Question about Philips HTS-6500/37 System
Finding Recording/Playing Channel on TV
I have a Panasonic TH42PX80U TV that I connected to the Philips HTS6500/37 using in turn the first four options in Philips Manual. I still cannot get the Recording/Playing Channel picture to come on the TV screen by pressing the channel down button. I did get the sound to come on, but again, not the picture. What am I doing wrong? Other referenced parts of the manual are of no help in resolving this problem. This is one feature I was really looking forward to using with the Philips. Other features have thus far performed well above my expectations. INITIALLY I was able to "stumble" upon the channel and play and record DVDs until I decided to rewire and upgrade the clarity by using a higher option (going from Option 2 to Option 4 for instance). Now, none of the options work. (Should have let well enough alone.) The only other attachment is the Direct TV DVR which thus far has performed flawlessly. Any suggestions and/or solutions would be greatly appreciated.
  • 8,596 Answers
Make sure there is a yellow video cable (or one of the other types of video cable) running from the Philips to your Panasonic. Make note of how the TV labels that source - Video 1, Video 2, Component 1, etc. Use the TV/Video button on your Panasonic to change the TV to the appropriate input channel - Video 1 or 2 if you used a yellow video cable, Component 1 or 2 if you used a red/green/blue cable, etc. Now, make sure that the Philips is in Disc mode by pressing the Disc button on the Philips remote. You should now have picture.
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Feb 16, 2016 | Panasonic Televison & Video
Can't change channel 3 to video for dvd playing - video won't come on to use with dvd player
I SUGGEST YOU USE AV CABLES( RCA ) AN CONNECT TO THE AV INPUT OF THE TV
Jun 20, 2013 | Panasonic CT-36D32 36" TV
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
How do you tape on vcr from a vcr?
The 'quick and dirty' way is to connect the VCR playing the tape via the RF OUTPUT coaxial connector to the RF (sometimes ANTENNA) connector on the recording VCR with it set to channel three or four. BOTH units must be set to the SAME channel. The better way is to use the RCA jacks and all but the very oldest should have a yellow jack (Video) output connected to the other unit's (yellow) video input and for sound, the output white jack connected to the white input jack (left channel) and the red output jack would go to the red input jack on the recording unit. This latter method yields a cleaner signal than the first method.
Jun 14, 2009 | Insignia Digital-to-Analog Converter for...
Playing slp mode picture rolls
the video and control heads are probably dirty. a video cleaning tape might work, otherwise you will need to get a proffessional to clean if for you.
Mar 25, 2008 | Philips Magnavox 20MC4304 20 in....
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Philips HTS-6500/37 System Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
