I have a Lenovo lap top. Recently it has switched to a mode where no matter what letter I press on the key board I get a number. The more letters I press the more numbers I get. The # pattern is always the same. It starts at 0 and goes to 9. So if u press
  • 734 Answers
Try Fn-Num lock, to go back to normal keyboard operation on IBM or Lenovo laptops.
Posted on Feb 08, 2012
ericram
  • 101 Answers
SOURCE: keyboard
It is possible that you have a bad keyboard. The best way to test whether this is a hardware issue or a software issue with Windows is to attach a USB keyboard and see if you have the same random results. If the keyboard is bad, which could be from something being dropped on it, a spill, or just worn out, the replacement part is readily available on eBay or other online parts sites for less than $35 and the replacement procedure is rather simple. The keyboard itself is not a fixable part.
Posted on Nov 01, 2009
  • 10 Answers
SOURCE: my lenovo laptop keyboard is not showing english
Theres a on screen keyboard you can see if the on screen keyboard is doing this too. That will tell you if its a OS or keyboard issue. Also try an external keyboard to see if its doing it too. If they all do it it your language pack in your OS. You may need to set your OS language to another language and then switch back to english. Ive seen this before.
Posted on Nov 24, 2009
  • 35 Answers
SOURCE: its always choppy
what is your pc configaration
Posted on Jun 14, 2010
  • 112 Answers
SOURCE: i can't type certain letter with my laptop
Please turn off Num Lock button on the Keyboard to use letters and turn on Num Lock key to use numbers.
Posted on Jun 24, 2010
  • 8909 Answers
SOURCE: My Brand new acer netbook
That is because the laptop has been set up using the Fn keys.
Consult your instruction manual refarding the Function Key settings after rebooting the laptop if it is still a problem.
Posted on Dec 13, 2010
I use a lap top, IBM ThinkPad, that has been in my docking station for a long time and it works fine in the docking station with the external key board and screen. I recently took it out of the docking...
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Dec 03, 2012 | IBM ThinkPad T41 Notebook
Cannot switch between letter and number pads. no whenever I am typing instead the letters some numbers are show up. I need to know how to switch back. Please help
just push the FN key and Nmlock key at the same time. the FN key is located at the bottom left and the Nmlock is usually the same key as the delete key located at the top right
Jun 26, 2011 | Lenovo 3000 Y410 Notebook
I don't have a lap top but a PC and when I type anything it comes up with numbers instead of letters. I don't have a fn key so what do I do?
Hi.
You have your Number Lock on. Look in at the top right of the keyboard for a key which says Num Lock on it and press that key. That will remove the Number Lock and you will be able to type letters as normal.
Regards.
May 02, 2011 | Dell Inspiron E1505 Notebook
Lenovo keyboard when i press letter u number 4 come on
Deactivate numlock. You can do it by pressing Fn and numlock. One of your keys will have numlock on blue. It varies from brand. Is usually on the top row.
Feb 26, 2011 | Computers & Internet
How do I input names on address screen in all CAPS
When you are at the "Enter Name" screen while adding a contact to your Phone Book, press the "*" key to switch between modes. You can check which mode you are in by looking at the box in the upper-righthand corner.
"Abc-W" mode will capitalize the first letter of each word
"Abc-S" mode will capitalize the first letter of each sentence
"ABC" mode will enter in all capital letters
"abc" mode will enter in all lower case letters
"123" mode will enter only numbers
You may switch between modes while entering the name if , for instance, you need to switch between letters and numbers,
Nov 02, 2010 | One Touch Jitterbug One-Touch Cellular...
When i press a key with a letter and a number the n4mber appear. i have to press fn for the letters to work
Keypad is number locked. Try to press the Fn + Numlock key to unlock the keys.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 21, 2010 | Lenovo ThinkPad T61 Notebook
Keys are not working correctly on key pad
It may be that you have NumLock on - these function represents a KeyPad on the Letter Keys - usually the U,I,O,P,[,J,K,L,;,M kEYS are replaced with numbers - to switch on/off you should have a key with Number Lock on it possibly abbreviated to NumLck or NumLK etc - activate that Key - may need to use in combination with the FN key as well to toggle the Number Lock on and off - also often a light appears to show its ON
Apr 13, 2010 | Lenovo IdeaPad S10-1208U Netbook
Instead of the letter ''O'' I get the number 6 on my keyboard.
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 20, 2009 | Lenovo ThinkPad X200 Notebook
Keyboard problem's
Yeah lol!!! shot the cat!
press the fn key and there should be a num key at the very top press those!
Dec 02, 2007 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
