White westinghouse tv model wtv-1903
On the bottom of the screen it says auto on & the channel # is displayed always, how do i get rid of that ?
thank you, bobby cox
  • cox2888 Oct 23, 2008
    Thank You !
  • Anonymous Mar 15, 2014
    lost original remote control to white westinghouse model wtv-12505, how do I change it to the video option
The display button on your remote should remove this.
Posted on Oct 23, 2008
I CANT GET CH03 OFF MY TV SCREEN
If from the set only the original remote on some models will have a 'display' button which should remove or call this up.
Nov 03, 2012 | Televison & Video
I am useing this yv to play video games on but the video 1- video 2 or component setting are always on the screen and i would like to know how to remove them thanks
Use ur tv remote.Press the display button on the remote should get rid of the Video input 1 or 2 reminder display on the tv screen.
Feb 03, 2011 | Sanyo DS24425 24" TV
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
? When AUTO PRESET CH action is completed, the lowest memorized
channel reappears on the screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH",
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
White Westinghouse Model No WTV 11901 television
It sounds like your TV is not equipped with audio/video (A/V) jacks. Many older TVs don't have these. You need to get an RF modulator that will convert the A/V output of the DVD player into a Coaxial cable that you can plug into the back of your TV. I'm including a link to one at Radio-Shack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel. I hope this helps you out.
http://www.radioshack.com/product/index.jsp?productId=2103095
Nov 16, 2009 | Televison & Video
Westinghouse model WTV-11901 shuts off by itself
That is usually a bad power board, the TV can be turned on again after a while because the capacitors inside TV will discharge after some time. The part must be tested before replacement, as overheating can cause similar problems.
Try also leaving the TV unplugged from main overnight, and test the unit on a different AC socket.
May 15, 2009 | Televison & Video
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Channel display
if you have the manua for the
universal remote that you are
using it the button that displays
current channel on the tv
or the one that say jump.
flashback or channel return
might be bottom R corner of
the remote or a small button on
either side of the zero button
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
On-screen menu Zenith Tv Model Z20A21D
it might be due to your cable operator giving important message. please reset tunning once or auto tune. give service code for opening menu. if you do notremember give me system control ic no. so i can send you thanks
Sep 11, 2007 | Televison & Video
Channel display
the option is usually in the menu or controlled by "display" button on the remote
Aug 06, 2007 | Sanyo DS27800 27" TV
Televison & Video Logo
391 people viewed this question
Top Televison & Video Experts
Electro Med Services...
