Question about Panasonic Televison & Video
Model no: TH-32c10r2 power off . power led green blinking fast .
Posted on Jan 29, 2014
  • 39 Answers
SOURCE: Panasonic Plasma TH-42PV500H goes blank on power up
RKUMAR-ALL BLINKING LEDS ARE DIAGNOSTIC CODES WHICH NEED TO BE COUNTED PER SEQUENCE AND REFERRENCED TO A PANASONIC CODE CHART,COUNT THE BLINK SEQUENC AND LET US KNOW.JOE TV
Posted on Dec 17, 2007
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-C42HD18 Blinking Power LED (7 times)
NEED SD OR SU OR SC BOARD REPLACED
Posted on Sep 21, 2009
satavlad
  • 405 Answers
SOURCE: Sharp AQUOS LC-46D85U green LEDs blinking, no picture, no sound
Sharp warranty is the way to go.
Posted on Oct 25, 2009
  • 8457 Answers
SOURCE: Tv shuts off and led power light blinks
Turn off/on couples times,power it well come back on stable,if not ur video board it dead.
Posted on Dec 17, 2009
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
Panasonic LCD TH-L32C2OM when I on the above lcd tv green led blinking and within few seconds red led blinking 4 times
Looks like a power supply trouble or capacitors not good. Has to be open and check by a pro. Good luck,
Serge.
Dec 27, 2015 | Panasonic Televison & Video
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Power outage tv never came back on
Unplug connector zn under front speaker panel if it comes on with remote replace this part. If fails to come check DM caopacitors generally also cause this problem
Feb 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Red light power blinking
Sep 12, 2009 | Panasonic Viera TX-32LX70 32 in. LCD TV
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
D530s will not power up, odd blinking green LED on mobo
Ok, this is acting as if your MB is getting power but doing nothing with it. This very well could be a MB problem where something (unknown without looking at it) is fried. Just for grins, take the cmos battery out and let the pc sit for 1/2 to 1 hr before putting it back. If this does not work, I would contact HP for a replacement MB.
Aug 17, 2007 | HP Compaq Business d530 Small Form Factor...
Jan 08, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Televison & Video Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
