How to operate omega washing machine cw 1252 - Washing Machines
3 Suggested Answers
GodBlessU
  • 3513 Answers
SOURCE: I have an Omega CW
Hi
The particular model number is not listed in the list of manuals of omega washing machine.Please call the customer support for assistance.However given bellow are some settings of the washing machine,which is extracted from a website.Hope it helps:-
7 is warm wash delicates (warm cycles then it runs through the number 10 delicate cold cycle too)
10 is cold wash delicates
1 is the longest regular cycle
I normally wash with only the cold tap on, 3 for dirty washes, 4 for regular washes.
Soap goes in the middle slot
3 Buttons from left to right
left - in to spray rinse
middle - in to NOT spin dry
right - in for NOT boost heat (or maybe it has no booster and it is just in for cold wash - not sure)
when standing in front of it, reaching over the back, the left connector is cold and the right connector is for hot water.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 09, 2011
  • 3 Answers
SOURCE: Washing Machine
remove the hose on the pump inlet, you may find it in there.
Posted on Mar 23, 2008
I have an omega 1052..l am renting..please let me know what settings do the 3 knobs be on to wash only my work clothes,for approx one hour.Thank you.
Omega Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/omega-products-inc
I need an Omega WD 1052 users manual. Omega Washer ... Omega Washer/DryerWD1052 ... user manual for omega ow6512wa washing machine wit. Omega .
Omega Wd1052 Instruction Manual
comeherefordownloading.com/omega-wd1052-instruction-manual.html
Omega Wd1052 Instruction Manual. esthermg71. Date: 29.09.2014, 16:28. A ll our cell are 100 brand new. _ fx-4500PA - User Manual and User Guide.
Oct 02, 2015 | Washing Machines
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
I have an Omega CW 675-A washing machine and I have just moved in but the owner did not leave an instruction booklet for the settings. Is this a free service? Can you help me? Paul
Hi
Aug 09, 2011 | Washing Machines
My fav6800aww will spin cw while in wash/tumble mode and go unbalance. i removed clutch and everything checks out including the one direction bearing inside the clutch. is there another one i dont know...
Some FAV6800AW series ues an upper and clutch mounted one-way roller clutch bearing. Your machine may be like mine (series 16) and use only the clutch mounted one-way roller clutch bearing. I have pic's in a link in this post for a clutch that has a upper bearing as well as the standard clutch mounted bearing.
Can you rotate the wash basket CW by hand? It should not. The wash basket should only rotate CCW by hand and with very little resistance.
Take a look at this post and see if the trouble shooting steps will help. Your problem seems to be the same as this forum member issue. I believe you have some binding with the one-way roller clutch bearing in the clutch pulley or binding in the agitator shaft causing this issue. Could you rotate the spinner shaft coupler CW in the clutch pulley? See this post for my crude exploded clutch parts view for the spinner shaft coupler.
Rich
Jul 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine doesn't wash
E8 Means the temperature is too high. Replace the thermistor - temperature sensor, also known as NTC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2009 | Washing Machines
Operations instructions needed for an Omega sewing machine
The company that handles OMEGA sewing machines is Euro-Pro. Just enter the model. This is how I got mine for a 7100.
http://www.euro-pro.com/europro/default.aspx
Apr 16, 2009 | Sewing Machines
Hi, I recently purchased an Omega Constellation automatic, strap & watch 18crt gold. With original cardboard box & red leather bound watch case. OK so far. Now the fun. Inside back case: 151.9132. G107.1....
Sorry about that but thought I was in the omega watch site.
Washing machines!, just my luck. 1st time I have used this site.
My problem is that I cannot find this particular model on most of the omega watch sites I have tried and was wondering, a) is it a fake, or b), is it rare.
Further info I missed out, the dial, its oblong.
Thanks for your time, Best regards, clive b
Apr 10, 2008 | Washing Machines
Missing User Manual
http://www.omega-australia.com/OMEGA/jsp/c_index.jsp
this is the companies website, I would contact one of those listed as a retailer near you and try to get a manual from them. Sorry I couldnt be of more assistance.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
