Question about Gigabyte GA-K8NS Pro Motherboard
Motherboard wont start - Gigabyte GA-K8NS Pro Motherboard
  • Petri Lahtinen Feb 09, 2012
    Problem is inmotherboard itself. There in only processor and memory, tested also without memory, and it dont start up. It should after switching on lights up leds and start running fans but that dont happen. So any ideas how to check/solve problem?
  • Gigabyte Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
might be getting hot
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Posted on Feb 09, 2012
Installed motherboard but now my computer wont start
RE-INSTALL THE ELECTRIC WIRES AND FOLLOW THE MANUAL
TO THE LETTER.
Jan 04, 2014 | ASUS M3N72-D Motherboard
I need to connect the pow-led
this is the download page for the motherboard manual http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=363&tab=1 it is in Zip file form you want the front panel pinout if you are having a tough time reading this it is because i didn't use any periods or capitalization bu i guess you are used to it
Sep 12, 2012 | Biostar G31-M7 TE Motherboard
My hp pavillon zv50000 wont charge wont start with our without battery wont start with battery out with power supply pluged in help im going crazy
Have the power supply adapter checked, if okay, The problem is more than likely a motherboard issue, first sub out the ram memory one at a time and test, if still no change the motherboard will need to be assessed for possible replacement.
May 19, 2012 | HP Computers & Internet
The computer wont start up, i can see a green light on the motherboard and nothing else. even the power button wont show up led light.
This can be a power supply problem or a motherboard problem.
One or the other has probably gone bad and must be replaced, if this is what happened.
Start by disconnecting all things from the motherboard except the CPU and memory.
If the system starts, then you've ruled out the power supply, CPU, motherboard, and memory.
If not, remove the memory and see if it tries to start. If so, then the problem is the memory.
If not, then it's definitely the power supply, CPU, or motherboard.
Aug 03, 2011 | Intel DH55TC Motherboard
Doesn't start
hi i got biostar g31d-m7 motherboard dual core cpu 1 gb ram 500gb hard it wont boot just stucks in windows logo screen and cant even reinstall windows its just stucks in the booting logo
Oct 06, 2009 | Intel Desktop Board D845WN Motherboard
Gygabyte ga-7n400 pro 2 wont start
How many beeps do you hear and what are the durations? (short, long..) On the surface, make sure the memory speed and configuration match your motherboard.
Good Luck
C2Solutions
Aug 07, 2009 | Gigabyte GA-7N400 Pro 2 : ATX Socket A...
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
M/b wont boot
Since this motherboard starts the boot sequence at all, then the next step I would recommend is to try testing it using a motherboard tester. This will help determine at which step of the boot sequence the motherboard stuck.
Flashing the motherboard's BIOS might help resolve this problem as well.
Apr 12, 2009 | QDI Group QDI Advance 10T Motherboard
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
Feb 09, 2008 | PC Chips MB PCCHIPS P21G (V3.1) P4M800 775...
Gigabyte GA-K8NS Pro Motherboard Logo
44 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
