Question about Lands Phones
My telstra V850a cordless phone does not have a ring tone when someone is calling. The display indicates an incoming call but handset not ringing, so we are unaware when a call is coming in. If someone has had the same problem, pls let me know.. Thanks.
3 Suggested Answers
SOURCE: No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Posted on Dec 04, 2007
divatif
  • 39 Answers
SOURCE: handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Posted on Mar 17, 2009
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
My two RTX Dual 3088 handsets do not ring when receiving calls (display light comes on and I can answer if I happen to look at my handset right when someone is calling me) and make no beep when I press...
I have exectly the same problem.After surfing the internet i found out that many people experience such bug and nobody has solved the problem by themselves so far.So if somebody knows what to do, please tell us.
Jul 09, 2011 | RTX DUALphone 3088
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
GE 28851 base handset #1, will not save ringer tone or volumn I selected. Brand New.
As it turns out, the primary base handset did save the newer selected ring tone and volume level setting.
However, the base maintains its own ring tone and volume level setting from factory.
Therefore, the base will present its own settings along with the handset setting during an incoming call.
So, one has to lower the volume of the base (in non-talk mode). The base should display in window: LO.
Then, only the ring tone and volume level selected for handset will be presented during an incomiong call.
How did I do????
Ken
Jul 09, 2008 | Uniden Cordless Phone
I HAVE A PANASONIC PHONE (KX-A332CE-B) AND THERE IS NO RING TONE ON INCOMING CALLS. I CAN CALL OUT AND THE LINE IS OK BECAUSE THERE IS A RING TONE ON INCOMING CALLS WHEN I USE ANOTHER PHONE. CAN YOU HELP...
Emeritus,
There are several things to ask yourself.
1. Do you have the manual?
2. Is there any software programming which relates to set ring?
3. Is there a manual switch for ring on/ring off?
4. Will another phone ring when plugged into the same jack?
IF NOT, the red and green wire may be reversed at the jack.
5. Lastly, has this cordless handset ever rang?
Most cordless sets have a volume control from off to loud. I hope this will help you solve your problem.
I
Feb 24, 2008 | Lands Phones
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
No ring on handset
Jun 28, 2007 | NTL VS1500 Cordless Phone
Lands Phones Logo
48 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
