Astracast mixer tap dripping cold water how do i fix the problam
  • 225 Answers
SOURCE: Taps that connect to washer water hoses are leaking
first of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
Posted on Jun 20, 2009
  • 50 Answers
SOURCE: i have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Posted on Mar 13, 2010
  • 150 Answers
SOURCE: i have mixer taps on my bath, cold water tap works
Remove the tap outer cover. Take out the barrel & inside there is the washer on the end of a screw which slides in and out when the tap is turned. This could have been turned too far out and will not go back in. Clean both the screw thread and inside the barrel, lubricate with petroleum jelly or similar and reassemble & test before replacing the barrel. Again lubricate all threads.
Alternatively buy a new barrel
  • 268 Answers
SOURCE: on the back of the
I sounds like the cold side of the faucet has a bad side. Contact them for free parts for that side and directions on how to install. It could be just those rubber seals but my be the actuator for the cold water.
Posted on Oct 07, 2010
deeric27894
  • 167 Answers
SOURCE: how do you remove the hot and cold taps on a
Use 2 Adjustable Wrenches . you may need a Allen key set to Remove the Mixer unit . You can fix the Water dripping problem may be replacing a O ring
Posted on Nov 18, 2010
7inch mixer lever tap is dripping how to fix
Turn off the water to the taps. Screw the top off your taps and clean off the rubber seals from lime or dirt and then put back together nice and tight. Hope that works
Sep 07, 2017 | Food Mixers
I Have a cold water dripping in my sink the taps are mixer taps i have fitted a new washer but it still drips also it is tight to turn on and off. also my Hot water tap is hard to turn on it turns quite...
you need to check the seating in the tap for pitting, the new washer will not seal if the seating is pitted. you could fit some TAP REVIVERS which are available from most plumbers merchants.
Sep 08, 2011 | Home
How do you remove the hot and cold taps on a shannon monobloc mixer tap, water is dripping from the cold tap
Nov 18, 2010 | Plumbing
On the back of the mixer tap on my astracast sink has a small hole that seems to be part of th mixer tap is leaking when the cold water is on and not the hot, can you help?
Oct 06, 2010 | Astracast ACR1919MB Rok Composite Kitchen...
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have mixer taps on my bath, hot water tap doesn't work
Mar 11, 2010 | Home
HAVE A RAMON SOLER SINGLE MIXER TAP THAT HAS STARTED DRIPPING HOW DO I REPLACE WASHER ON THIS TAP OR STOP IT DRIPPING
there should not be a washer as it is a ceramic insert assembly
the dripping is from wear of the plates caused by minute dirt particles in the water
the fix is a replacement insert
see a plumber shop for the correct insert
Dec 31, 2009 | Plumbing
Mixer tap makes a noise like a fog horn when cold water turned on
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Feb 04, 2009 | American Standard Plumbing
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
