Question about Amana Freezers
My Amana ARB2109 freezer does not freeze and the fan is making so much noise
4 Suggested Answers
  • 12 Answers
SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Posted on Aug 05, 2008
  • 523 Answers
SOURCE: fridge freezer both compartments not cooling or
compressor mabey
Posted on May 05, 2010
marka19
  • 1430 Answers
SOURCE: My bottom freezer amana refrigerator
Refrigerator making clicking noise compressor not running.
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine.
Posted on Jan 29, 2011
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
Freezer is making a loud noise, assume when compressor is on. Pretty much as soon as the door is opened, the noise begins. Things are still frozen inside.
inside the compressor body there are springs which sometimes break and allow the
motor to knock against the outer enclosure. There is no fix for this as the system is
sealed, short of replacing the compressor. Not a problem with operation, but quite
distracting.
On another note, if the freezer compartment is beginning to freeze up or the fan
blade was installed too far back on the shaft, this could also cause noise.
(it will only make the sound in the freezer compartment when the fan is running
if this is the case). Hope this helps.
Apr 28, 2011 | Woods Freezers
Upright freezer makes a loud rattling sound, like something is loose. Doesn't do it all the time, but does several times a day.
have a look behing your drws in the freezer it has probably started to freeze and the fan that blows the cold air around will have an ice build up. The noise you hear is the fan bashing against the ice. The fan is normally situated behind the panel in the freezer section.
Hope this helps
Mar 22, 2010 | Whirlpool Freezers
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Nov 04, 2009 | Amana 15.0 cu. ft. / 425 liter Upright...
My upright freezer is making a loud screaching noise something like a car's slipping fan belt makes in winter. It is still freezing but sounds like something is on the way out.
If you have the model number you posted under, you are looking at replacing the evaporator fan motor, which would be a part number 4309014 for that Maytag MQU1556A. It is located inside the freezer, behind the lower back wall.
Jun 22, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Sears ColdSpot model number 106 7649314
REplace the fan. The fan is most likely bent and will continue to have problems until it is replaced. You can get it at repairclinic.com
May 30, 2009 | Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Freezers Logo
83 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Gil Shultz
Charles T Nevin
Charles T Nevin
Are you an Amana Freezer Expert? Answer questions, earn points and help others
