Question about Aiwa NSX-A777 Shelf System
Volume knob Re: AIWA NSX-A777 The stereo volume knob can only turn the volume up, not down. When I try to use the stereo volume knob to turn it down, it only turns the volume up. I have to use the remote control to lower volume. Thanks in advance if anyone can help. Ps. I have limited technicial knowledge...but any answer would be appreciated.
  • MELISSA HANSON Aug 04, 2006
    thanks for the information!
    Problem Solver:
  • 7 Answers
Hi there,u need only clean volume control delplly that will help i mean the control ler of volume but it need pasion u need open all panle off aiwa near screen connceteed.but need pasion it cost me 5 hour fix all!
Posted on Oct 09, 2012
  • 3 Answers
This really doesn't give a solution to the situation - how do you fix it?
Posted on Dec 19, 2007
  • arthur mancuso Sep 26, 2010
    does the remote work?
Hi Your Problem need an expert Technician, this Aiwa stereo has the digital type volume control that gives pulses to the cpu to make volume up / Down. Solution to be fixed by a technician: - Remove the volume from the front board, disassemble it and clean the conductive parts inside it then reassemble back and check. Good Luck Toufic G. Malek
Posted on Sep 24, 2007
    President:
  • 3,130 Answers
In other words the lever that the front knob is attached to is broken or the microswitch is bad or broken.. if your not a tech please take the unit in to a shop as there are no user serviceable parts inside these units. Good Luck
Posted on Aug 03, 2006
    Scholar:
  • 72 Answers
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Volume dosent turn up and down correctly..u turn the knob and it dosent go louder or softer
I ALSO HAVE THE CX-NA777 SYSTEM, THIS WILL SAVE YOU SOME TIME AND MONEY, FIRST, YOU WILL NEEDS THE SERVICE HAMUAL FOR THIS UNIT, YOUR CONTACT IS www.kap1007@yahoo.co.in TELL HIM BRGARY3 SENT YOU, YOU WILL NEED A PAY PAL ACCOUNT TO PAY THE $9.00, THE MANUAL WILL BE SENT TO YOUR EMAIL, YOU WILL NEED A PAY PAL ACCONUT TO PAY, WWW.PAYPAL.COM TO START THE ACCOUNT, ONCE YOU GET THE MANUAL, GET AN ELECTRONIC TECH TO READ THE PART NUMBER FOR YOU, OR YOU MAYBE ABLE TO FIND IT YOURSELF, UNDER VOLUME KNOB, THEN CONTACT ANDREWSELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, CALL CUSTOMER SERVICE AND PLACE THE ORDER FOR THE VOLUME KNOB WITH THE NUMBER THE TECH GIVES YOU, ONCE IT ARRIVES, YOU JUST HAVE THE TECH PUT IT IN FOR YOU, THIS MAY SAVE YOU AS MUCH AS $200.00.
Nov 09, 2013 | Aiwa NSX-A777 Shelf System
Should i spray the inside of the volume knob to fix the volume?
You can try contact cleaner. Spray some in (with unit turned OFF) and move the knob up and down several times stop to stop. then try to see if it helped.
Dec 28, 2011 | Aiwa Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
My Compact Disc Stereo System NSX-AJ50 is tripping off every time I turn it on. Henry dulcerito@live.com Thanks.
One or more of the output transistors has failed or you have a bad speaker. Try disconnecting both speakers and turning on the unit. If it still shuts down, then the transistors are likely to be defective. These can be replaced for about $15-$25 plus labor at any service shop that handles audio gear.
Dan
Feb 20, 2009 | Aiwa Audio Players & Recorders
Why does the volume go all the way up when i put it to 15?
aiwa typical issue. loved my aiwa's sound hated the stereo. my volume control knob did the same thing and i had to order a new control.
please take time to rate,
good luck
Ryan
Feb 16, 2009 | Aiwa NSX-DS55 CD Shelf System
Volume
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
Aiwa NSX-A777 Shelf System Logo
1,526 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
