Question about Belkin (F5D7231-4) Wireless Router
Belkin 348A for ip address - Belkin (F5D7231-4) Wireless Router
5 Suggested Answers
roadhawk
  • 25 Answers
SOURCE: IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Posted on Nov 25, 2007
JSPCEXPRESS
  • 178 Answers
SOURCE: belkin router f5d8230-4 ip address change
I am a belkin partner I can help. You can call me
661-588-4401 I can help you out
Posted on Feb 13, 2008
mastersaintx
  • 928 Answers
SOURCE: belkin wrong ip address
You may mean that it is not giving the right address to your computer. Try pressing the reset button for about 20 seconds then unplug the power wait for about 15 seconds then plug the power back in then restart your computer.
If you need further help just message back.
Posted on Nov 26, 2008
Styli
  • 20 Answers
SOURCE: i have a belkin g+
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Posted on Mar 05, 2011
What Is the Default IP Address of Belkin Router? And determine Admin password?
HI ! HERE YOU GO!
https://www.lifewire.com/what-is-the-default-ip-address-of-a-belkin-router-818062
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
Im trying to set this up as an access point. but it will not fine a ip from the router
Most router wont act as a DHCP client (Get an IP address) on their own.
You need to go into the Belkin setup and set it to an IP address in the range of your other router.
For example:
If your PC is getting (connected to the same network) an IP address of 192.168.0.3 IP and a Default Gateway address of 192.168.0.1 you can set the Belkin with any adderss between 192.168.0.10 & 192.168.0.254. Changing the last octet (set of numbers after the 3rd period) to the desired address.
Mar 02, 2011 | Belkin Wireless-N Wireless Router with...
How can I get my IP address set for my Belkin router... IP # 192.168.2.1 ???
Hi go to http://whatismyipaddress.com as soon as the page loads you will see your ip address and if you need other ip details just click the gray box beside the ip address it will be labeled additional ip details you will see things you didn't expect!! hope this helps
Feb 02, 2011 | Belkin Basic Wireless Router
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
Is there any case that the port from belkin router
This may happen due to double NAT issue.... the DSL modem might give an IP address in the range of belkin route....that is 192.168.2.X check for the ip address when the computer is directly connected to the DSL modem... now check for the IP adress when the Belkin alone is connected to the computer.... if they both give an IP adress like this 192.168.2.X......(X can be any value) then you will face the above issue..... in that case you can login to router and change the IP address of belkin router from 192.168.2.X to 192.168.15.X this will resolve the issue
Apr 15, 2010 | Belkin (F5D7230-4) Router (587009)
When I type in the ip address in my browser.....it doesn't open anything. it takes forever then eventually says error. PLEASE HELP!! Trying to find my WPA key so I can connect to XBOX Live. Been trying...
Which IP address are you typing in? The router will have a specific address. Its not your Internet IP address. Go to the Belkin website as the default IP should be th same for all belkin routers.
Jan 06, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin N router and linksys ip cam
You need to connect the camera directly to your computer and have it manually assign an IP Address on your computer so you could access the camera on the first hand.After that you need to range the IP Address of the camera accordingly to the IP Address of your network.
May 05, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Belkin (F5D7231-4) Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
