Question about Lasonic Ghetto Blaster i931 Boombox
I lost the battery cover for my lasonic ghetto blaster boombox. Does anyone know where I can find a replacement? Thanks!!!
    New Friend:
Http://www.lasonicstore.com/p-91-i-931-battery-cover-black-.aspx
Posted on Apr 29, 2013
3 Suggested Answers
  • 668 Answers
SOURCE: Problem with Lasonic i pod ghetto blaster
Check to see if the batteries are in correctly or there is corrosion on the battery terminals. This may sound too easy but too many times i have seen it happen. Also check to see if there is a switch on the back near the battery lid or on the side of the unit for ac/batt power. If not there is a circuit problem with the unit. Most of the units like that have a year warrenty. If it is out of warrenty it probly would cost more to repair than to buy new.
Hope this helps,
Skyassoc
Posted on Jun 16, 2009
SOURCE: My lasonic ghetto blaster won't come on
Happened to me. wasn't the U shaped connector. It was the connector on the right hand side, it gets pushed down over time. If you look at it and you see that its not pushed all the way up, then thats the problem. I opened my box up and physically pushed it up. It slides right up and then close it back.
Posted on Dec 03, 2009
I plug in my lasonic blaster g31 when I put up the volume it turn off what is it
From the description the audio outputs are cutting out due to bad connections, or semiconductor failure. Check to make sure there are no shorts in the speaker wiring, if no change! take it back to the place of purchase for exchange or repair.
Jul 07, 2012 | Lasonic Ghetto Blaster i931 Boombox
My remote control isn't working
Take a digital camera like the one on your phone... point the 'business end' of the remote at the camera while you can view it in the screen and press a button on the remote.. the IR LED on the remote should be visible on the camera screen. If not, try replacing the battery. If that doesn't work either then it would seem the remote as come to an unfortunate demise. If you can see a blinking light from the remote then it would seem the issue is with the radio's receiver. Make sure the IR port on the radio is free of stickers or anything else that might block it. Also, be sure that you have LOS (line of sight) from the remote to the radio.
Other than that it would seem you need to take it to a repair expert locally.
Apr 08, 2011 | Lasonic Ghetto Blaster i931 Boombox
THE VOLUME KNOB ON MY i931 WILL ONLY INCREASE SOUND, NOT DECREASE
If your volume control has no "stops" to it, meaning when you turn the control it continually spins, then the volume control is what is called a "rotary encoder" as opposed to a potentiometer which has a definite beginning and end. The only way to test a rotary encoder accurately is to do so with an oscilloscope. And usually the only way to repair the problem is to have it replaced by a qualified technician. It's not really a job for the home hobbyist. You may have success cleaning it with a contact cleaner that doesn't leave any residue, but don't hold your breath...
Nov 28, 2010 | Lasonic Ghetto Blaster i931 Boombox
Hi, I bought my Lasonic Boombox a while ago. I turned it on and that only lasted for a little bit, then it made a buzzing noise, switched off and a bit of smoke came out of it. now it won't turn on.I think...
Sounds like its blown. If you bought it in the U.S. and tried to use it in the U.K. then you may have inadvertently fried the system. The U.S. uses 115 Volts AC and the U.K. user 240 Volts AC. If you plugged it in to the U.K. power with out a voltage reducer the radio received 240 volts of raw power instead of its required 115 volts it was built to handle.
Is possible a locale repair shop may be able to save it by replacing it's internal volta-pack, but it won't be cheap.
Hate to hear that happened to you, this is a great sounding radio! Don't feel bad this happens all the time as not many people know about the voltage difference between countries.
Oct 09, 2010 | Lasonic Ghetto Blaster i931 Boombox
I clearly have the correct batteries, but it won't turn on without using the power cable
The battery wire inside the boombox could have come loose or there is corrosion on the battery terminals.
May 23, 2010 | Lasonic Ghetto Blaster i931 Boombox
Make sure the switch on the back is on the correct power setting. The cord is AC and the input is DC. On batteries, switch it to DC and use tinfoil or copper wire on the left top U shaped + battery receptor. on mine, it didnt connect with batteries without metal there
Jul 20, 2009 | Lasonic Ghetto Blaster i931 Boombox
I have just turned on my brand new lasonic i+931 boombox. I plugged it in and it automatically turned on, made a loud humming noise and then within seconds turned itself off. I was thinking maybe a fuse...
same happened to me. it might be the battery circuit or the batteries many times fall out of place so they dnt work. call lasonic or send it back for a new one for free like mine
Jul 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Happened to me, and a very common problem. on the top left of the battery compartment, there is a U shaped connector meant to hook up with the + battery on that side. it's too low, so the circuit doesnt complete. Use some aluminum foil or copper wire to make the U connect with that battery and it should work.
Jun 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Brand new lasonic i931 boombox wont turn on!!!
okay, i had a similar problem, and the problem turned out to be a bad connection. If you open up the battery box, in the bottom top left corner there is a positive connection wire that looks kind of like a "U".
this connection doesn't come in contact with the batteries, so you need to extend it by wrapping a small piece of wire or something to make it stick out more.
what we actually did was put a piece of 1/4 in. by 1 in. piece of copper flashing in the plastic slot and across the U shaped connector to increase conductivity and it works fine.
i hope this was helpful!
Jun 10, 2009 | Lasonic Ghetto Blaster i931 Boombox
Lasonic Ghetto Blaster i931 Boombox Logo
265 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
