Question about Canon Office Equipment & Supplies
Canon ir 1605 e100 - Canon Office Equipment & Supplies
  • 7 Answers
SOURCE: ir 1600 . e100
When the scanner motor is started up, the BD input signal does not arrive
within a specific period of time.
When the scanner motor is started up, the motor rotation is too fast, and
fails to reach a specific revolution within 20 sec at time of deceleration.
While the scanner motor is rotating at a specific speed, the BD input signal
cycle is not within a specific range (±2%) for an equivalent of 10 mm (print
distance).
cycle is not as indicated (±2%).
During the period after the power switch has been turned on or
the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed
Posted on Mar 30, 2010
SOURCE: canon ir 2000 has e100
Hello....
eE100 = no laser.
user has broken off the lug on the drum cartridge . This lug operates laser shutter. Solution replace drum Assembly cartridge.
Posted on Jul 03, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
  • 20 Answers
SOURCE: imageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
Posted on May 20, 2010
  • 3 Answers
SOURCE: I AM TROUBLING WITH E100 IN MY CANON IR 400
try to change the scanning lamp,if not then change the immage reader board,at last u have to change the power supply
Posted on Nov 18, 2010
When to change laser unit of canon ir3300
Changing of laser is not essential...if your machine shows error E100-0001, E100-0002, E100-0003 & E110-0000 you will be must change the laser unit...
Jun 27, 2016 | Canon IR 3300 Digital Copier
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Dec 14, 2011 | Canon Office Equipment & Supplies
My ir1610 say error E100? how do i get it working
Hello I have a problem in copy machine Canon ir 1610 have a error code E100 can some one help me on this? please thank you all !!!
Oct 11, 2010 | Canon imageRUNNER 1310 Printer
System error e100
The PCB is faulty.Check the laser unit amd the laser driver PCB.Remove the wiring(check the short or open circuit).
Aug 09, 2009 | Canon imageRUNNER 2000 Copier
hi there
Jul 15, 2009 | Canon iR 2016i Black and White Copier
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Jun 02, 2009 | Canon iR 2020i Laser Printer
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
216 people viewed this question
old marine
old marine
