Question about StarTech.com EXTERNAL USB 2.0 TV TUNER WITH REMOTE (00065030815949)
Software asks to connect hardware
When I try to run the software to view the tv, it will ask to connect the hardware device. My computer can see the hardware and I can even use other video software to access the hardware device, ie. msn messenger or Skype video. I installed it on another computer and it seem to work fine. I am running it on usb 2.0. I have reinstalled both the drivers and the software to no avial.
  • 4 Answers
Please download the latest drivers from their website at http://www.startech.com/Data/ProductDrivers/USB2TVTUNER.zip
Please follow the below steps and this should provide a resolution.
1. Unplug the USB2TVTUNER from the PC
2. Uninstall the following from Add/Remove Programs
a) USB Video/Audio Device Driver
b) Windows Media Tools 4.0
c) XTV2.0
Extract the file downloaded to your Desktop, make sure you remove any cds from your drive.
3. Restart the computer (leave the USB2TVTUNER unplugged)
4. Install USB2TVTUNER\Windows.32bit\AP Software\setup.exe from the folder you downloaded. This will install three separate programs, please install all of them.
5. Restart the computer (leave the USB2TVTUNER unplugged)
6. Install USB2TVTUNER\Windows.32bit\Driver\Setup.exe from the folder you downloaded.
7. Restart the computer (leave the USB2TVTUNER unplugged)
8. After the computer is 100% loaded into Windows, plug the USB2TVTUNER in. It should self install itself.
Regards,
Ryan
Posted on Jan 03, 2008
  • 3 Answers
Aqui estan los drivers para XP, VISTA y WIN7
AQUI
Posted on Apr 25, 2011
When i connect the hardware it will ask to the software
Posted on Oct 13, 2008
Mercury Ez View TV Tuner Card Driver for win 64 bit
You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 17, 2014 | Microsoft Computers & Internet
Cant get SGH-G600 connected
When this happens, click Start and Control Panel. If you are in Category View, click Performance And Maintenance and then System. If you are using Classical View, double-click the System icon.
In the System Properties dialog box, click the Hardware tab and the Device Manager button. Next, look through the list of devices until you see Universal Serial Bus Controllers and click the plus (+) sign next to it. Double-click one of the USB Root Hub lines and click the Power Management tab in the USB Root Hub Properties dialog box. Click the Allow The Computer To Turn Off This Device To Save Power checkbox so it is unchecked. Click OK and restart your computer.
Mar 09, 2008 | Samsung SGH-D900 Cellular Phone
Have E Machine ET1161-05 trying to install Kodak ESP6150 computer does not find printer
While installing the printer just switch off the printer and try to install the printer driver completely, When the software will ask you to connect the printer then only switch on the printer. If this way still you are getting the same problem then connect the printer in other usb port or use different USB cable
Aug 14, 2012 | E-Machines eMachines Desktop PC
My computer can't recognize my sansa fuze player... plz help me..
The Fuzeplayer must NOT be connected to the computer before you install the software.
If this has happpened, you will need to remove the Fuse driver in Device Manager. (Inst for XP)
Go to My Computer->Right click and select Properties. In properties, select hardware and Device Manager.
With Device Manager open, plug in the Sansa Fuse player. Find the new driver that popped in.
(You can do and undo this several times until you are certain you have the right one.)
Right click the fuze driver and select 'Remove'.
Close all windows you opened.
Unplug the fuze player and do not connect it until the driver is reinstalled with the driver disk. When the software asks, plug it back in.
That should solve it.
Unsure? ask a knowledgable friend to help.
Mar 21, 2010 | SanDisk Sansa Fuze MP3 Player
Tried to load HP Laserjet 3015 s0ftware with printer plugged in. That failed. Now getting "finds new hardware" when I try to load the software even though nothing is plugged in. software is not asking me...
The thing is printer is automatically detected by the system and there was no proper driver was installed and it is in device manger installed as other device with yellow mark. Just uninstall it. And click on scan for hardware changes. To go to device manager right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | HP LaserJet 3015 All-In-One Printer
Installed WMP54GS and am getting the following error from Linksys Wireless Network Monitor Access violation at address 0040744D in module WMP54GSv1_1.exe'. Read of address 00000368
Possibly you have installed the WLAN monitor also that is why it is creating the error...try these settings... Reboot your computer in SafeModeUninstall the software for the Adapter from start >> All programs/Remove the Drivers from Device Manager...Turn your computer Off and connect the adapter in a different PCI Slot...Reboot your computer in Normal Mode...
>> Insert the Setup CD in the cd drive>> Click on Exit when the
Linksys welcome screen appears>>Click on start. Unplug & replug adapter ...>> There should be a "" Found New Hardware Wizard ""
that pops up on your screen>> Click on “Install software
automatically “, and then click on next. Once the installation is
complete>> Right click on the wireless network connection icon in the
system tray besides the clock >>Click on view wireless networks and
then connect to your network name...
May 01, 2008 | Computers & Internet
Is lexmark 8300 printer conpatible with window vista?
Ok here we go
unplug your printer (from usb)
1.) Click start / right click my computer choose properties
2.) choose device manager
3.) right click on anything on the tree view and choose scan for hardware changes
5. put in your printer driver an begin the instilliation process
6.) when it ask to connect your printer connect it and ensure it is on
7.) it should detectyour printer automatically
8.) if it fails to do this, leave the program running and repeat steps 1 to 3 it will find your printer and install it..
9.) if that still fails click start / control panel / classic view and then choose Problems and reports..
A MISSING DRIVER problem should show up there. select it and choose solve problem via the internet..
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
Hp PhotoSmart 3310 All In One Printer
Toi uninstallthe old driver,
1.) ensure your printer is connected to the computer and its powered on
2.) click start, right click mycomputer, click properties
3.) click hardware tab, then click device manager
4.) click view then show hidden devices
5.) the printer will show up on the left in the tree view,
6.) right click it and click uninstall
7.) immidately unplug your printer
8.) restart and install new driver..
9.) when it ask your to plug your printer in then do so..
10.) sigh of relief
Dec 31, 2007 | HP Photosmart 3310 Printer
ENLTV- Failed to initialize Hardware. followed steps. STILL PROBLEM!!!!!
Look at the FAQ in www.encore-usa.com: "When you see "Failed to Initialize Hardware" message, please be sure Video Card driver and Sound Card driver are properly installed by checking Device Manager under Computer Management. If the above conditions are met and you are still experiencing problem, it is necessary to perform a hardware reset procedure on the card. Here's how: power down the computer, unplug the TV Tuner Card from the motherboard, remove the jumper on the card (pin 2 and 3) and then put it back. Power back up the computer and then try to run the software again." It seems that the card have some kind of issue that "hangs" its hardware, you should try also another TV Program like K-TV. Mine did exactly that "Failed to initalize Hardware" but the free K-TV program worked! :)
Nov 30, 2006 | Encore ENLTV-FM-HA (CTETVC)
Camcorder connection to pc computer
you can install picture package software which comes any ofusual sony cybershot digi cam. I think that might work..try that and revert back to me.
Sep 07, 2006 | Sony Handycam DCR-HC21 Mini DV Digital...
StarTech.com EXTERNAL USB 2.0 TV TUNER WITH REMOTE (00065030815949) Logo
434 people viewed this question
Top StarTech.com Televison & Video Experts
Marvin
Marvin
Are you a StarTech.com Televison and Video Expert? Answer questions, earn points and help others
