Question about KitchenAid K45SS Classic Stand Mixer
Kitchenaid stopped working - KitchenAid K45SS Classic Stand Mixer
  • dawn_breaks3
    dawn_breaks3 Feb 08, 2012
    Whilst our Kitchenaid was working this morning, it just stopped and would not turn on again. No strange sounds or smells noticed. It is relatively new - just over 1 year of service in a small bakery.
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
HOW TO TEST A PHASE CONTROL BOARD ON KITCHENAID MIXER
I am sorry to say but only with a new one, about 30 bucks and five minutes of work, but if your mixer has any speeds working except only high (only high means it is the phase control board) then it is more likely the speed control board is bad rather than the phase board. Can you send is more info on what happened when the mixer started or stopped working. We can be of more help with more info
Oct 18, 2012 | KitchenAid K45SS Classic Stand Mixer
I own KitchenAid RRKP50 350 Watts since late 2004. and it stopped working last night. I searched internet and found that the worm gear is might be the issue. So I opened it and noticed that the tooth on...
I belieive i"ve found what you need at -the gourmet depot.net-click on worm gears on the list on left side of page,parts with pictures and listings will come up.I think you will want the kp50 series 5 parts
Oct 12, 2010 | KitchenAid RRKP50 350 Watts Stand Mixer
Kitchenaid mixer stopped working in mid-use. No warning and now it won't work at all--checked plug and electrical connection and that is fine
Mixer has a power control board inside the domed end cap. If it has failed then you this would cause these symptons.
Mar 13, 2010 | KitchenAid Food Mixers
KitchenAid KSM50P mixer sporadically stops working
Hi, This sounds like you have an issue with the planetary gear system. The mixer has a plastic worm gear inside the planetary that is prone to wear and failure. I would bet that it needs replaceing.
W!ill not start up
Hi Karl. Have your mixer repaired by a shop that has experience repairing Kitchenaid mixers. Don't think for a second that a new mixer will solve your problems. The new Kitchenaid mixers are not as durable as your old one and are made with an absolute minimum of quality. Quality costs money! ricardok45
Mar 16, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid Professional 6 stops in every rotation
you will need to open it up and check it out. sounds like a broken gear. it's not difficult to work on just remember where everything goes so you can put them back. mendingshed.com has parts and you can find how to do it on kitchenaid.com
Oct 15, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid K45SS Classic Stand Mixer Logo
71 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
