Question about IBM ThinkPad T20 2647 Notebook
Black Screen I have a Thinkpad T20 2647. Its starts fine, runs through the Windows 2000 load screen, but after, the scren goes black and no matter how long it sits there it wont advance. I've tried with and without the battery and it happens anyway. I can hear the fan working so I dont think its overheating. It did this in safe mode and last known good config also. Anything else I can try?
  • Anonymous Nov 05, 2008
    Same problem happens with XP isnstall. Only ways to get video to work so far is to either bor in safe mode or in VGA mode.
    Problem Solver:
  • 6 Answers
Mostly like is your lcd screen...you can try to see if your laptop still working by connect to external monitor.
Posted on Nov 07, 2008
After changing out fan IBM think pad t40 screen goes black after windows xp screen finishes losding up
Wait Black Screen? AFTER you changed the fan... hmmm... I think I know what the problem is. Okay solution one; You might of hit a wire or cord in the computer when you changed out the fan. Two: You might have the virus 223, get it fixed and it should be going again! Hoped this helped! :D
Mar 25, 2013 | IBM ThinkPad T40 2373 Notebook
Has hp solved the problem with iq804 touchscreen black scren when upgrading to windows 8
You know, HP only cares for $$$ as all other companies, so they are going only to make new, bad pcs.
Feb 08, 2013 | HP TouchSmart IQ804 Desktop PC
Hp modelt60m283 run black scren
Turn off your pc and connect another monitor. If the external monitor works fine then the screen cable is damaged or your laptop's LCD needs replacement.
Jan 20, 2013 | Computers & Internet
I cannot get my computer to boot. It just goes to a black screen after the acer logo and then the Microsoft loading screen comes up and then goes back to the black screen and that's it. I tried system...
This is a hard drive issue, remove hardware and reseat it back into place, sometimes this will work and run fine. But it is more than likely your hard drive will need to be replaced.
Mar 06, 2012 | Acer Computers & Internet
Thinkpad blank screen
Once you run safe mode. You can turn off the laptop. Then start booting normally.
Mar 02, 2012 | IBM ThinkPad T20 2647 Notebook
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dec 30, 2011 | eMachines T Computers & Internet
GATEWAY LAPTOP COMPUTER IS FULLY FUNCTIONAL WITH BLACK SCREEN
umm i would not if you really never opened a laptop before there is deffently a wire loose in there no doubt about that. if you know anyone that could just open the scren part and fix the wire you should be in buissness
Jun 05, 2009 | Gateway MT3705 Notebook
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
IBM Laptop A2629 LCD Problem
sounds like your video is going out wheather its your card or lcd not sure but kinda sounds like the screen
Dec 24, 2008 | IBM ThinkPad A20 2629 Notebook
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad T20 2647 Notebook Logo
104 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
