Question about Pioneer AVIC-D3 Car DVD Player
Radio on but no sound
I have checked all the wires, fuss. Do i have amps somewhere in the car that I can get to so I can check those fuses? radio is on but no sound, what is the color coding for the radio wires, i need to connect a blue wire from my aftermarket radio to the stock car amplifier
  • yonniki Dec 28, 2008
    I have the same problem. I was changing the radio station and the sound cut out! All other operations are functional on the face plate. Trying to atttempt to trouble shoot the problem. Your help is appreciated.
  • 3 Answers
Try going in to your settings and turn the antenna power on...it's something to do with one of the factory presets on the antenna...check it out and let us know if it works. I had to do it on my d3
Posted on Jan 13, 2009
Please can someone tell me where this memory fuse is for the radio. According to the forums that's what's wrong with my radio. It turns on but there is no sound. I've searched every fuse! Please help!
I never heard of a memory fuse, but you don't say what kind of radio or vehicle it is so maybe on a brand new auto but I never heard of one... Sounds like the radio took a dump, or the whole wire plug harness is unplugged or at least loose..try unplugging and plug it back in..
Jan 20, 2015 | Cars & Trucks
I recently had a after market stereo, Amp and bass box installed now my AC,Heater and vent blow out of the top dash defrost vents and not the ones facing the driver and passanger. I checked all the fusses...
Check for a vacuume leak, a small broken hose around the radio or heater controller or around the engine bay. Those snap real easy when they get old and maybe when they ran the wire from the battery or around the radio one got pulled out or snapped. Good luck..
Nov 10, 2012 | 2000 GMC Yukon XL
Infinity modulus problems with car radio for 2005 Chrysler Crossfire. No sound
If the radio works the two fuses for it must be OK. 15A fuse 23 is the source of amplifier power. The amplifier is probably tucked away near the radio
Oct 10, 2012 | Cars & Trucks
It keeps blowing my fuse for my stock radio. Pushing a 10" sub.. Fuse on my amp is good. In-line fuse is good. But it keeps blowing the radio fuse in my panel.. ? Please help.. Thanks Ryan
Check the amp turn-on wire. It's a blue/white wire running from the radio to the amp. It's probably label REM at the amp. This wire sends a switched 12 volts from the radio to the amp. It is probably shorting out somewhere between the radio and the amp.
Nov 28, 2010 | Alpine MRP-T220 Car Audio Amplifier
Power windows will not work what fusse do i check none listed in
owner manual will have a fuse chart.
go to central junction box and check fuse #17, 15 amp fuse.
check power distribution box maxi - fuse #6, 30 amp fuse. This box may be in engine compartment.
Dec 27, 2008 | 2002 Mercury Mountaineer
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
Radio on but no sound.
no there are no factory amps on the vehicle, chances are the circuit on the output side of your radio is the fault it's a 12 pin chip that is soldered to the main board. that chip is bad. to repair it would be more expensive than to just buy a new one... please rate
Car will not start keeps blowing fuse for radio internal light and immobiliser 10 amp fuse
welcome to fixya
This sounds like a short some where check inside the lighter for and metal items like a penny,dime ....if nothing in there then there is a short in the wires somewhere might be radio or the lighter .....i would lok at those two first
Jul 31, 2008 | Daewoo Lanos Cars & Trucks
Pioneer AVIC-D3 Car DVD Player Logo
196 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
