Question about Vivitek V37835 46 in. LCD Television
COLOR WHEEL WERE CAN I ORDER A COLOR WHEEL FOR MY 56INCH DLP TV
  • PATRICK BEVERLY Oct 29, 2008
    I NEED THE PART NUMBER FOR THE COLOR WHEEL SO ICAN ORDER IT
  • Anonymous Nov 26, 2008
    ok, So I got a new color wheel and verified back with Vance Baldwin to make sure the color wheel was the correct one and it was. Did the install...not too hard and now my colors are off??? I read elsewhere that on a SAmsung you need to take a jumper out but what about the Vivitek??? happened to any of you guys? please let me know. Thanks.
    Problem Solver:
  • 10 Answers
I Have Found The Best Website For Vivitek Tv Parts http://www.encompassparts.com/products/?VIV&start=1
Posted on Nov 21, 2009
    Problem Solver:
  • 3 Answers
Call Vance Baldwin.
They are on the net.
Posted on Oct 29, 2008
2 Suggested Answers
SOURCE: VIVITECH
56 inch vivitek screen blured and hard to see replaced bulb twice
Posted on Nov 25, 2008
Toshiba 52HMX84 DLP color issues
DLP colour wheel reset tool...Goodluck not sold unless your order from Japan.
Feb 04, 2012 | Toshiba Televison & Video
Good day! we have a Sharp DLP 56inch and were having difficulties of looking for the color wheel since last year. Do you any by chance that you could give us a way that we can replace it with other brand...
Hello
There are two main sources to get most of the electronic spare pars. One is 'Ebay' and the other is 'Alibaba'. Get into their sites by googling, and search for the component you need by giving the exact number of the component or giving the model number of Your Sharp TV. The model number of your Tv will be at its back cover; either sticked or printed. They will send the exact spare part you asks at your door step by E-payment. OK
Jun 29, 2011 | Sharp Televison & Video
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
What is causing white spots on my 56inch DLP Samsung Television. It started with on spot 2 days ago and now there is 15
the dlp chip needs to be replaced. samsung will cover the cost of the part and labor. call 1-800-samsung to set up service.
Dec 28, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp 6163w color wheel
Ours was on the color wheel. I also went to samsungparts.com and entered my tv model number and we could veiw the color wheel. However, the one we needed is back orders . I hope your is not.
Mar 02, 2009 | Samsung HL-P6163W 61" TV
Samsung DLP HL-R4266W..no sound or picture. TV is completely dead
Assuming the noise is a high-pitched whine, then yes, it is the color wheel.  If the color wheel goes out, the TV will turn on for a while, then turn off when it can't establish color wheel sync.  The color wheel has to be in sync with the mirrors on the DLP, so if sync can't be established, the TV turns off.
You can order a new color wheel from Sears or partstore.com (among other places) and replace it yourself, if you are so inclined.
Jan 24, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
VIVITECH
Oct 22, 2008 | Vivitek V37835 46 in. LCD Television
Sound on Samsung HD DLP rear projection TV sounds like an airplane taking off (no other sound)
sound like u have a bad color wheel , u need to have the model code to order the new color wheel , is going to be at the side of your set
May 02, 2008 | Samsung DLP HL-P5663W 56" TV
Vivitek V37835 46 in. LCD Television Logo
420 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
