Hitachi hdr325 keeps freezing on the library menu and also on the guide, also is missing some recording from series record and recording others with a forzen screen. had it for around 18months and has worked fine til now
SOURCE: DVD recorder will not record
Sounds like the slider assy., tracking motor, or the rail is gunked up. If you know how to disassemble the slider by all means take apart ans see if theres any dirt or hair tangled inside the gears or track. If you dont, you should let a tech take a look at it, as if you take something apart that shouldnt have been disassembled, it will cost ya double to repair. Also the tech will have all the proper alighnment tools and disc to properly get the unit back up and running. Not alot a consumer can do nowadays to repair solid state electronics! Good Luck
SOURCE: Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
SOURCE: All previous recordings do not
Hello, I hope you are having a good day today.
In finding a solution I would like to know the model number of your Thompson product.
In the mean time, most DVRs have a hard drive. Recordings will stay on the hard drive. If you want the recording saved onto your DVD then you need to choose the record option from you menu.
Please let me know if this helps. And give us the model # if you can. Thanks
Good luck.
SOURCE: freezes while recording
I'm been searching for slutions to this as well - It's happened to me numerous times, so much so, I've almost thrown it on the ground to see how many pieces I can break it into...
SOURCE: Thomson DTI 6300 Digital TV Recorder freezes
try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
does anyone know where ican download a manual?
http://help.digitaluk.co.uk/pf/197/webfi...
