Question about Samsung Televison & Video
Samsung PCJ533R projection tv, with video problem
From natural colors, it turns in water colors looking like, no more natural, with area of splashes of predominant red. I can associated with the look of a very old color photo that lost the colors. In the convergence screen is a big irregular island of splash of red. I can adjust the blue, but the red is nonadjustable. But the image is sharp, clear and bright, no "3d" image, no screen deformation. The all 3 cathodic tubes are working and you can see all the 3 colors coming out true the lenses (when I look inside the the tv). Reading about, I bought the two convergence IC (STK392-040) and replace them. All finish good, they are warm in an equal way to the touch, but the image is absolutely unchanged. The parts are from E-Bay, OEM, Sanyo. What else can be, and how to verify ?
Ecollier2012
  • 3459 Answers
SOURCE: Sony KP-53S75 Red convergence problem
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
welcomejee
  • 10594 Answers
SOURCE: Looking for Akai part # STK392-040
STK392-040 available in Part Store.
Posted on Mar 27, 2009
  • 41 Answers
SOURCE: the Screen looks 3D & Colors don't line up on my big screen????
If the convergence is off more than 1/2 inch or so you can't adjust. you have a failure of hardware. most likely the output IC. This set has 2 outputs for convergence. Each output contains 3 circuits, Six circuits altogether 2 red ,2 blue and 2 green. The normal customer adjustment will only alow adjustment of blue and red. They should be converged onto the green. There is a much more complex adjustment in the service mode for Geometry and convergence. These adjustments are only needed when you replace a failed componnent like the output ic. These ICs have been upgraded several times since the production of this set. The latest and most powerfull version is STK394-160. If feel up to it I suggest changing both outputs and the corresponding output resistors. Then do a complete geometry and convergence alignment.
Posted on Apr 16, 2009
SD Tech
  • 14553 Answers
SOURCE: hitachi 51f500a rear projection tv screen looks 3d
This model uses two convergence IC's----if 3 D one or both are bad.
Most of the time this set uses either two of the STK-392-110 OR THE STK-392-150 CHIPS.
Both chips and any bad protection resistors around them need to be replaced and the set adjusted.
If you are able to do the repair yourself total parts cost will be under 30 dollars.
Some history for you:
This set like all rear projection tube type sets uses two chips---the ones in your set are Black in color--about 2 1/2 inches wide X 1 1/2 inches tall and are on either one large or two smaller heat sinks with fins on them.
When the chips are installed a white grease called heat sink compound is applied to the metal back of each---the grease transfers heat from the chip quickly to the metal it is bolted to.
After some years the grease dries out from the heat and one of the chips goes instantly.
You can buy a pair of the chips for your set on Ebay for less than 15 dollars plus shipping--
If you cannot do the repair yourself--shop around your area---most shops charge 300-400 for this type of repair. Whoever you get to do it make sure BOTH chips are replaced or you will have the same problem in a few months.
If you open the set and locate the chips---they will have the full STK number printed on them in white letters----there are about 12 resistors around them that need to be looked at--if any are discolored they need to be replaced.
If a shop says it HAS TO GO TO THE SHOP keep looking as any good tech can do this repair right in your home in about 1 hour---I know as I have done hundreds of them.
IF you can solder and are handy I will give you general instructions on how to do the repair and what you need---some people I talk to can either do it or have a friend who can do it for them---let me know
I can tell you what you will need aside from the parts and how to proceed with the fix---
If all this helped rate this solution---I do this here for free.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW--I am here to help people.
Regards, SD TECH
Posted on Oct 30, 2009
Testimonial: "You truly are an expert! Thanks for the advice, don't think it could've been explained any better!"
SD Tech
  • 14553 Answers
SOURCE: Looks like 3D - the red won't converge and is distorted
55H70 model uses two of the STK-392-110 CONVERGENCE IC CHIPS.
If red is skewed and will not adjust you need to replace both chips and any of the protect resistors around them that are gone---Most of the time just the two chips need to be replaced.
You can buy a pair of the chips on Ebay for less than 12 dollars plus shipping----
The chips are black in color--2 1/2 wide X 1 1/2 tall with 18 pins each and are mounted on large metal heat sinks side by side----THEY WILL HAVE THE STK-392-110 PRINTED ON THE FRONT OF THEM IN WHITE.
The question is are you able to do this yourself? If you can you can save the set and a lot of money--most shops are going to charge 300 or more for this kind of repair---IT SHOULD BE FIXABLE IN YOUR HOME.
I HAVE repaired hundreds of these sets--just got back home from doing a Panasonic that uses the exact same parts your set uses.
The chips fail because a white grease to quickly transfer heat from them to the heat sinks dries out after time and one of the chips goes.
Let me know if you need more directions--the hard part of this repair is getting at the chips and the ability to unsolder and replace them.
TOTAL PARTS COST SHOULD BE UNDER 25 DOLLARS.
If this information has helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 07, 2009
Testimonial: "Very detailed and informative. I can't believe someone with so much knowledge would be so giving with his/her time"
I can't get the color set.Everything has a greenish ting,The red adj. don't seem to work.Can't get natural skin tones.Can't get things red thst should be. Can I do somthig and how...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 07, 2011 | Samsung HCM4215W 42" Rear Projection...
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
I have a red curve at the top left and the bottom right . I tried adjusting the colors at the back but no fix .
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Mar 03, 2010 | Samsung HCM4216W 42" Rear Projection...
I was watching tv and it wont turn back on its a samsung hcl4715w/xaa!
Prior to failing was the video looking distorted.
If so it may be a convergence short causing the shutdown.
Symptoms:
Dec 25, 2009 | Samsung Televison & Video
My TV is almost 5 years old. Barely used more
Howdy,
Sounds like the TV has lost the VIDEO and only has color. Make sure all the cables are secure and good. 2) Reset the TV by unplugging the TV or any BOX you have attached to TV. Unplug both from a/c for 3-5 minutes, plug back in and turn both on.
If no fix. Go to service Company that is Authorized and get an estimate, possible cost $450.00 +. Too many areas of concern to help you with particulars.
Good Luck, Big Irish.
Dec 02, 2009 | Hitachi 46F500 46" Rear Projection...
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Red colored halo at bottom corners of screen
Movement of any TV can result in a problem caused by bad
solder connections.In your case, the red convergence IC......
Found on a circuit board,mounted on large heatsinks........
Part # STK392-040.....Change both for prevent maintenance.
Do not use generics - I use OEM or better = Sam,Pan,Hitachi.
After repair,recheck alignment................T.
Nov 20, 2007 | Samsung PCJ533R 53" Rear Projection...
Tv won't start up after turning on power
Most likely is CRT coolant leak on signal PCB or right into
the connectors joining the signal PCB to the main PCB.Give
it a real close look for "wet" damage.
Oct 13, 2007 | Samsung PCJ533R 53" Rear Projection...
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
