Question about Zanussi ZIT64X Cooktop
What is the wiring diagram for zanussi xit64x
Its an induction hob power goes to control panel but induction does not work
4 Suggested Answers
  • 1462 Answers
SOURCE: Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Posted on Jun 06, 2007
  • 1462 Answers
SOURCE: Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
SOURCE: left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Posted on Jul 16, 2009
Does anyone know more about the error codes F5 / F6 on a Whirlpool/Ikea induction hob Type: PLEAC, Model: 80123766 approx. 7 years old?
Call a Wirlpool dealer and give them the code. They will tell you what the problem is. I think F5 or F6 is the control panel. The last time I went to replace one I was better off purchasing a new stove.
Apr 22, 2015 | Cooktops
Zanussi induction hob. Hot warning light remains on permanently for one ring. Tried power on/ off- no good.
Unfortunately this is not a user fixable issue,it is caused by a faulty temperature sensor,which needs replacement.
Nov 25, 2014 | Cooktops
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
Only 2 hobs work
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi ZIT64X Cooktop Logo
37 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
