Question about Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC
A cuboid has sides whose lengths are whole numbers greater than1.b Find the dimensions of the cuboid if it has volume 30 mm^3
  • Mathsoft Master
  • 7,993 Answers
Find all possible combinations of three integers whchi when multiplied together yield 30
2*3*5
If one or two dimensions can be equal to 1 you may find more combinations 1*1*30=1*2*15=1*6*5=1*3*10=2*3*5
Posted on Feb 08, 2012
Define a prime number
A prime number is a whole number greater than 1, whose only two whole-number factors are 1 and itself. Read on at the link.
http://whatis.techtarget.com/definition/prime-number
Apr 04, 2017 | Prime Computers & Internet
Rectangular prism is made from centimeter cubes. What are the dimensions of the prism width x length x height? What is the surface area of the prism? What is the volume of the prism?
Dimension of the prism is the number of cubes in width x length x height.
Surface area is 2(w x l) + 2(l x h) + 2 (wxh)
Volume is the number of cubes.
Good luck,
Paul
Dec 07, 2016 | Office Equipment & Supplies
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
What is volume in litres of a bag 230mm dia x 450mm long?
You give only two values for the dimensions, so it must be a cylinder with a radius r=230/2 mm= 115 mm= 11.5 cm
and a height of h= 450 mm =45 cm
The volume for your right circular cylinder is V=PI*(r^2)*h=PI*(11.5^2)*45 cm^3=?
Divide the result by 1000 to convert the volume to liters (1 L =1000 mL=1000 cm^3)
Jul 03, 2014 | Office Equipment & Supplies
What is rectangular prism?
Hello
Rectangular Prism/Cuboid Definition:
A Rectangular Prism/Cuboid is a solid figure bounded by six rectangular faces, a rectangular box. All angles are right angles, and opposite faces of a cuboid are equal. It is also a right rectangular prism.
Rectangular Prism/Cuboid Formula:
Area of Base(A) = l * w
Perimeter of Base(P) = 2l + 2w
Surface Area of Prism = 2(lw) + (2l + 2w)h = 2A + Ph
Volume of Prism = lwh = Ah
Diagonal of Prism = Sqrt(l² + w² + h²)
where
l = length, w = width, h = height
Hope this helps, if so do rate the solution
Jan 15, 2011 | MathRescue Word Problems Of Algebra Lite
One cube has a face equivalent to the total area of another cube. find the ratio of their volumes?
Let the sides of the cubes be a and b,
the length of the diagonal of the cube whose side is b is given as square root(3)*b
according to the given question,
a=square root(3)*b
the volume of the cube with side a is given as
v1=a^3=(square root(3)*b)^3
and the volume of the cube with side b is
v2=b^3
then their ratio of volumes is given as
v1/v2=3*square root(3)*b^3/b^3=3*square root(3)
i.e v1:v2=3*square root(3):1
Next qwasthun pwease :D
Jan 06, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
HOW LONG AND WIDE IS THE FORD FOCUS FIT INTO MY GARAGE?
I hope this helps
External dimensions: overall length (mm): 4,270, overall width (mm): 1,699, overall height (mm): 1,430, wheelbase (mm): 2,616, front track (mm): 1,494, rear track (mm): 1,486 and curb to curb turning circle (mm): 10,455
Apr 14, 2009 | 2001 Ford Focus
I am trying to find the capacity of a Dayton Glass Lined Electric Water Heater. The model number is partially missing but it starts with 3E1200 Does anyone one have any idea of where I could find this...
To figure close but not accurate use this formula Pie(3.14) X  R (22/2=11)and multiply this by its self before multiplying by pie) sq2  so it looks like this (3.14 * (11X11))*  then multiply by length or height,  length 48)  this gives you cubic inch size roughly, then devide by 231 ( the number of cubic inches in a gallon). This will be close I think its close to 30 gallon.
Hope this helps if so  please rate me accordingly. Good Luck
Mar 01, 2009 | Dayton Electric Heater
I need the following info for my 1999 Audi S3 in relation to the tailgate dimensions: Height.......cm; Length........cm; width.........cm; wight.........kg
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Nov 05, 2008 | 2005 Audi A3
XEROX 5328 COPER
Total weight is about 200 pounds. But, that machine comes apart.
You can take off the thumb screws and disconnect one plug and lift off the document feeder.
The machine processor separates just above the tray 2/3 module, also the tray 2/3 module separates from the stand. So you can make is much easier to move by taking it apart. Nothing is bolted together, just sits one on top the other.
Jul 07, 2008 | Xerox WorkCentre M-24 Color Copier
Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC Logo
109 people viewed this question
Top Mathsoft Computers & Internet Experts
k24674
Michael Cummings
Level 1 Expert
Bapco
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
