Question about MGE UPS Pulsar Ellipse Premium 650 UPS System
My MGE Ellipse Premium UPS is dead
When switched on no sound, light any thing. Batteries are dead, i read 3V only. I checked the battery fuses, they are ok. There is no connection failure from power plug to mainboard. My batteries are dead for sure but what i wonder is why is it powering on (at least power light and battery warning light should light). I expect it powering on, trying to charge the batteries and meanwhile battery warning lights.
  • 1 more comment
  • Mark Spencer Feb 08, 2012
    If changing batteries are the only solution for this problem, do you advice that I try to charge batteries outside (I once bought a lead acid battery charger, i should find it) and see if the ups comes alive?
  • Mark Spencer Feb 13, 2012
    Batteries are:
    2 pieces 12V 6Ah in series.
    Dimensions: 151mm x 94mm x 51mm (Per Cell)
  • Mark Spencer Feb 14, 2012
    One of the battery is not able to hold the charge. It gives 7 volts max. Other has 11 volts. That confirms the batteries are dead. But when I connect the batteries read 17-18 volts and it is sufficent to lights the leds of the ups for a second and a beep sound. That means UPS is working but needs proper batteries.
4 Suggested Answers
xerick
  • 139 Answers
SOURCE: MGE UPS SYSTEMS ELLIPSE 800
i think u need to replace the battery so u get it working again.
thank u
Posted on May 29, 2008
  • 181 Answers
SOURCE: FUSE RATING
3amp
Posted on Jun 17, 2009
Geekman
  • 32281 Answers
SOURCE: Hello, could you please let
The batteries in an UPS are sealed lead acid batteries. The voltage and amp hour rating depends upon the VA rating of your UPS.
I suggest you shut down your UPS and remove the batteries and get replacement ones that are the same rating as the ones in the UPS. Be careful of the size of the battery, they are a neat fit inside the UPS battery compartment.
Posted on Oct 05, 2010
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
My 2000 stratus has no dash lights and starter will not turn. It was working great until I tried to start it the next morning.
Sounds like a dead battery, check that and then check your fuses. Sounds like your battery is dead, or has a bad connection. One other thing to check is your security setting, if your car was jumped recently it could have corrupted your computers programming, which means have your cars memory reflashed
Jan 08, 2015 | 2000 Dodge Stratus
1100 shadow no start no lights. dead
Do you have an alarm fitted sometimes these cause problems of this type. Other things to look at are kill switch, side stand switch and the switch on the clutch all these can prevent the bike from going. You say the battery is good but then say nothing comes on. I would remove the battery (REMOVE THE NEGATIVE LEAD FIRST) try attaching a 21 watt bulb to the terminals and see if the light output dims in a short time. If it does the battery is shot. Batteries these days only last for a couple of years at best. Your first battery from new will always last the longest never did fathom that one out but it seems to hold up. MF (MAINTENANCE FREE) batteries give no warning signs that there are about to die. Switch on ride a while switch off DEAD. I have had it happen twice on my SUZY SV.
I would get a new battery fill and charge it as per the manufacturers instructions PLEASE ONLY USE A DEDICATED MOTORCYCLE CHARGER, A CAR CHARGER WILL FRY THE BATTERY.
WHEN YOU REFIT THE BATTERY, CONNECT THE POSITIVE LEAD FIRST.
HOPE THIS ALL HELPS.
Apr 10, 2014 | Honda VT 1100 C2 Shadow Sabre Motorcycles
2007 chevy impala ss radio stop working and now car wont start
Assuming the battery is fully charged, the connections from the battery red to starter motor & relay are tight, and black terminal from battery to engine block (or chassis) are tight, and cables &/or terminals are not corroded, and the battery electrolyte levels are not low to expose the battery lead plates, the symptoms you describe sounds like a main fuse panel issue. Some cars have two fuse panels; one beneath the driver or passenger console, another one beneath the hood in engine area. If fuses are OK, then not enough electrons are passing through when you turn the key, meaning something is acting as a resistor to prevent free flow of electrons (loose connections or corroded terminals or cables). When you pop open the caps off the battery, each cell holds 2 volts. If the lead plates are exposed, that cell will hold less than 2 volt. Replenish with distilled water or battery electrolyte (sold at some auto parts store, so call around instead of driving all over town). If you have a battery charger & digital voltage meter, the battery should read 12.6 to 13 volts for fully charge. If below this, touch black probe on voltage meter to negative side of battery, then dip red probe on each of battery cell's electrolyte. Write down the voltage reading of each cell, then hook up the battery charger let charge for half an hour or so until battery shows 12.6 or higher reading after unplugging the charger. With charger unplugged, take digital voltage meter and take 2nd voltage reading of each cell, dipping red probe into electrolyte while black probe touches negative side of battery. Write down voltage reading of each cell. Wait half an hour to 45 minutes, then take a 3rd voltage reading of each cell. If there's a drop in voltage reading on one cell from the 2nd time, this cell is not holding a charge and its draining power from the adjacent cells, resulting in eventually leaving a dead battery after it had been parked over the weekend. Replace the battery. This method of diagnosis to check battery condition is more accurate than a load test. I've seen batteries that will pass a load test, yet battery goes dead after the car (or semi truck or bus) had been parked for 2 or 3 days because the faulty cell had drained power from the adjacent cells next to it. In semi trucks & buses, when the battery goes dead, it continues to drain the power from other batteries that are hooked in parallel or series to other batteries.
Mar 20, 2014 | 2006 Chevrolet Impala
I had my car stored for 6 months, battery disconnected and when I reattached it inside lights etc. came on but not enough juice to turn it over. Attached a battery charger which charged the battery to 80%...
newer cars need to see at least 10.5 volts to operate. A new battery has 12.6v. fusses would not have blown while you were charging the battery unless you hooked up the connections wrong. usually if you saw a lot of sparks than i would say it was a fuse. but in your case, it just sounds like you need a new battery. when you store a battery again try and recharge it every month. once car batteries go completely dead they will sulfate and nothing can bring them back. diesel and watercraft batteries are the only deep cycle batteries and they can be run to nearly no charge and be brought back. hope this helps
Apr 03, 2010 | 2007 Chevrolet Blazer
While putting electric window down engine stalled and all electrical went dead even dome light everything is completely dead electrical and batteries good
check the main fuses (bigger fuses in the engine compartment fuse block)
if they are ok, check the ground wire from the battery for defects and the terminals and connection to the chassis for corrotion
Feb 18, 2010 | 1991 Oldsmobile Bravada
Instrument panel went dead
Checked Every fuse in the fuse box (no small task).This includes #4 - Power point Instrument Panel, #14 - Day time running lamps (auto lamps doesn't work nor does auto lock), #27 - ignition switch run feed, #35 - Instrument Cluster, #41 - Instrument Cluster, #42 - Delayed Accessory, #45 - Ignition switch run/start feed, #102 - Door locks body security module, #103 - Ignition switch, #110 - Ignition switch, & #116 - Ignition switch. But I also check all other ones as well, they all register OK. AC panel & radio work. Turn signals work. Mileage does not work, trip computer does. So, basically, everything works except auto head-lights, auto locks, and the dash cluster (no MPH, RPM, mileage display, Fuel, Temp, Tran Temp, and Oil Pressure).
Aug 19, 2009 | 2003 Ford Excursion
MGE UPS Pulsar Ellipse Premium 650 UPS System Logo
292 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
