Question about Dremel 16472 Carbide Coated Scroll Saw Blade
Changing blade on Dremel scroll saw
My husband died and I can't find the manual to our scroll saw. How do I change the blade on a Dremel scroll saw?
  • mdr234775 Dec 14, 2008
    i cant find a manual to a dremel scroll saw how do i change the blade
  • Bill Mecklenburg
    Bill Mecklenburg Jul 01, 2014
    There is a knob on top at the rear which when turned adjusts the tension to the blade. By turning you will release the tension enough to remove the blade.
  • 2,176 Answers
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Posted on Jan 17, 2009
  • page 15 Squirt a generous amount of SAE 20 oil around the shaft end and bronze bearing
  • Dremel 1830 Manuals
Sep 16, 2014 | Dremel 1830 120V 18" Scroll Saw
Blade tension lever
Was the tension lever in the untensioned position when the blade was installed. It needs to be.
Sep 05, 2014 | Dremel 1830 120V 18" Scroll Saw
Would I be able to replace the blade on my scroll saw? How would I go about doing this?
It is possible to replace the balde on your scroll saw when it gets dull. Make sure that you do change the blade to be very careful because the new one will be very sharp. Following the instructions on this site will help you out.
Jan 02, 2014 | Saws
I have an old Dremel scroll saw model 550 and need blades. However, the blade holder is missing a clamp that secures the blade. Is there a universal kit I can purchase to solve problem?
Try going to a store that sells scroll saws and look at the new models to see how they hold the blade. Take your Dremel with you. Maybe you can find one that is similar enough that could work if you can get the part. Then go to the tool company's web site and search for the manual for the comparable tool you found - they all have on-line manuals nowadays. You should be able to order the part you need. Good luck!
Jan 30, 2013 | Dremel 5 3" Saw Blades 8033 For 550...
Need owner's manual for a dremel 1671 scroll saw
Check out this site: Copy and paste it to your browser
Jul 21, 2012 | Dremel 1671 16" Scroll Saw Operators &...
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
chances are you might be trying to feed the wood to fast or your speed is set wrong or the blades are not right for the job.
Oct 24, 2009 | Saws
I have an old dremel 2 speed 16 inch scroll saw. The motor appears to work, but I can't figure out how to put a new blade in it! Can you help me?
a standard coping saw blade or a blade made for the saw - one end is clamped in the piston, the other end is clamped in the upper arm. look for an allen wrench set screw.
Oct 13, 2009 | Dremel Saws
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Dremel 16472 Carbide Coated Scroll Saw Blade Logo
2,046 people viewed this question
Top Dremel Saws Experts
JonSnell Electronic
JonSnell Electronic
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dremel Saw Expert? Answer questions, earn points and help others
